Old 04-06-2011, 12:09 PM   #739
Jason@SportsCar
Originally Posted by Bluevitz-rs View Post
Is it just pictures or is there an article in there too?
There are four pages talking about GT5 and the Yaris Club Sport Challenge - which used the other two Yaris race cars (#98 & #20), including details on the cars. There is no coverage of the HP car (#99), because we did not let the press play with it, only the guys from Toyota, JGR and Sony got to drive it. Lots of pics of all three.
Old 04-06-2011, 01:08 PM   #740
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Nice. Might have to pick up a copy then.
Old 04-06-2011, 08:08 PM   #741
Jason@SportsCar
The May 2011 issue of SportsCar magazine, featuring the second installment of the Yaris project, just hit my desk... SCCA members should have it in the next 5-10 days.
Old 04-07-2011, 01:06 PM   #742
SailDesign
Drives: .
Cool!
Old 04-07-2011, 05:37 PM   #743
Astroman
Modded Moderator
Astroman's Avatar
Where might non-members pick up a copy?
Old 04-07-2011, 05:56 PM   #744
Jason@SportsCar
You cant. Membership has its benefits.
You should be able to order one via our website, once it has become a "back issue": http://www.sportscarmag.com/index.asp
Old 04-17-2011, 04:11 PM   #745
Jason@SportsCar
So I decided to kill some time today by replacing the front subframe assembly - A arms, brakes, hubs etc. The cool thing I found is that the stock front bar on our hatch is 24mm (blue dot), and the one on our spare subframe (that came out of a sedan) is 23mm (purple dot). This smaller front bar should help the car rotate.
Old 04-17-2011, 09:04 PM   #746
I'm curious to know how softening the front will help rotation. Can you explain it so us noobs get it?
Old 04-17-2011, 10:28 PM   #747
Jason@SportsCar
A swaybar transfers grip to the opposite end of the car. When you put a big rear bar on you force weight to the front - this can usually be seen on a fwd car when the inside rear tire is in the air. The car weighs X, and now the other three tires are carrying this weight.
On a rwd car a big front bar can be used to try and lift the inside front, this forces weight to the rear, helping acceleration off of the corner.
Picking up a tire is the extreme, but even when this does not happen the bar is always trying to lift the inside tire.
Using a smaller front bar will help keep the inside front tire in contact with the road, and transfer less weight to the rear. The car thinks the rear bar is now bigger. And I have stiff enough springs that it still wont roll excessively.
A smaller front bar is a common mod on a stock class fwd car, it is the only bar you can change, and it really helps a car with an open diff put down power.
A small bar can hurt in slaloms, but you can get that back with more rebound in your shocks.
Old 04-18-2011, 10:45 AM   #748
loren used to disconnect his front bar for auto-x, iirc
Old 04-18-2011, 12:44 PM   #749
Jason@SportsCar
24mm bar
23mm bar
Old 04-18-2011, 10:58 PM   #750
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
this is awesome info to know.. thanks jason
Old 04-25-2011, 12:50 PM   #751
Jason@SportsCar
BFGoodrich Tires Super Tour
This coming weekend (April 30-May 1) is the Cal Club SCCA Double National and BFGoodrich Tires Super Tour at Buttonwillow Raceway Park.
Saturday is a standard National Club race, but on Sunday things get turned up a notch thanks to BFG. The Super Tour is like a traveling version of the National Championship Runoffs - it features live timing and scoring (via the web), enhanced race coverage (both on site and in publication), and the most important part, the champagne shower on the podium.
We thought we might get as many as eight HP cars, but the Honda Fit is currently MIA, and one of the front runners from Norcal had to pull out at the last minute. It should still be an exciting race, Gary Wittman (the Austin Healey I was trading paint with at Willow Springs) will be there - and both of us have been working in the garage to find more speed. There are a number of other British roadsters, and Cory Markos in his Honda Civic. Its going to be fun.
If you can't make it out follow the link at scca.com for live scoring on Sunday. We are race group 4, and should be on track around 1:50pm.
http://www.scca.com/contentpage.aspx?content=144
Old 04-25-2011, 02:12 PM   #752
ilikerice
ilikerice's Avatar
will be there via web, hopefully. good luck
Old 04-28-2011, 12:11 PM   #753
Jason@SportsCar
These are supposed to be the timing links for this weekend. I don't know if they will be active on Sat, but they will be on Sun.
SOUTHERN PACIFIC SUPER TOUR
BUTTONWILLOW RACEWAY PARK
LIVE TIMING
Live Timing & Notes: http://www.scca.com/sccalive
Live Timing Only: http://www.livetimin.../scca/supertour
Mobile Devices: http://www.livetimin...ertour/html.asp
Web Devices: http://www.livetimin...pertour/wap.asp
Old 04-28-2011, 12:28 PM   #754
Jason@SportsCar
Took yesterday off to finish up a few details for the upcoming weekend... Purged more of the unneeded wiring harness, set the alignment and installed some brake cooling ducts.
We have never had an issue with the brakes, but the 13" wheels make for such a tight fit (I literally can not use a tape weight on the inside of the wheel, the caliper will hit it), and it everything is getting hotter. I am concerned both about brake temps, and the seal material in the three-piece wheels.
I did not want to open another path for air into the front of the car, so I squeezed the hoses into the grill opening. I would have liked to run the hose all the way to the caliper, but again the small wheel/tire package made this impossible - there is just to much going on with the CV boot, strut and tire clearance. So I attached the end of the hose to the swaybar link. When the suspension is at static ride height the hose lines up just behind the caliper - the suspension can move up and down freely, and the hose stays in the same location.
It's not as good as feeding the air right on to the brakes, but I am happy to have some airflow in the general area, it should help keep all the parts happier.
Old 04-28-2011, 01:44 PM   #755
This looks like it will work pretty well. Does squeezing the hoses restrict airflow? Can you have them terminate right behind that grill? Does that grill have to be there?
Old 04-28-2011, 05:22 PM   #756
Jason@SportsCar
I tried to squeeze them as little as possible, which is why the grill is a little deformed in that area, but the volume should be the same.
If I would have put them behind the grill, which was my original plan, the grill would have blocked some of the tube.
The front bumper has to "resemble" the stock one, so I would say that it does need to have the beams.
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
