Old 02-02-2011, 07:01 PM   #199
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
^ Did you try swapping .z firmwares? I believe .z107 is usually the accepted firmware for toyotas/scions.
What exactly is the problem? Can you even connect to it?
Focus_Sh1ft is offline   Reply With Quote
Old 02-02-2011, 07:17 PM   #200
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
I tried the firmware and failed. Talked to the AEM techs they said its very unlikely that its a hardware issue but I am welcome to send it to them. Only thing i can think of now is the wiring is bad. Something came loose or something. Next possible factor could be that the TPS has gone bad for some reason. Gonna go through the wiring again and make sure all connections are secure. Probably something up with the grounding wires i think.
Yoda is offline   Reply With Quote
Old 02-05-2011, 06:18 PM   #201
Yoda
Yoda's Avatar
tsk tsk tsk i found my problem with the fic. Now to the boost leak.
Old 02-05-2011, 07:10 PM   #202
xixarchangelxix
The Unicorn
xixarchangelxix's Avatar
Drives: 2006 Yaris 5D HB
What was the issue?
xixarchangelxix is offline   Reply With Quote
Old 02-05-2011, 08:02 PM   #203
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Operator error? LOL
Old 02-05-2011, 08:36 PM   #204
Yoda
Yoda's Avatar
well.. you kno those extra wires that you dont use.... yea it not good when they touch stuff they have no business touching. I will leave it at that lol.
Old 02-05-2011, 08:40 PM   #205
TSA?
Old 02-05-2011, 09:48 PM   #206
cdydjded
Drives: Yaris LB Turbo
you can pull them out of the harness plug, thats what i did.
cdydjded is offline   Reply With Quote
Old 02-06-2011, 12:59 AM   #207
Yoda
Yoda's Avatar
Yea I gonna do that. Hmmm I need more powa. I took a ride in my buds stock evo8 and feel in love with that tq. I want that neck snapping tq. Thats my goal for my car. Don't kno the majic number for it but that's what I am aiming for. After I get it retuned gonna do some light weight mods.
Old 02-06-2011, 10:40 PM   #208
Yoda
Yoda's Avatar
Sigh
Dont let friends drive your car....
So either my turbo blew or my engine is shot. Rough idle, misfire above 1k rpm, very strong jerking above 1k rpm. Popped the hood and it sound like a vacuum cleaner. Gonna check the turbo tomorrow for shaft play and pray to GOD my engine is ok. If engine is gone then time for rebuild
Old 02-07-2011, 12:48 AM   #209
ah oh, sorry to hear that.
Old 02-07-2011, 01:25 AM   #210
Focus_Sh1ft
Before drawing those conclusions, check all hoses and piping. I had a very similar situation when the charge piping off the compressor housing popped right off while driving. The symptoms were very similar...
Also, the fact that you describe it as sounding like a vacuum cleaner further backs that up. You may be hearing the air being sucked in.
Old 02-07-2011, 12:04 PM   #211
Yoda
Yoda's Avatar
Yea will check that out. There is a knocking sound on cold star up.... Will post up the vid later tonight when I get off work. Think that idiot spun a bearing. Leak down test gonna be done Thursday.
Old 02-08-2011, 06:08 PM   #212
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Sorry to hear the bad news. Ya I dont let anyone drive unless I'm in the car. Let us know what happened. Hopefully a hose popped off or a spark plug detonated. I dont think U have enough miles on that turbo to have trashed the bearings already, then again I couldn't believe the bearing play on my turbo. Good Luck
pimp my yaris is offline   Reply With Quote
Old 02-15-2011, 02:34 PM   #213
Yoda
Yoda's Avatar
Back at Cft today to dail in the final tune. So happens that the are doing a photo shoot. First up on the Dyno is 2011 4dr sti
Old 02-15-2011, 05:36 PM   #214
Yoda
Yoda's Avatar
Final numbers 178 whp 182 tq @ 9psi. Would have more if I didn't have a resback exhaust.
Last edited by Yoda; 02-15-2011 at 05:39 PM. Reason: SN still have that slight boost leak :( when it gets above 5k boost drops to 7~8
Old 02-15-2011, 05:44 PM   #215
Bluevitz-rs
NICE!!!
Old 02-15-2011, 05:55 PM   #216
cdydjded
What did your A/F look like? Are you still on stock injectors?
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 11:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 12:59 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 01:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-27-2007 12:18 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 09:45 PM
