Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 02-20-2011, 04:16 AM   #703
markylicious
markylicious's Avatar
Drives: 2010 Yaris Sedan "Abyss"
Originally Posted by xtremist View Post
wahahaha...bakit naman? gusto ba nila bumili ka ulit ng yaris? msta n nga pla auto mo? npaayos mo nb ung gasgas?
naniningil! mafi fulos pa. d pa kaya ipaayos.
mga ka YW ME, khamsa2x naman tayo! sarap mag ihaw eh! para naman ma-itodo natin mga boombastic nyo!!!
markylicious is offline   Reply With Quote
Old 02-20-2011, 04:41 AM   #704
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
Go! I-Sked na yan!
jonimac is offline   Reply With Quote
Old 02-20-2011, 05:49 AM   #705
syntax
syntax's Avatar
Originally Posted by jonimac View Post
Go! I-Sked na yan!
GO GO GO
Old 02-20-2011, 07:46 AM   #706
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
mga kayaris, galing kmi sa Lulu kagabi and found some speakers and ampli. can you check if this is ok sa car natin at paano kaya installation nito?
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
Old 02-20-2011, 09:18 AM   #707
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
Go! I-Sked na yan!
cge ok ako jan galaan.....di pa ako nakakarating dun...
rosco is offline   Reply With Quote
Old 02-20-2011, 11:49 AM   #708
rosco
rosco's Avatar
mga kayaris baka pede dun na ganapin ang monthly mini meet sa khamsa khamsa.....march 4,2011...suhestiyon lamang po...kung may ..gusto....
Old 02-20-2011, 12:51 PM   #709
armando
pilyo
armando's Avatar
Drives: blue yaris y 2009
ako anytime, nalamangan nga ako doon sa inuman syang. wala man lng ang yaya!
armando is offline   Reply With Quote
Old 02-20-2011, 01:40 PM   #710
rosco
rosco's Avatar
Old 02-20-2011, 02:14 PM   #711
jonimac
jonimac's Avatar
...Bro, huwag ka na magtampo... TRIAL lang yun, besides di rin preparado ang lahat, hayaan mo may kasunod yun tol.
...hoy magpaliwanag kayo!!!
Old 02-20-2011, 02:26 PM   #712
rosco
rosco's Avatar
okey dun daw sa khamsa khamsa..................softdrinks ??
Old 02-21-2011, 01:03 AM   #713
jonimac
jonimac's Avatar
@xtrem, saan mo pala gagamitin yung amp.? It's a 2 channel amp (stereo) or mono (bridged), pwede sya to drive 2 speakers or a sub woofer not more than 200watts.
Connection? still high input (speaker connection) base sa info. nya.
Share ko lang... look for 4 channel amp with sub pre amp out and ask for RMS ratings ng speakers & amplifier not their peak power rating, nakaka ligaw ito mga bro's.
Old 02-21-2011, 01:15 AM   #714
jonimac
jonimac's Avatar
RMS POWER VS PEAK POWER
RMS Power refers to Root-Means-Square power. The formula for determining RMS power is 70.7 x Peak Power Rating. The RMS power rating is a measure of continuous power measured in watts and the higher the RMS power means the device is either able to provide or accept the specified power over a significant length of time without fail.
Most suppliers use the PEAK POWER ratings in their specifications. I would prefer not to recommend use of Peak Power when assessing the capabilities of a music product because Peak Power does not reflect a product’s capabilities under normal, every day use. It is simply a measure of how much power can be generated or handled for very short period of time. I believe speakers, subwoofers and amplifiers should be compared using the RMS power ratings to ensure the right product is chosen for the application in question. However, since most suppliers advertise peak power and since most consumers believe that larger numbers are better, some are forced to also advertise peak power.
For example, if a speaker has a RMS wattage rating of 100 watts and a connected amplifier has a RMS wattage rating of 100 watts, the speaker should theoretically, be a perfect match regarding power capabilities and a result in optimum performance from both products. While it is important to not be fooled by Peak Power, Peak to Peak or the erroneous numbers often made up by some suppliers, as long as you have accurate peak power numbers for both the speaker and the amp or receiver, you can still make an accurate comparison using the fornula above. While only true power, under everyday, realistic circumstances actually means anything, if one supplier advertises peak and another advertises RMS it becomes harder to make a comparison without an understanding of both.
Old 02-21-2011, 01:39 AM   #715
syntax
syntax's Avatar
pre nosebleed ako dito ahh...
Old 02-21-2011, 01:54 AM   #716
jonimac
jonimac's Avatar
aku din eh...
Simply... don't go for peak power, always look for RMS ratings (speakers & amplifiers) even sa mga Home Theater systems dyan.
Old 02-21-2011, 02:23 AM   #717
rosco
rosco's Avatar
aku din eh...
..isa kang gabay!
Old 02-21-2011, 02:25 AM   #718
xtremist
xtremist's Avatar
thanks pre, punta agad ako ng clinic, daming dugo naubos sakin eh
Ciao !!!
Old 02-21-2011, 02:25 AM   #719
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
no comment
duke_afterdeath is offline   Reply With Quote
Old 02-21-2011, 02:27 AM   #720
xtremist
xtremist's Avatar
ah gnun ba, plan ko sana in the future plitan ung stock speaker eh w/ the same size sana, kaya lang no idea ako kung paano pumili ng suitable speajer and ampli pra doon, ampli na kailangan ko e pra lang sa speaker since may active sub nman na tyo.
Ciao !!!
