Old 02-19-2007, 11:14 PM   #1
"G"
Drives: 2007 Yaris Hatch
Hatchback with abs ?
Is this an option ? If so that means the rear discs are rotors right ? Then all one needs is to source these from an abs equipped model.
"G" is offline   Reply With Quote
Old 02-19-2007, 11:15 PM   #2
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
You can have rear drums and still have ABS on all four wheels, technically speaking.
Old 02-19-2007, 11:35 PM   #3
"G"
So yours has drums w/ abs ? Any americans with the same ?
Old 02-19-2007, 11:38 PM   #4
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
yup...
Go4th is offline   Reply With Quote
Old 02-19-2007, 11:44 PM   #5
"G"
^ you have a hatch ?
Old 02-20-2007, 12:43 AM   #6
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
No Yaris has rear disks in the US, regardless of ABS or not.
Old 02-20-2007, 09:16 AM   #7
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
Originally Posted by echo_hrs View Post
I think you mean rear drums...
Cheers
Yea rear drum....
YARIS DOES NOT HAVE REAR DISK!
-- Blen
Old 02-20-2007, 09:20 AM   #8
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by Blenjar View Post
Yea rear drum....
-- Blen
Correction, no Yarii in the U.S. com equipped from the factory with rear Disc Brakes :) You do not know if some one did a rear disc conversion yet, also there are many Yarii not in the US that have Factory rear disc
Old 02-20-2007, 10:37 AM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
i know it's very nice to have rear disk conversion, but.... once you've done it, does that mean you have to source your rear disks each time they are due? or do you stock up on rear disks and pads for future use?
Old 02-20-2007, 12:06 PM   #10
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
The US hatch with ABS has rear drums and front disc.
They work well.
Old 02-20-2007, 12:38 PM   #11
Go4th
Go4th's Avatar
They work well.
yup
Old 02-20-2007, 09:16 PM   #12
"G"
Dam, never seen a car with front abs only.
Old 02-20-2007, 09:30 PM   #13
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
Ok, the ABS system is not only for disc brakes, the whole system is ABS no matter if it is drums or discs. Further info: http://en.wikipedia.org/wiki/Anti-lock_braking_system
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 02-20-2007, 10:17 PM   #14
Go4th
Go4th's Avatar
How long is this going to go on?
Does your liftback have ABS? BensVitz General Yaris / Vitz Discussion 75 05-24-2011 08:11 PM
Possible ABS Issue? JeffRapp DIY / Maintenance / Service 3 01-07-2007 03:43 PM
ABS Virgin!!! yaris-intuit General Yaris / Vitz Discussion 23 11-29-2006 01:49 PM
Yaris Hatchback Clearance Height Ryu General Yaris / Vitz Discussion 7 11-28-2006 02:35 AM
No ABS on Sedan?? hans_fh General Yaris / Vitz Discussion 2 10-12-2006 04:39 PM
