Old 02-24-2011, 04:49 PM   #1
blacks
Drives: toyota yaris sedan
Trunk Problems
Hi
I have a problem with my trunk when i open it it doesn't stay open it closes back down on me
It doesn't open up completely on it's own
Does anyone have the same problems
Can anyone help me by telling me what to do
blacks is offline   Reply With Quote
Old 02-24-2011, 05:45 PM   #2
MUSKOKA800
MUSKOKA800's Avatar
I've never had that issue. You might check that nothing is dislodged/broken in the area of the hinges. Compare the left and right sides for differences. One spring rod may be disconnected or damaged.
Old 02-24-2011, 06:33 PM   #3
blacks
I already checked all of that there's nothing broken or disconnected
Old 02-24-2011, 08:33 PM   #4
tk1971
tk1971's Avatar
Did you by any chance soundproofed it? Adding weight to the trunk lid (ie. dynomat, etc) will cause this.
tk1971 is offline   Reply With Quote
Old 02-24-2011, 10:53 PM   #5
Tom48
Drives: 2008 Yaris Hatch Back
You may need to add/replace the Hydrolic (sp?) supports on either side of the trunk.
Tom48 is offline   Reply With Quote
Old 02-24-2011, 11:42 PM   #6
The sedan uses torsion bars, rather than gas shocks. They are #12 and #13 in the diagram below. They may be too fatigued to support the trunk.
Old 02-25-2011, 01:58 AM   #7
Tom48
What about adding a spring between 13 and 14? Adding more torsion.
Old 02-26-2011, 07:25 AM   #8
blacks
Thank you very much everyone
I'll check out everything that you've posted and i'll get back to you
@tk1971 no soundproof
@CTScott i will check it out
@Tom48 Too complicated
Old 02-27-2011, 12:29 AM   #9
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
The trunk lid blows down in a breeze on my sedan. It ALWAYS catches me by surprise and is a painful reminder. I would have been happier with gas struts, but that ain't how they built it. The trunk lid is very flimsy, and I ain't sure that it would stand up to struts.
Not many flaws in the Yaris sedan, but that is one of them...
Old 02-27-2011, 06:58 AM   #10
blacks
@TLyttle Yep yep that's true i always get reminded by the trunk that it doesn't stay up because it hit's me everytime
Old 02-27-2011, 10:46 AM   #11
tk1971
tk1971's Avatar
I had taken the spoiler off my EVO (to avoid all the silly stop light challenges) and every time I popped the trunk, it would launch up. That's why either there is extra weight on the trunk, or the tension bars are binding, or they are no longer correctly in place. Good luck.
Old 02-27-2011, 12:43 PM   #12
RedRide
RedRide's Avatar
I agree as torsion bars rarely go bad particularly in this type of application although, it is a pssibility.
Old 03-04-2011, 11:16 PM   #13
auto pal
Drives: 2008 toyota vios 1.5G A/T
same problem here. thought it was just one of the quirks of the vios/yaris. it would be nice to find a solution to this problem.
auto pal is offline   Reply With Quote
Old 03-05-2011, 06:30 AM   #14
zuberio
Joined 3/08 ... really
zuberio's Avatar
Drives: '07 Sedan
Ahem, all, may I please direct your attention to the Yaris TSBs thread where I discovered this little gem well after my warranty expired.
To sum it up ... Toyota has known about this issue for a while without telling anyone and we all have bumps on our heads because of it.
zuberio is offline   Reply With Quote
Old 03-12-2011, 06:31 PM   #15
Trubin
Trubin's Avatar
Drives: 2009 Toyota Yaris Hatchback
I sorta got the same thing on my hatchback, after this winter the trunk does not open on its own I have to push it up. Any Cheap Ideas on what I could do?
"Dat's only in da moning."
Trubin is offline   Reply With Quote
Old 03-18-2011, 08:19 AM   #16
blacks
@CTScott I changed the torsion bar , i put on the one without spoiler and it's worse now what should i do ?
Old 03-18-2011, 12:36 PM   #17
The no spoiler one would provide less tension than the spoiler one. If you read the TSB linked above, supposedly there are newer ones which provide more resistance than the original ones.
Old 03-18-2011, 02:30 PM   #18
blacks
So what should i do now purchase the one that says with spoiler ?
Remote trunk opener Dec24th Cosmetic Modifications (Exterior/Interior) 16 01-29-2016 10:18 PM
Sedan trunk question brg88tx General Yaris / Vitz Discussion 15 07-08-2010 03:30 PM
Adding Power Trunk Release Ideas...Need Help Jrilla DIY / Maintenance / Service 12 08-23-2009 03:38 PM
Trunk carpeted and rear seat belts removed (lots of pictures) m911gt Cosmetic Modifications (Exterior/Interior) 24 05-24-2009 05:38 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 02:26 AM
