Old 04-14-2011, 08:18 AM   #1
bronsin
bronsin's Avatar
Is There A Fix For Auto Trans Wont Shift Into 4th Until Warm?
Well, is there?
Old 04-14-2011, 09:59 AM   #2
TRDMarty
There is ONLY ONE fix.
Let it WARM UP.
For the light in my 08 Auto HatchBack to turn off it takes 4 minutes total.
If you raise the RPM's to 2000 and hold it, the time is only 2 minutes.
The engine does have to generate heat then transfer that heat to the sensors to tell the computer, HEY, I'm warm now. Result is, normal operating conditions, use all gears.
I did a SIMPLE time study & these are the numbers.
Do this and your tranny will shift to 4th gear.
Just let it warm up or just plan your trips 4 minutes earlier. Your Yaris will love you for it.
Old 04-14-2011, 10:37 AM   #3
bronsin
bronsin's Avatar
Well in order to test that theory you would need a 1 quart gas tank. Warm it up and drive it a mile and see how much gas was burned. Then DONT warm it up and drive a mile and measure the gas consumed. The problem with warming it up is you are BURNING GAS AND NOT MOVING!
One of them is more fuel efficient. But which?
Old 04-14-2011, 10:41 AM   #4
nemelek
DWEED
nemelek's Avatar
I find it only takes a block or 2 to warm up. Summer it nover comes on.
Old 04-14-2011, 12:25 PM   #5
Hershey
Our 2008 sedan with the automatic starts out in 2nd for about 1 minute then does to 3rd and then to overdrive in about 1 and 1/4 miles . It's supposed to start in 3rd , then go to overdrive not long after the operating temp light goes out . Anyone else have the same issue ?
Old 04-14-2011, 02:35 PM   #6
Brian
Brian's Avatar
At 90° it will shift into 2nd
At 112° it will shift into 3rd
At 130° the light goes out
And at 139° it will shift into Drive
Old 04-14-2011, 02:40 PM   #7
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Do NOT idle to warm up. You're getting 0MPG when you idle.
Old 04-14-2011, 02:54 PM   #8
Hershey
We don't idle , start up and go .
Old 04-14-2011, 02:58 PM   #9
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
doesn't ALL automatic toyota tranny's do this? my 91 celica gt does it......
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 04-14-2011, 04:30 PM   #10
markitect
Drives: Yaris
I just get in and go. And you can go 80 in 3rd(which warms it up real quick). So I've never seen it as a problem.
markitect is offline   Reply With Quote
Old 04-14-2011, 05:32 PM   #11
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
My 06 Rav 4 and 2004 4Runner didn't.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 04-14-2011, 07:45 PM   #12
41magmag41
Drives: Loaded 2007 mica silver sedan
Well, is there?
It's an emission thing for the computer. Why fight it, all yaris automatics do it. I find that it takes me about 2 miles and reaching a temp of 137 degrees and it slips right into 4th. I'm still getting 38.5 to 41.5 mpg on her and drive the interstate to work for 28 miles at speeds around 75. Not bad.
I would live with it and not push the car as it's designed that way.
41magmag41 is offline   Reply With Quote
Old 04-15-2011, 04:54 AM   #13
bronsin
bronsin's Avatar
But you are burning MORE gas when doing that. I dont drive on the highway were I can get 40 mpg. I just drive 6.5 miles to work and back everyday. A mile or two of that is being stuck in 3rd gear.This winter with winter crap gas and temps in the teens and 20s in the morning, I got lows of 28 mpg. And I never exceeded 45 mph. With a manual you can be in 5th gear ANYTIME you want. So dont try to tell me it HAS TO be that way because it doesnt.
Old 04-15-2011, 10:33 AM   #14
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
05 RAV I HAD DID.......
Old 04-15-2011, 11:53 AM   #15
Hershey
" A mile or two of that is being stuck in 3rd gear. "
Same here , usually 1 and 1/2 miles in 3rd when cold . Then a few seconds after the operating temp light goes out the 4th gear ( overdrive ) kicks in .
Old 04-15-2011, 12:02 PM   #16
Hershey
" Do NOT idle to warm up. You're getting 0MPG when you idle. "
You'd be amazed how much fuel is consumed when letting the car idle to warm up . THe ECO-METER we have verifies that . Also , the fuel can get into your engine oil causing fuel dilution . Making your oil less protective . States this with the papers that came with the U.O.A. kit from BLACKSTONE labs for preparation to send in the oil sample . Best to drive the car for about 20 minutes ( start and go ) and not to let it idle to operating temperature before taking a sample so not to have excessive fuel in oil for the analysis .
Old 04-15-2011, 12:42 PM   #17
bronsin
bronsin's Avatar
Fuel dilution happened in carbed engines that idled because the mixture was rich. With FI that is not the case. The mixture is correct.
You still have the problem of increased warmup time however if you idle. And of course if you aint moving youre losing.
Im hoping Scotts reisitor mod will prove feasable. I got 28 mpg at times this winter driving 6.5 miles to work.
Proof is in the pudding. Either it gets better with the mod or it doesnt.
But Im wondering if the 3rd gear thing is to warm up the TRANSMISSION not the engine?
Old 04-15-2011, 07:02 PM   #18
41magmag41
According to toyota designers yes it does. you should have bought a manual if you want to be in high gear in a hurry. Live with it or trade it for a manual.
Better yet take public transportation and you save a load of gas and we save a load of gas.
Stick shift at 'N' at stop lights(Auto trans) curtqn Fuel Economy Forum 14 02-25-2010 07:04 PM
Back to school sale Short shifter, Shift Knob, EVERYTHING is on sale! TWM Performance TWM Performance 13 09-29-2009 11:55 AM
TWM Performance weighted shift knobs on sale! TWM Performance TWM Performance 5 06-30-2009 10:58 AM
October sale on TWM Performance shift knobs! TWM Performance TWM Performance 1 10-31-2008 06:01 PM
