Old 01-31-2011, 11:05 PM   #19
six weeks since post #5. update, please
Old 02-02-2011, 11:01 PM   #20
cfeng
Drives: Yaris 2010 Liftback
does anyone else think this is a scam? the only pictures i see on their website are of a poorly machined block of metal.
cfeng is offline   Reply With Quote
Old 02-02-2011, 11:11 PM   #21
cfeng
Apparently the two halves of the block put pressure on the diff gears. I took a class on optimizing gears, this sounds like bs. Anyways, I'll be happy to machine these for anyone, lets say for ~$200.
http://z31.com/mods/drivetrain/phantomgrip/
Old 02-03-2011, 01:14 AM   #22
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
I like the enthusiasm, but I see a lot of phantom grips going for under $200 for JDM's. It would be cool to have something new on the market though.
Old 02-03-2011, 10:29 AM   #23
cdydjded
Drives: Yaris LB Turbo
Old 02-03-2011, 10:42 AM   #24
cdydjded
6 weeks?, try 9 months! : ). Here is you update, there is nothing to update. I never had it installed. Between family & my business I just had no time to get the car up to them to have it installed. Another factor was that there was not much interested in it here.
The unit works & yes some people have had issues. Some like it, some don't. Its not a scam & the company has been around for over 10yrs. The owner is the same guy that runs the NSCRA.
Old 02-03-2011, 04:46 PM   #25
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
From what I can tell it works similar to a Detroit locker without the dog teeth gears. If your into drag racing I can see it working great but for taking corners locking the axles isn't always the best solution. For the majority of people a KAAZ or Quaffe or even a Torsen(not sure of the yaris is able to get one of those) would be a better fit.
Old 02-03-2011, 04:52 PM   #26
or OS GIKEN
Old 02-03-2011, 09:58 PM   #27
xnamerxx
0-60 in slow
xnamerxx's Avatar
Looking at the design of the OS GIKEN it appears to be a clutch type differential with no spider gears. I wonder how that kind of design would compare to a eaton diff.
My only fear with a clutch type design is the heat generated during long hard cornering which may overheat the transmission/diff.
Very interesting design though to bad they don't list anything for the Yaris on their site.
Old 02-04-2011, 04:05 PM   #28
Jason@SportsCar
They have it... We talked to them (OS Giken USA) last year when we started our project, they did some research and found they were available in Japan. I think Garm has one in stock, if he has not already put it in his car.
Old 02-04-2011, 04:36 PM   #29
They have it -- and I have it. One in my car, and one on the shelf.
This is a superior diff to the Kaaz, I can tell you that.
Old 02-05-2011, 04:14 PM   #30
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
The Phantom Grip sounds great for launching. I always worry something's gonna break when I launch and my wheels hop-hop-hop-hop-hop-hop down the road.
Midnight Drifter is offline   Reply With Quote
Old 02-05-2011, 04:19 PM   #31
^ TRD trans mount will fix that and it installs in 30 minutes.
Old 02-05-2011, 04:27 PM   #32
Midnight Drifter
Going Retro
That however wouldn't solve the one-wheel spin that happens in the first place, I imagine?
Old 02-07-2011, 11:27 PM   #33
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
That's never been a problem in any rally car that I know of and certainly hasn't been a problem in mine.
rob323 is offline   Reply With Quote
Old 02-08-2011, 12:42 AM   #34
xnamerxx
0-60 in slow
xnamerxx's Avatar
The Rally cars that have been built where I work use torsen differentials with viscous coupling center differentials. But they are only rated to last 3 runs which is better than the motors which are only designed to last 1 run. Making 950 hp on a 2.1l is rough on drivetrain parts.
Ive seen that problem with rear wheel drive cars that don't have differential coolers. I know corvettes, cobras, and vipers have had issues with overheating the diffs when using a clutch based diff.
I prefer the design of helical gear differentials because their designs can bias torque from one wheel to the other as long as you have traction whereas clutch type diffs tend to just limit the slip so to speak. Guess I just prefer the feel of a gear based diff over a clutch based one.
Old 02-08-2011, 01:26 AM   #35
rob323
Rarely a problem in front wheel drive cars cause the preloads aren't set anywhere near as tight as they are in rear wheel drives.
Yep, and for a street car they are perfect. Far from it in a circuit car or rally car when you are lifting wheels off the ground though.
Old 02-08-2011, 01:29 AM   #36
rob323
Careful there xnamerxx, next you'll be dropping names
TRD 2 way clutch LSD kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-05-2009 11:59 AM
Anyone installed an LSD in their Yaris? Keith Tinari Performance Modifications 15 08-01-2009 11:54 AM
LSD Question PHXDEMON Performance Modifications 14 05-04-2009 10:58 PM
TRD Helical LSD kngrsll Items for Sale by private party 18 04-27-2009 11:16 AM
Is LSD Automatic & Manual Same? maxgil05 Performance Modifications 4 04-24-2009 10:57 AM
