Drives: 07 Yaris 4DR Join Date: Feb 2011
Advice Needed Install Power Locks and Windows
Hi group,
My daughter has requested that I install (as a birthday present) both power windows and power locks on her 4 DR 2007 Yaris. Any suggestions on kits - I looked at the Colibri kit and it looks good, or should I go to the boneyard and try to find an OE setup, complete, used? The windows are just straight wiring from the factory, but the door locks are ECU controlled. Any experience you have had would be appreciated. I'm comfortable installing and wiring anything. Thanks in advance. |
![]() ![]() Drives: 2007 Join Date: Dec 2010
I too would be interested in this
except I'm a `07 Hatchback member.xD |
If you do a little searching, there is some good info on here regarding the installation process. Many have used the A1electric kits (http://www.a1electric.com/) for the door locks, and they sell the Colibri window kits as well.
Going the OEM route (even with junkyard parts) would be quite expensive. I personally prefer aftermarket keyless entry (and optionally remote start) to OEM, as the good aftermarket ones have much better range. With my UltraStart remote starter, I can start my Yaris from the opposite end of a Home Depot.
#4 | |
but most of them require you already have power locks >=| for the system that you have (or any remote start for that matter) do you believe this is true? aka x we would have to buy one of these power lock kits then get the keyless? |
#5 | |
I love my Yaris!
Drives: White Yaris Liftback 2 Dr. AT Join Date: Sep 2006
Hi! I went that route; got both the Colibri kit for the locks and the A1Electric for the locks... 4 years later and everything is holding up just fine.... I also installed an alarm, and the keyless entry has never failed.
_______________ |
![]() Drives: 09, 3dr, LB, Carmine Red Join Date: Oct 2010
I just installed the power windows, locks, and keyless entry to my car in December. I used the kit from A1electric that had the power locks and keyless entry together. It works great. I used the Spall window kit which works fine too but I think the Colibri kit looks easier to install. I had to get creative with the brackets to keep it from hitting the window.
| Tags |
| power door locks, power windows |
| Power windows and locks on a 2009 3dr. | chilly79 | DIY / Maintenance / Service | 8 | 12-15-2010 12:55 PM |
| Installing power windows and locks | yaris prime | DIY / Maintenance / Service | 30 | 11-28-2009 10:43 PM |
| Questions and advice required about power upgrading(windows & locks) | W.A.S.P | DIY / Maintenance / Service | 10 | 07-22-2009 02:59 AM |
| Aftermarket Power Windows?? | blazerscoach | New YARIS Purchase Forum | 7 | 02-18-2007 06:49 PM |
