Old 02-27-2011, 11:49 AM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
AFTER 4 years i now have to replace my.....
4 years this april i finally have to replace my windshield wiper blades for my yaris.. besides me buying oil and filter changing it my self and the minor mods the wiper is actually the first actual part that now needs replacing..why oh why!!!!
Old 02-27-2011, 12:05 PM   #2
big lo
big lo's Avatar
Drives: 2007 VIOS
Lol, that's sound right. I changed mine in Oct. Which makes 5 years, that was the last part I over looked, what brand you looking at?
Old 02-27-2011, 12:30 PM   #3
swidd
Drives: Yaris HB
After 4 years I replaced the battery... it didn't really fail, but began to crank for a very long time when extremely cold. New battery installed, and it starts with a "jump".
Old 02-27-2011, 12:39 PM   #4
p123456789
Drives: 07 lb jeep tj
I had to rebuild my transmission when I got it due to leaking input shaft seal which is placed on the inside of the transmission, the clutch howerver had plenty of life left on it.
p123456789 is offline   Reply With Quote
Old 02-27-2011, 02:19 PM   #5
Frankd1
Drives: 2008 RS, 5spd
Do you guys replace the entire wiper blades with after market ones or do these wipers have slide in blades from the dealer?
I thought for some reason that the OEM blades slid out and were replaceable with new rubber inserts....
Frankd1 is offline   Reply With Quote
Old 02-27-2011, 04:11 PM   #6
^ They are. Inserts are dirt cheap compared to whole OEM replacements, or any other aftermarket stuff.
Old 02-27-2011, 06:36 PM   #7
PumpkinSteve
PumpkinSteve's Avatar
Drives: Yaris SR 1.8
I just found that I have to replace my wiper arms, they are completely rusted and have paint flaking off them...damn this UK climate. My wheels are also badly corroded and have finish flaking off, this has only just happened as we had a particularly harsh winter this Christmas.
PumpkinSteve is offline   Reply With Quote
Old 02-27-2011, 06:58 PM   #8
swidd
Drives: Yaris HB
The OEM wipers are so much better than anything in the aftermarket I have ever tried (which is every brand sold at common stores).
Old 02-27-2011, 07:04 PM   #9
marcus
toyota
marcus's Avatar
inserts eh.. didnt know that ..cool..dont know which one to get..
Old 02-27-2011, 11:09 PM   #10
mimelio
Drives: NONE
http://www.brandsport.com/wiblare4.html
mimelio is offline   Reply With Quote
Old 02-28-2011, 01:42 AM   #11
salmonz
salmonz's Avatar
Drives: 07 Yaris Sedan
Replaced so far in 4 years:
Windshield (rocks from highway)
Front bumper (cracked)
Side wheel covers (these scrape easily)
4 factory tires (wore out at 60,000km)
2 front brake pads (down quite a bit)
2 front brake rotors (original started to score)
Wiper blades 2x both sides
Speed sensors both side (due to corrosion)
Right now:
Factory battery - DEAD
Next up:
2 rear brake shoes (getting low)
Transmission oil replacement (required)
Coolant replacement (required)
2 front wheel bearings (for good cause)
2 front axles (appears bent)
1 right front outer tie rod (leaking grease)
1 right sway bar link (left one replaced @ $200 rip)
2 front struts / 2 rear
salmonz is offline   Reply With Quote
Old 02-28-2011, 09:39 AM   #12
marcus
toyota
marcus's Avatar
hows anyones brake pads doing in 78000 km i keep forgetting to check mine..but its manual as well..since i sometimes downshift to slow down rather than using my brakes.
Old 02-28-2011, 09:54 AM   #13
yaris2010RS
yaris2010RS's Avatar
Right now:
Next up:
^ u my friend got a lemon of a yarii.....how many km on ur car? what have u done to it? all extra work i have needed done to my yaris is cuz somehow i messed up and got it covered under warranty
and to OP thats great, i dont know how u did it..... it was raining today and i was noticing that i will prob have to replace my wipers within the next 6 months. my car was a year old as of jan 6th and i now have about 45,000km
better then my moms 01 camry, she eats wipers every 8 months or less. think it has to do with it being still the original windsheild and the surface is getting rough.
Old 02-28-2011, 10:35 AM   #14
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Right now:
Next up:
Who's telling you you need to replace all this stuff?
Old 02-28-2011, 10:38 AM   #15
jambo101
jambo101's Avatar
At 70K Kms mine are 50% all around..probably get the whole job done at 100K
Old 02-28-2011, 10:39 AM   #16
bronsin
bronsin's Avatar
Wife needed new pads at 66k miles. You definately want to look at them once a year after 50k or so. Personally my brake pads (front) go 100k +.
I let the wifes get to 1/32 inch which was cool and got another year out of them.
Old 02-28-2011, 11:56 AM   #17
salmonz
salmonz's Avatar
I'm at 124,000km.
Bad luck - windshield, front bumper, wheel covers
Warranty replaced - speed sensor
Ware/tear - factory tires, wiper blades, pads/rotors/shoes, battery,
Required maintenance - tranny oil (@106,000km), coolant change (@126,000 i believe)
The rest:
1. Sway bar link (would rather spend $10 to get aftermarket so both sides are new), the other side @ $200 was hitting a pot hole that the town paid for, dealer cost for 1 sway bar link is $200Cdn. Aftermarket $"15" for 2.
2. I have front end vibration, did some measurements with the dial indicator and visual inspection of the axles. The axles need replacing (CV joint) and MAYBE the wheel bearings (no noise though).
3. When I was inspecting my Yaris yesterday there was grease leaking from the right outer tie rod.
4. Struts and shock absorbers start to deteriorate after 80,000km. Time is ticking and maybe at 190K km I'll replace them if they start to bounce. But hey, it's on the list. :)
I think the 401 in Toronto is rough on vehicles.
Old 02-28-2011, 12:12 PM   #18
swidd
Drives: Yaris HB
When I drove around Toronto I noticed a lot of cars, even not-so-old, had rusted out bottoms and sideskirts.
24 years of age, AAA forces you to get your own car insurance policy? yarisitis Off-topic / Other Cars / Everything else Discussions 3 01-28-2011 09:37 AM
Man hits 1 MILLION MILES in Ford F-250... in four years!!! Kal-El Off-topic / Other Cars / Everything else Discussions 6 10-30-2010 10:19 AM
Official: MERCURY is DEAD after 71 years. Kal-El Off-topic / Other Cars / Everything else Discussions 15 06-06-2010 01:06 PM
LEDs to replace interior lights: Which ones? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 57 04-28-2010 01:44 PM
Will We Still Love Our Yarii in 10 Years? redyaris General Yaris / Vitz Discussion 28 03-14-2007 12:34 AM
