Old 02-24-2011, 07:03 PM   #1
david_mackk
Drives: Yaris 5dr LB
HELP PLEASE! 5dr s-techs and df210???
Hey guys I got a 2010 5dr lb . Just bought some ROTA GT3 16x7 +40 with 195/50/16 tires. I been doing some research into springs for my car too. There are s-techs with a 1.9" drop and df210 with a 1.6/1.8" drop. Then I search up to find there are 5dr tein s-techs with a 2.1/2.3" drop and df210 with a 1.6/2.1" drop. Can both springs be used or only the 5dr ones since I have a 5dr? Would I have any rubbing issues with any of these springs with the wheel/tire setup I have. Anyone got any pics with the 5dr springs??
Thanks guys!!
david_mackk is offline   Reply With Quote
Old 02-24-2011, 07:20 PM   #2
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
um.....you drive a 5dr but your info says 3dr?
OTA'sTOY is offline   Reply With Quote
Old 02-24-2011, 07:25 PM   #3
david_mackk
My bad didn't even realize, I'll change that now if I can!
Old 02-25-2011, 01:06 AM   #4
david_mackk
Anyone??????
Old 02-25-2011, 01:09 AM   #5
enviri
enviri's Avatar
Drives: 2010 Yaris
dunno with your rims i'll go for a lesser drop (df210s in your case). you have a bigger chance to rub in the front if you go lower.
Old 02-25-2011, 02:16 PM   #6
OTA'sTOY
OTA'sTOY's Avatar
Drives: '10 5dr
the springs are probably the same, the only difference is that our 5dr are alittle heavier than the 3dr so it will lower a little more. did they have different part numbers?
Old 02-25-2011, 03:30 PM   #7
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Thanks guys!!
sick rims i got the same one although its dragdr16 which is the same as well as offset running on 205/50/16 since its rs model.. im only on trd which is about 1 inch drop but i do rub on dips still..
Old 02-25-2011, 05:27 PM   #8
david_mackk
Same part number same price for the s-tech's. The df210 I think are same part number but are about $80 more expensive
Old 02-25-2011, 05:33 PM   #9
OTA'sTOY
OTA'sTOY's Avatar
Drives: '10 5dr
If there the same number then the drop difference will be because of the weight of the
5dr to 3dr
Old 02-27-2011, 06:56 AM   #10
david_mackk
Your car looks awesome, I only found one pic on the forums. Could you upload some more if you have any please?
Old 02-27-2011, 12:11 PM   #11
marcus
toyota
marcus's Avatar
http://www.yarisworld.com/forums/sho...ight=drag+dr16
