Old 04-12-2011, 02:04 PM   #1
netspec239
YarisCraze
netspec239's Avatar
Drives: 2008 Yaris Type S
CHECK ENGINE !!! Dealer Blames (Oil Control Valve)
Hi All,
I've had an issue with my 2008 Yaris Sedan for a while now and the dealership hasn't been able to determine the issue.
CHRONOLOGICAL PROCESS OF ISSUE:
1. Check Engine Turns On
2. Transmission Disengages (or it seems).
3. The Engine sounds like it's accelerating.
4. Gas pedal stops responding.
5. Your heart almost stops from the scare.
6. You have to pull over and restart the car for it to start working again.
The dealership is trying to tell me that the issue is caused by the (CAMSHAFT TIMING OIL CONTROL VALVE ASSEMBLY). This part is depicted in page LU-14 of the PDF on the following link: http://www.etimago.com/yaris/repairm...ubrication.pdf
The dealership is not totally sure that this is the issue; however, they want me to pay $500 to replace it. This is after replacing the carpet and gas pedal since they originally thought it had a sticky pedal issue (even though the Yaris wasn't part of the recall).
Could someone please shed some light on this matter. I don't plan to reconstruct the whole car to find the issue. At the dealership's labor rate it may be cheaper to buy a new brand new Yaris.
netspec239 is offline   Reply With Quote
Old 04-12-2011, 02:09 PM   #2
check the CEL code...
Old 04-12-2011, 02:12 PM   #3
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
OCV brand new is about 95.00 and takes a whole 15 minutes to install(on my 07 anyways)...
I had a CEL and a P0011 code so I went ahead and bought a new OCV from Toyota....CEL is gone. I was getting a random high rev when I would shift into N(manual trans). I assumed it was the CPU playing with the timing since the OCV was going out, but that was just a guess.
Old 04-12-2011, 06:00 PM   #4
netspec239
YarisCraze
netspec239's Avatar
The diagnostics code is P0011. I'm going to replace the Oil Control Valve (OCV) (Manufacturer Part #: 1533021011) since it's only $75 dollars and go from there. The part is available at: http://www.toyotapartszone.com/oem/t...330-21011.html
Thank you both for the good info. I'll make sure to post my results in order to save other people some time with this issue. It has really been a pain in the rear. It's 5 O'clock! Thanks Again!
Old 04-12-2011, 06:18 PM   #5
mazilla
advocatus diaboli
mazilla's Avatar
It's a piece of cake fix. Disconnect neg battery cable. Drop the alternator bracket and unbolt/unplug the old OCV, you'll need to give it a little twist then it will slide right out. New one goes in the same way, bolt up, re bolt alternator bracket....done.
With that code I believe there was only two real options, OCV or camshaft gear...thank goodness it wasn't camshaft gear.
Old 04-12-2011, 07:28 PM   #6
end user
GRO H2O
Drives: Yaris
EDIT: Meh should have read the first post properly.
end user is offline   Reply With Quote
Old 04-13-2011, 07:26 PM   #7
07 flint mica
Drives: 07 sedan.04 2500hd,10 mazda3
This a common Toyota issue with most models. The oil control valve gets clogged with sludge due to lack of maintenance.
07 flint mica is offline   Reply With Quote
Old 04-13-2011, 09:22 PM   #8
thepartsmancometh
Drives: '08 LB, '07 WRX
yep, what he said. we see this quite a bit, and most of the time the motor is sludged something terrible! keep that oil changed folks, its the cheapest insurance
thepartsmancometh is offline   Reply With Quote
Old 07-11-2011, 02:08 PM   #9
aruester
Drives: 2009 Yaris 3D
The site says this only fits up to 2008. Does anyone know if it fits a 2009?
aruester is offline   Reply With Quote
Old 07-11-2011, 08:21 PM   #10
thepartsmancometh
holy old thread batman!
as far as I know, they wouldn't have changed this between model years as the engine is the same. If I recall, I will check at work tomorrow (I don't have parts cataloging at home)
Old 07-11-2011, 10:43 PM   #11
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
06+UP sedan or H/B are all the same part number
OTA'sTOY is offline   Reply With Quote
Old 07-11-2011, 11:12 PM   #12
auxmike
auxmike's Avatar
Is this a real common failure part that's worth ordering and tucking away for a rainy day? Can they be removed and cleaned?
Old 07-12-2011, 12:52 AM   #13
mazilla
advocatus diaboli
mazilla's Avatar
Not really, it doesn't normally effect the engine to the point that you couldn't drive it. I drove on that CEL for over a month without noticing any difference, just the lack of the CEL after I replaced it.
-Type 07 FFL-
My odometer 03/11
Old 08-11-2018, 04:31 AM   #14
ricardo-cr23
Drives: Toyota Yaris 2007 1.5L V4
Guys do you have a way of testing the oil control valve? I think that I accidentally broke it when I was replacing the belt :(
ricardo-cr23 is offline   Reply With Quote
Old 08-11-2018, 08:52 AM   #15
tmontague
tmontague's Avatar
Not anyway that I know of other than checking which cel was triggered. I have a spare one from when I junked my echo I can sell you
Old 08-11-2018, 04:31 PM   #16
ricardo-cr23
Thanks for the offer but I live outside US so it is a little bit complicated, besides having that part bad can cause serious problems in your engine. Toyota OEM new here is $90 so I'll have to buy it there.
Cheers!
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-13-2010 12:47 AM
Question About Engine Oil Kaotic Lazagna Off-topic / Other Cars / Everything else Discussions 21 08-29-2009 04:08 AM
WTB: Oil Control Valve/VVT Valve bdc87 Willing to Buy by private party 4 05-22-2009 09:15 PM
