Old 04-14-2011, 06:26 PM   #19
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Originally Posted by cdydjded View Post
Really? How exactly? How can you set the psi to be 0?
My turbo is internally gated. I control my boost lvl via a counter spring. I can set it as low as I want actually or as high.
Old 04-14-2011, 07:52 PM   #20
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
You can disconnect your wastegate acuator rod... Result is 0psi...
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 04-16-2011, 05:07 AM   #21
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Originally Posted by Bluevitz-rs View Post
Whatever man, sorry I even started this thread. I obviously have NO clue about how an internal combustion engine works, or turbo, or pressure valves, or physics for that matter.
Peace. I'm done with this thread.
Jamie you don't have to be sorry for this thread ! You opened this thread surely to get opinions from us and it always happens that people do not fully agree with our theories.
I cannot say how this 0 psi turbo setup could be and I am curious if this can be done infact with positive results although it's a shame putting a considerable amount of money and having no boost at all!
Although I am sure this can be done and with correct calculations you can gain something from it for sure. The only problem is Money wasted vs Power/Torque gains
Parmas is offline   Reply With Quote
Old 04-16-2011, 08:59 AM   #22
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
All you'd have to do is take an existing system, like the zage kit sold at Micro Image, modify the spring in the waste-gate and add an electronic boost controller. It doesn't mean you're locked into not using boost.
I just thought up the idea from guys using the supercharger that can run with the clutch turned off to save gas. It's just that a turbo is more efficient on a small displacement engine.
Old 04-16-2011, 12:46 PM   #23
Is anyone going to answer post 25?
Old 04-16-2011, 02:04 PM   #24
johnny_vitz
How do you make more power or torque without any boost though?
To attempt to answer cali's Q - I've never heard or seen any automotive application with this set-up, they all make boost
Although, with that set-up, you could use your controller to only run say 3 pounds and be safe for your engine
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 04-16-2011, 03:19 PM   #25
Yoda
Yoda's Avatar
Your car is still in vacuum @wot so 0 psi is more than what the engine would under normal conditions. Only way to bring you n/a car close to it is to free up all the restrictions in the intake system.
Old 04-16-2011, 07:46 PM   #26
johnny_vitz
Ok, i've never measured myself, but isn't it supposed to be only 1 or 2 in. vac (very close to 0) @WOT? I could see picking up a tiny bit, but nothing worth the money you would pay for a turbo kit.
We need a guinea pig...
Old 04-16-2011, 09:56 PM   #27
Focus_Sh1ft
Focus_Sh1ft's Avatar
cdydjded, you answered it yourself... This method would work perfectly if there is enough flow.
It's a cool idea but definitely not worth the hassle or cost.
Old 04-16-2011, 10:28 PM   #28
turboecho2005
If your wastegate is accessible it shouldnt take more then 5 minutes to pull the pin holding the arm.
Old 04-23-2011, 07:25 PM   #29
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Blue vitz, it is possible to do as you have suggested, I can think of numerous ways to do it. Restrictors on the inlet to limit air flow and boost, soft wastegate springs as you have suggested, pressure activated solenoids to bleed excess boost (may cause emissions problems though). All though have down sides and require more thought so that you could obtain a very low boost turbo setup with minimal losses at high revs.
rob323 is offline   Reply With Quote
Old 05-23-2011, 11:57 PM   #30
Viperoni
ding ding ding
I like the idea Blue, but there's no way I, personally, could keep a car at 0 psi boost when it could do more :D
2006 Saturn Ion Redline
Old 05-24-2011, 12:08 AM   #31
...I like Ovaltine
Oil Pressure problem... Suspecting Turbo issue Parmas DIY / Maintenance / Service 16 12-13-2010 05:23 AM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 11:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 12:59 PM
