Old 04-15-2011, 06:10 PM   #19
bronsin
bronsin's Avatar
Originally Posted by 41magmag41 View Post
According to toyota designers yes it does. you should have bought a manual if you want to be in high gear in a hurry. Live with it or trade it for a manual.
Better yet take public transportation and you save a load of gas and we save a load of gas.
If the mod works I will have my cake and eat it too!
Old 04-15-2011, 09:49 PM   #20
41magmag41
Drives: Loaded 2007 mica silver sedan
Eat the cake and have toyota laugh at you if you try to get work done under warranty, providing the car is still under warranty, because you mod it. m
41magmag41 is offline   Reply With Quote
Old 04-16-2011, 12:19 AM   #21
SAV912
Pirate Yaaaaris
SAV912's Avatar
Isn't 3rd gear in the ATX at 45 MPH around 2500 or so RPM? Hardly WASTING fuel.
Truth is, Toyota designed it that way since it's such a small engine. The quicker it gets to operating temp, the quicker it reaches the most efficient temperature to operate at thus burning less fuel. There are many, many more factors you should be looking at if you're getting shit mileage in the winter (IE 28 MPG) before blaming it on the ATX not shifting into 4th within a mile or two of starting up. I guarantee you that mile of being stuck in 3rd will not net you the increase from 28 MPG to whatever you think you should be getting. Blame winter blend gas, underinflated or winter spec tires, or your short commute before you go modifying the electronics in the ATX.
Solution:
1. Trade for manual, although lugging the engine when cold won't do you any favors in regard to fuel efficiency.
2. Leave New Jersey.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 04-16-2011, 06:48 AM   #22
41magmag41
Solution:
-C
YAY plus one for some common sense. Econo cars why screw with them.
Old 04-16-2011, 12:04 PM   #23
bronsin
bronsin's Avatar
I have the home made cruise control for $10 installed. They have never detected it. What makes you think theyre going to know about a modifyed coolant temperature sensor? They are too busy looking for power pulleys, aftermarket suspensions and turbos.
Let me guess. You guys are sitting on your couch all day playing video games.
Old 04-16-2011, 12:22 PM   #24
41magmag41
actually no wise butt, driving a heavy dump all week and only check this in the evening or if I'm not working Saturday. butt enjoy your need for speed in the wee early mornings while your car tries to do what it's programed to do.
Old 04-16-2011, 02:08 PM   #25
bronsin
bronsin's Avatar
-C
So...put your money where your mouth is and do me a little favor. Drive normally in 4th gear for a tank of gas and record your mileage. Probably you already know what your mileage is. Great! Now drive a tank of gas in 3rd gear. I would like to know what difference it makes. I would do it myself but thought you would be eager to prove me wrong.
Old 04-16-2011, 04:19 PM   #26
SAV912
Pirate Yaaaaris
SAV912's Avatar
No, I'm smart and bought the proper transmission (manual) for my driving style. I'm not the one starting with one thing and trying to turn it into another.
You asked a question, and you got an answer. It's nobody else's problem but your own if you're not satisfied with it. For what it's worth, I'm not in 5th until 40+ MPH anyway. I don't see why you're pissing and moaning about an automatic doing what it's suppose to do at low speeds and low temp/op conditions. The quicker the engine reaches optimal temp, the quicker it gets to max efficiency. Modifying the programming to get into 4th as quick as possible under cold conditions will result in it taking LONGER to reach optimal temp, and thus burning more fuel anyway, defeating the entire purpose. You got 28 MPG for a variety of other reasons. Not because you can't get into 4th for one mile of your seven mile commute.
-C
Georgia Bulldogs!
Old 04-16-2011, 04:27 PM   #27
41magmag41
-C
Again Plus 1 for some common sense.
Old 04-16-2011, 05:13 PM   #28
MadMax
MadMax's Avatar
There is no "fix" as there's nothing wrong with your transmission! It was designed to stay out of fourth gear until the engine has reached a certain operating temperature. It is for your engine's benefit and it would be detrimental to try to override the function.
Old 04-16-2011, 05:51 PM   #29
bronsin
bronsin's Avatar
Why would it be detrimental to the engine? A manual can be shifted into fifth immediately. Are people with manual transmissions having problems with their engines.
Old 04-16-2011, 05:54 PM   #30
bronsin
bronsin's Avatar
-C
Well maybe I can get YOU to put your money where your mouth is. Drive for a tank of gas in fourth gear of your manual trnasmission and tell us what mileage you get.
We trust you to tell the truth!
If this mod proves possible I will post my results also. Then we will see what is what.
Old 04-16-2011, 06:44 PM   #31
SAV912
Pirate Yaaaaris
SAV912's Avatar
Dude, you're just not making too much sense. People with manuals such as myself CAN get into 5th gear right away with the cold lamp activated, but it is certainly not beneficial in regards to fuel economy. Since the ATX does the shifting for you, it automatically (imagine that?) figures the most optimal gear to be in under the given conditions. And in the conditions under a cold start, it is optimal to get to optimal temp as quick as possible, hence locking out overdrive.
