TRIM HUNTER
CEL= P0300-P0304 CODES........
just took the techstream off the car and found i had the 4 following codes:
P0300 P0301 P0302 P0303 P0304 we cleared codes and so far nothing has come back. i found this on youtube and wondered WHO'S CAR IS THIS???? http://www.youtube.com/watch?v=KjZR7...layer_embedded i had almost no gas in car when this happened so i filled up with premium and lets see what happens.....
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
looks like a random misfire code, and miss on cylinders 1-4
if you were out of gas that would throw a misfire code. also, if you filled up and it hasnt come back then you should be good. |
TRIM HUNTER
wasn't out of gas at all! first time was on highway between 75-80 and car just shut down in limp mode for about 30 seconds before allowimg me pedal use again with no CEl. second time came after a 4 day no use and after first turning ignition car refused to stay running and threw this code.....
bad gas? EMF disrupted coils? if its not happenin y worry?
| P2420 and P0441 codes | jkonrath | DIY / Maintenance / Service | 3 | 09-05-2010 09:33 PM |
| Fault Codes P0441, 442, 446 | soloecho2 | DIY / Maintenance / Service | 1 | 04-25-2010 06:21 PM |
