Old 02-23-2011, 03:49 PM   #1
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Golf cart/diesel??
Hey there all,
I've been noticing lately that my engine sounds like a loud gas powered golf card or diesel engine when accelerating.
I remember reading something regarding an exhaust part that caused the noise, but I'm wondering what that would be.
When driving at a constant speed it's fine just when accelerating I can hear the LOUDness of the engine.
Any help would be appreciated!
devinlamothe is offline   Reply With Quote
Old 02-24-2011, 11:35 AM   #2
Vinceb
Drives: 2008 5 Speed Sedan
does it seem to lack power when accelerating? or a bit sluggish? chances are if it's louder and sluggish then there is probably a hole somewhere in your exhaust system allowing more emissions to escape than normal.
if not that maybe a problem with your resonator? or the catalytic converter ?
Vinceb is offline   Reply With Quote
Old 02-24-2011, 04:34 PM   #3
yaris2010RS
yaris2010RS's Avatar
lol, all the canadians chimed in on this one.
my vote is exhaust leak. loose heat sheild sounds like.....well a loose heat sheild. would sound more like something is being dragged under the car
Old 02-25-2011, 02:29 PM   #4
devinlamothe
I've had a loose heat shield before and it was more of a metal clanging sound... but I will check under the car for that.
And no, there is no real hesitation or sluggishness ... it just sounds louder when I am accelerating, like a diesel engine sort of, it's hard to explain.
It could be the CAT but how can I check?
Old 02-25-2011, 11:46 PM   #5
devinlamothe
It's more of a putter putter ... like press your lips together and blow lol and that's what it sounds like.
Old 02-26-2011, 02:11 AM   #6
yaris2010RS
exhaust leak. check the "flex" pipe portion for holes or leaks.
Old 02-28-2011, 08:04 AM   #7
Vinceb
excessive water in the muffler for some odd reason? did you back into a snow bank and got snow in the exhaust which then melted, and isn't draining out for some reason? lol
Old 02-28-2011, 08:45 AM   #8
yaris2010RS
naw, most likely u wouldnt hear a sound from that.
my friend works at a dealership and someone got their car towed to the dealer cuz it wouldnt start. they checked it out and saw the exhaust tip was full of snow and ice, so they left it inside to melt and 2 hours later it started up no problem
Old 02-28-2011, 12:37 PM   #9
devinlamothe
Nope that's not it...
I did a quick check of the rubber hoses and everything seems fine. I am now thinking it could be the PCV Valve? I usually change it every year (cheap part) but I haven't for a while.
Also I am due for new spark plugs but I don't think that would be it.
Old 02-28-2011, 02:51 PM   #10
yaris2010RS
miss fire or no fire could make a sound but it would throw a computer code
Old 03-01-2011, 08:00 AM   #11
Vinceb
if trying to pinpoint an exhaust leak, could always spray some seafoam into the throttle body, have somebody else rev the engine and look underneath to see if you can see any smoke 'leaking' from other parts of the exhaust - I guess exhaust leak is the only one that fits this issue.
Old 03-01-2011, 12:25 PM   #12
yaris2010RS
for it to be a exhaust leak and for it to just all of a sudden appear, it wasnt slow and slowly getting worse ur looking for a crack (header) or u blew out the seal between header and exhaust or the flex pipe part has gone bad, i remember a thread from a member in ottawa or quebec that had his flex pipe go bad with reletavitly low km and it was said to be due to city driving.
Old 03-04-2011, 06:38 PM   #13
devinlamothe
Thanks guys ... I will probably get someone to rev the engine while see if I can find any smoke or anything ... if that fails I will take it in to see what's wrong. :P
Old 03-05-2011, 02:36 AM   #14
yaris2010RS
u probably could have done it when it was cold, i doubt ull see any smoke now.
as someone revs it, spray water along the header and at the joint and see if u see the water getting blown out of the air
Old 03-06-2011, 02:15 PM   #15
devinlamothe
It's still cold up north here, so I will prob do it today (its -13).
Old 03-06-2011, 07:03 PM   #16
yaris2010RS
lol^ my bad. if u feel like getting FREE professional help for ur issue, come down to the west end toyota meet on wednesday
Old 03-06-2011, 09:37 PM   #17
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
I have the same problem, sound like a "cheap" car with after market piece of crap on the exaust system.
the_boss is offline   Reply With Quote
Old 03-07-2011, 03:12 PM   #18
devinlamothe
Yes that explains it LOL
I did go out yesterday and try to see if I could find any leaks but I couldn't see anything.
I guess I will have to take it in.
Golf ball shift knob Mittelklasse Cosmetic Modifications (Exterior/Interior) 9 10-25-2010 07:47 AM
Golf Ball Shift Knob MadMax Cosmetic Modifications (Exterior/Interior) 11 03-08-2009 02:52 PM
Golf ball attacks Yaris windshield. Scooterman General Yaris / Vitz Discussion 5 06-16-2006 10:49 PM
