Old 02-15-2011, 12:15 PM   #1
PumpkinSteve
PumpkinSteve's Avatar
Drives: Yaris SR 1.8
16 x 6.5 rubbing with 205/50/R16?
Can you tell me sure if these will rub? I have 16" x 6.5" ET45 rims with Tein lowering springs and I want to fit 205 50 R16 tyres, does anyone else have a lowered Yaris and wheels of a similar ET?
PumpkinSteve is offline   Reply With Quote
Old 02-15-2011, 12:20 PM   #2
Wisher23
Drives: LB
The tires a little tall, but it should work with no rubbing. I run 205/45/16 with 16x8.5 and 16x8 wheels. Im lowered on tein stechs and get no rub what so ever.
Wisher23 is offline   Reply With Quote
Old 02-15-2011, 12:27 PM   #3
PumpkinSteve
According to the online tyre calculator, the 205 50's are the closest match in diameter to my stock wheels, only 5mm smaller overall. I just want to make sure that they definitely don't rub, I think the offset is the thing to watch here, but I'm not sure if ET45 is good or it need to be higher/ lower?
Old 02-15-2011, 12:43 PM   #4
here's mine on 16x6.5 miata wheels, offset is 38iirc and i was on 205-45-16's. lowered about 2" on megan coilovers
Old 02-16-2011, 03:24 PM   #5
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I rubbed with 205/50/16s (+37) lowered on Megan coilovers.
Old 02-16-2011, 04:16 PM   #6
Klink10
Klink10's Avatar
I am not rubbing at all with 16" Enkei RPF1's offset +43 and 205/50/16 Generals. Lowered via TRD springs and shocks. If I could have gotten the rims at +45 I would have gone that route.
Old 02-17-2011, 02:23 AM   #7
PumpkinSteve
So, judging by you guys' posts it's the offset which makes all the difference...
Where did the wheel rub? The outside arch?
Old 02-17-2011, 02:03 PM   #8
Klink10
Klink10's Avatar
Yes, offset is the key.
Old 02-17-2011, 07:40 PM   #9
i would only rub on severe dips in the road where the fender plastic would dip and rub the tire
hell, i get that now w/ my rpf1's and 205-50-15's w/ hard driving....
Old 02-18-2011, 11:17 PM   #10
Thirty-Nine
Yes; at about the 10 o'clock position.
Old 02-19-2011, 10:19 AM   #11
PumpkinSteve
I just realised that I have been pretty stupid thinking about these tyres:
the stock tyres are 205 45 R17 which have an overall diameter of 617mm
the 205 50 16 have an overall diameter of 611mm and an equal section width...so how could they NOT fit? they are smaller, if the stock wheels fit then there is no reason why the others wont. The offset difference is only -6mm, surely they will be okay?
Old 02-19-2011, 12:45 PM   #12
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
If you have a 45 offset you should be in enough that they only rub on big bumps.
I was running 205/45/17s with a 42 offset and only rubbed on big bumps,when I changed tires I went to a 40 offset and only rub still on the same big bumps on my daily drive....our roads here were built by blind monkeys...pretty bad.
The lower the offset the further out the wheels sit out in the wheelwells and larger the offset the further in they sit.
You should be fine....and it should look great on how it sits....hope that helps.
Old 02-19-2011, 12:55 PM   #13
PumpkinSteve
^since the offset is only 6mm different between my stock wheels and my aftermarket wheels, I guess an extreme measure would be to take them to an engineering company and have 6mm milled out of the centre of the wheel, then they would fit perfectly and match the stock rims.
I'm only asking all of this because 205 tyres cost considerably less here than 195, about 20% cheaper I think...
Old 02-19-2011, 01:00 PM   #14
bzinn 1
bzinn 1's Avatar
nahhhh....you should be fine...Im on 42 offset and rarely rub in the front,backs never rub and I havea spacer back there too pushing out 10mm so they are 32 offset.
the rub on the front is where the bumper meets the fender on the liner it wears through in a day or two and you have hardly no rub at all ever then.
You should be fine.
Old 02-19-2011, 01:11 PM   #15
PumpkinSteve
I just realised that because the new rims are 1/2 an inch narrower (6mm on each side) then the +6mm offset is completely negated by that, hence they are in exactly the same position as the stock wheels. So they will definitely not rub...that was hard work
We should compile a proper list of all offset and tyre combinations that people have and whether or not they rub, then others could check for reference when choosing rims and tyres.
Rubbing Issues RacerFreakXXX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 05-12-2010 08:26 PM
Installed 6.5 components with crossover but have a question... YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 7 03-01-2010 12:22 AM
anyone rubbing with df210 on 205/45/17 marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-09-2009 10:59 AM
Rubbing botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-06-2009 03:32 PM
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