I'll tell you the truth right now. That's not the same situation as what you're proposing. You don't take off from stops in 4th gear of your ATX, why should I do it with an MTX and post the findings? You also don't know my driving conditions or my commute. From what you posted, you'd actually be pretty alright cruising in 4th gear of the MTX at 40 MPH. If you had my commute which involves several miles down I-95 in 80 MPH flow, then I'd be first in line to tell you that you're silly for staying in 4th at that speed, but that wouldn't be applicable either as by the time you reach the highway from where I live, your ATX would've warmed up and you'd be fine. Drop to overdrive immediately from a cold start, and that may no longer be the case, thus keeping the engine colder longer and not optimally efficient thus robbing you of more fuel economy than if you let the transmission do it's job. I don't know what better way to explain it to you, but go ahead and for shits and giggles, do your mod. Report back the findings. You're already sitting right at the EPA City rating for the Yaris, so I don't know what more you expect to find given your commute, conditions, and driving style.
It's almost comical how some of the fuel economy guys think they know better than a corporation full of engineers.
-C
Georgia Bulldogs!
Old 04-16-2011, 08:32 PM   #32
auxmike
auxmike's Avatar
I get a pretty steady 30mpg on my 20mi. each way commute to work. That's winter numbers. Hoping to do better now that weather's clearing up. Mostly stop and go with mabye a 1/2 mi. of highway driving during the route....
People who work right around the corner from work (I never have!) will never realise the full benefits of the Yaris' ownership experience.....
Old 04-16-2011, 10:23 PM   #33
MadMax
MadMax's Avatar
Not yet, but if they're shifting into fifth gear with a cold engine they might be doing unknown damage. It's well known that it's not good to go into OD when an engine is cold, and our little Yaris is smart enough to prevent the transmission from doing so. Why people want to override this excellent feature is beyond me, I guess they think they are smarter than the engineers who designed and built it!
Old 04-17-2011, 09:19 AM   #34
bronsin
bronsin's Avatar
I work with engineers who design proto type electronics for miitary and space applications. They design it I build it. Once we had 60 days to buiild the 150 circuit boards that went into a data recorder for a satilite. They put a software engineer in charge of the machine that built the boards. Under his direction they built 4 or 5 boards A WEEK. Because we would never get done in a year at that rate they put me running the machine on second shift. My first night on the job I built 14 boards all by myself. QC went apeshit in the morning. They thought they were all screwedup. Wrong.
When we went to surface mount electronic in 1994 the freaking genius engineers degreed we could not add flux to the parts before soldering. There is flux inside a hollow core and they said that was specifically designed by engineers whose shit does not stink to be all that was required. We assemblers were agast and just added it anyways. When some of us were punished for that we came to the realization we could screw them over by doing what they told us to do. The quality of the work was so bad they recinded their edit in a month.
That is the side of engineers you never hear about.
Old 04-17-2011, 11:48 PM   #35
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
I've never been quite sure *why* it's designed this way. Whether its a cold engine drivability thing, an emissions thing, a fuel economy thing, or an engine wear thing.
But it makes no sense to me that a higher engine speed is going to result in faster warm up. Assuming the driver is calling for the same road speeds and acceleration, the 3rd gear scenario is going to have a lower torque and faster rpm. The 4th gear scenario is going to have higher torque and lower rpm. But the overall power (work / second, or force x distance / time) is going to be the same in each case.
My bet is that the lockouts are supposed to improve cold engine drivability.
-Steve
sbergman27 is offline   Reply With Quote
Old 04-17-2011, 11:57 PM   #36
sbergman27
sbergman27's Avatar
If I had a nickel for every "well known" bit of wisdom I've heard that turned out to be totally baseless, I'd be rich. So with my skeptic's hat on, I'll ask "how do we know this?". What evidence (as opposed to hearsay) can we point to?
I suppose what it boils down to is a assertion that a cold engines handle higher RPMs better than they handle higher torque, with respect to wear.
My Yaris is A/T. But my Chevy Sprint ER is a 5 spd manual. When cold, I shift at about the same points as I do when warmed up, getting into 5th at about 45mph. It would be interesting to know for sure what strategy minimizes wear.
-Steve
Stick shift at 'N' at stop lights(Auto trans) curtqn Fuel Economy Forum 14 02-25-2010 06:04 PM
Back to school sale Short shifter, Shift Knob, EVERYTHING is on sale! TWM Performance TWM Performance 13 09-29-2009 10:55 AM
TWM Performance weighted shift knobs on sale! TWM Performance TWM Performance 5 06-30-2009 09:58 AM
October sale on TWM Performance shift knobs! TWM Performance TWM Performance 1 10-31-2008 05:01 PM
