Old 02-22-2011, 12:18 PM   #163
bkndacn
bkndacn's Avatar
Drives: 2009 Toyota Yaris
So I just bought my Scangauge II from Garm and I've had it in my car for about 3-5 days now .....
On the first day that I had it in the car I drove down to DC (about 120 miles one way) as I do every friday night (work) and my scangauge told me I averaged 45 mpg for the whole trip (95% HWY 5% CITY) and then on the way back I averaged 43 (prob bc CC was on)
But looking at everyon elses #s I feel like thats too high!! lol and Ideas as to what might be causing this false readout? if in fact it is a false maybe i just have a super FE Yaris!
I got a ride in Garms' Yaris and got on a plane within 24 hours of each other.... his yaris was faster! I bet if he put wings on it he could get passed all that L.A. traffic!
bkndacn is offline   Reply With Quote
Old 02-22-2011, 03:36 PM   #164
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Dont you have to set a standard on the device by recording your first full tank of gas then inputting some parameters on your second tank of gas??
Old 02-22-2011, 03:58 PM   #165
bkndacn
bkndacn's Avatar
yeah but it still tells me what my average MPGs are
Old 02-22-2011, 08:47 PM   #166
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
Hey guys, just got mine today works pretty well!!
I've got a few questions:
Anyone have experienced issues by placing it over the steering wheel because of the direct sunlight it may get there?
Is there any way I can read whenever the a/c compressor clutch is engaged?
Is it true that I can send codes into the ECU, like turning on/off the radiator fan for example?
http://www.verboom.net/info/speedste...16/xgauge.html
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 02-24-2011, 04:02 AM   #167
jambo101
jambo101's Avatar
Is that the setting where the mpg reading is all over the place or the X gauge reading that posts average mpg by the day,the trip or the tank.?
Old 02-24-2011, 03:23 PM   #168
Kitt
Kitt's Avatar
soo what is your average water temp and idle rpm??
Old 02-25-2011, 07:04 PM   #169
Kitt
Kitt's Avatar
Has anyone been able to add the air to fuel ratio gauge on xgauge?
Old 04-16-2011, 05:17 PM   #170
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Thinking about getting one, found this info and thought I'd share this here:
$127.99 ($159.99-20% off) Use Promo Code AECCDX1 to get 20% off
Offer 20% off expires 04/18/11
Link here
Old 04-18-2011, 05:35 AM   #171
jambo101
jambo101's Avatar
My water temp stays around 184-188
Idle RPM 710
Old 04-28-2011, 08:09 PM   #172
toy_toronto
always toyin'
Drives: 2010 5-Dr
* crossposting to this official thread =)
Finally decided to get one and I think it's great -- note the current units on display are in metric:
The gauges I use for now are:
• 7.4 L/100KM = 31.7 MPG (Ave Fuel Economy per tank)
• 421 KM = 261 Miles (Distance to Empty tank)
• 13'C = 55.4'F (outside ambient temperature)
• 789 RPM idle <-> Switches to Instantaneous MPG
* Edit: By the way, this is how I mounted the SC II against the windshield.
Material is plexi-glass from left over projects -- pretty strong/sturdy and does not move at all. Total cost = $0
* View from backseat
Old 05-01-2011, 11:33 AM   #173
Revsson
^Interesting installation.
I was thinking of trying something using the same "velcro" strips that the Illinois tollway
gives out to mount the I-Pass.
How hard is it to route the cable under the headliner?
Do you have any pics looking back into the windshield to see the back side of the install?
Old 05-01-2011, 07:37 PM   #174
toy_toronto
always toyin'
Drives: 2010 5-Dr
Sorry I don't have any pics looking from behind that's why I drew up the sketch of the mount. You can't tell it's there looking from the outside due to the tint on the (upper) windshield. It's not difficult to hide the wire under the headliner, just tuck it in under there.
I actually used the same velcro/fasteners they give you to mount your EZ pass or Transponder toll devices to your windshield.
From my pictures above you could actually see two other velcro/3m dual lock strips (right behind the ScanGauge) where I stick my transponder to.
Old 05-02-2011, 07:12 PM   #175
Revsson
Now that you mention it, I do see the strips of velcro.
Illinois wants theirs mounted lower and more toward the driver's side,
IIRC. I mounted it more centered and below the tint, so it actually
sits behind the mirror and isn't seen by me unless I crank my head a little.
Thanks for the info and ideas!
Old 05-15-2013, 10:37 AM   #176
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
Got mine last night. Did the basic setup, have not adjusted the cut off setting, have not filled up. This morning I checked what I could on my drive to work. The speed readout was about 1.5 mph below the read out on my GPS, pretty close. The instant MPG reading seemed pretty close to the Eco-meter built into the car. The average for the trip was a little higher than the eco-meter. The SCII indicated 53 mpg avg, the Toyota Eco-meter indicated 51 MPG. I guess as I dial it in it should get more accurate.
I have mine set to fast updating, and I find it easy to watch.
Amdkt7 is offline   Reply With Quote
Old 05-15-2013, 07:51 PM   #177
nookandcrannycar
Those 3M Dual-Lock fasteners are fantastic. I've been using them for probably close to 10 years for various car related and other uses.
Old 03-28-2014, 01:26 AM   #178
mario98c
mario98c's Avatar
Anyone know if the scangauge can display knock retard values?
Old 03-31-2014, 10:18 AM   #179
jambo101
jambo101's Avatar
As an instrument to measure MPG my Scangauge is useless and cant be trusted to give an accurate reading..
With a full tank of gas and sitting at the gas station I put in all the required parameters for setup in miles and gallons as the trip was entirely in the USA,also included an Xgauge setting to show me average MPG per day,went to the fillup and pressed DONE then off for a 2000 mile trip,MPG read steady at around 36MPG through the first tankful but when i refilled the tank with 8 gallons of fuel going to the fillup icon it said i just put 12 gallons in so i adjusted/recalibrated the 12 gallons back to 8 gallons and started off again but now the MPG reading was reading a steady 25MPG.Throughout the trip the amount of gas i actually put in got further and further away from reality and i saw fluctuations as low as a steady 10MPG to as high as 90MPG The problem was probably my my fault but i cant figure out what i was doing wrong as the set up is quite straight forward and subsequent fillups should have read very close to the amount i was actually putting in the tank but in reality that fillup number just got further away from actual gas input..
Any one got an idea whats going wrong?
And can anyone suggest a less problematic MPG device?
Thanks
Have Yaris will travel..
Old 03-31-2014, 11:13 AM   #180
Thanks
The problem with how devices like ScanGauge, Ecometer, etc. calculate MPG is what they do when the car is standing still. If the car was always in motion it is very accurate, but as the ratio of in to not in motion increases it becomes a crap shoot.
As for the 10MPG to 90MPG fluctuations; That is actually normal. When the Yaris is under heavy load the MPGs decrease significantly. For example, driving up the 1/2 mile hill of the road that I live off of, I see a pretty steady 8-12 MPG. Coming down it I start off in the 80-90 MPG range (when my foot is still on the pedal) and I quickly hit DFCO where the scangauge shows 9999.
How DFCO is handled is probably another issue with how these devices do their calculations as well. You have infinite MPG during this period, so depending on how you average that in can skew things quite a bit in the opposite direction of averaging the theoretical 0 MPG while stopped.
