Old 02-26-2011, 07:54 PM   #1
piranha0522
Drives: '06 Yaris
Want to lower..i'm a noob
Hey all, I want to lower my Yaris a bit this summer, and yes i'm a noob. I have never lowered a vehicle before.
Are lowering springs all I need to lower my Yaris? I thought it would be more complicated than that. I dont have to change my shocks or anything?
Are they easy to install on my own?
I also think im going to get some rims. I dont want there to be too big of a gap between body and rubber, or rubbing. Is 15" or 16" recommended?
Thanks a lot!
piranha0522 is offline   Reply With Quote
Old 02-26-2011, 08:42 PM   #2
This should help you. Yes, it is THAT simple, not hard at all. Wheels are a preference and so are changing the stock shocks. I've been running stock shocks with lowered suspension for two years and no problems in handling or ride. Also, remember that the larger the wheel, the more height you are putting between the ground and lowered car. Of course, lower profile tires would help.
http://www.yarisworld.com/forums/sho...wering+springs
Old 02-27-2011, 12:01 AM   #3
SeriousBlack
SeriousBlack's Avatar
Drives: 2007 Yaris RS HB
Piranha - you really have to ask yourself why you want to lower the car before deciding which set up to go with. Generally, lowering springs are all you need.
There are some great threads on this site with the ratings for various brands. Personally, I think the H&R sport springs for the Yaris give a nice moderate drop with an attractive stance. You also can't go wrong with H&R quality at a pretty reasonable price.
If you are going with lowering springs, it might be an idea to change your shocks/struts to aftermarket units suited to lowered cars. Again, I've found the Tokico HP blues offer a solid, if not somewhat stiff, ride. They are great for the money, though.
Coilovers are great for slamming the car or where you want the option of adjusting ride height (between road and track). Personally, I could not justify the cost as most of my ride is on the street and it would just be overkill for me.
Whichever way you decide to go, I'd suggest you also bear in mind what size rim/tire you envision for your Yaris. Many wide (6.5" +) rims with offsets lower than 40 will result in rubbing problems when your car's lowered. Just something to keep in mind.
Enjoy your ride!
SeriousBlack is offline   Reply With Quote
Old 02-27-2011, 12:50 AM   #4
just come by my house, lol
its so easy, a kid can do it
http://www.yarisworld.com/forums/showthread.php?t=29258
ive run coilovers on the yaris, but im on eibach sportlines and stock shocks....since spring 2010. the ride is comfy, but sporty.
as for rims, keep an eye out on kijiji for used stuff, thats how i pick up all of the rims ive had...
id suggest trd springs as the drop is about 1.5", which looks great, but its not too low to run year-round. wheels/tires for summer, i think 15" are the most comfortable w/ 205-50-15 tires (thats also what i run), but 16" wheels look big while still having a decent amount of rubber on them (205-45-16 is about right)
Old 02-27-2011, 12:55 AM   #5
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
coilovers. done.
Old 02-27-2011, 02:08 AM   #6
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
coilovers. done.
Put the car on a lift, get under it, take a torch and heat your springs. Done.
Sponsored by: Micro Image
http://microimageonline.com
Old 03-06-2011, 09:42 PM   #7
10peep
10peep's Avatar
Drives: 2010 3D LB 5spd
If you actually LIKE your car, do NOT do that.
10peep is offline   Reply With Quote
Old 03-07-2011, 10:36 AM   #8
Imagine
Insert sarcasm here.
Imagine's Avatar
Drives: 2009 Black Pearl Sand 3Dr
I personally prefer the versatility of the coilovers the best. Not a lot more money, the shocks are valved to the springs, so you usually get a good mix of ride quality and sportiness. Plus you have the freedom of putting it at the height that works best for you. Coils and springs, you have one height and you're pretty much stuck. I've owned may different suspension setups and I can tell you I'll opt for coilovers every time.
Imagine is offline   Reply With Quote
Old 03-07-2011, 08:38 PM   #9
Trubin
Trubin's Avatar
Drives: 2009 Toyota Yaris Hatchback
HELP!!!
I am considering to lower the car because I often drive over bridges and near coastal highways . I notice a lot of wind as I ride and get blown from one side of the lane to another. Are lowered springs good Idea? Should i consider a rear sway bar instead?How can I find out how much lower do I need my ride to be? I would also like to enhance my rides aesthetics. 1" inch drop seems unnoticeable, while 1.8" maybe a bit too much, or is it? If I am not planning on putting any body kit or nothing but my mom occasionally likes to economically ride over potholes, Should 1.8"-1.6" Tanabe DF210 suit me or should I go with 1.5" TRD. Which brands are more comfortable?
Trubin is offline   Reply With Quote
Old 03-11-2011, 02:21 AM   #10
SeriousBlack
I think you'll find the TRD's more than enough drop for your commute.
If you want more cost effective options, consider H&R sport springs or Megan springs.
Old 03-11-2011, 02:46 AM   #11
H&R with its progressive rate, is a very very good spring choice.
Sway bar also helps a lot with stability.
Old 02-01-2012, 12:01 PM   #12
yPod09
All black everything.
yPod09's Avatar
Drives: '09 5dr All black.
SeriousBlack, can you post a photo of your car with the H&R's on it. I'm looking at ordering the same set-up, including the Tokico Blues from MI, and just wanted to see them on a 5dr first.
Thank you!
(My set up is 185/60/15...I think I saw on another post you are running 195/50/16).
yPod09 is offline   Reply With Quote
Old 02-01-2012, 02:52 PM   #13
^ Ah, I just PM'ed you. You can ignore; if there are any questions we can answer, let me know. thanks
Old 02-01-2012, 11:51 PM   #14
yPod09
yPod09's Avatar
Thanks Garm, got it.
Never mind SeriousBlack, found some photos. Looks perfect!
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 11:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 07:49 PM
Lower Grill Replacement Idea (feeler) counterfiend Cosmetic Modifications (Exterior/Interior) 7 09-24-2009 09:40 PM
Best MOD for midrange to lower rpm gain. Neen a little more low end grunt. dtbrown Performance Modifications 13 03-29-2009 05:35 PM
What parts do I need to lower a Yaris? tacsnier Cosmetic Modifications (Exterior/Interior) 15 06-18-2007 09:15 PM
