Old 04-20-2011, 01:58 AM   #1
Yaris4L1fe
Drives: 2010 Yaris Sedan
tein S tech Spring question?
just wanted to make sure the Tien S tech Spring model# NPC91L which is meant for the 07+ Yaris 3drs will work w/ my 2010 Yaris Sedan? I believe its suppose to be a 1.9 inch drop but considering my cars a sedan what do you guys think will be the end result in the drop w/ my heavier sedan? Will I also need to remove my wiper assembly like ive read in the DIY section since mines a sedan? Thanks
Yaris4L1fe is offline   Reply With Quote
Old 04-20-2011, 02:20 AM   #2
First thing's first. The sedan is the lighter of the three Yarii. However, something about it makes it have a lower drop on the same set of springs.
Second, it'll fit. I'm running the S.Tech's. Drop is approximately 2.1" Here what mine looks like on 16" rims with 205/45/16 tires.
Old 04-20-2011, 02:28 AM   #3
Oh, I have coil spacers/lifter in the rear, so it's raised about 1/2".
Old 04-20-2011, 12:30 PM   #4
Yaris4L1fe
Thanks for the response and the pic's, looks nice!!!
I believe tho that the 2.1 drop is for the S tech Springs made for the 5 door, the 3dr Stech springs are suppposebly a 1.9 inch drop! Wondering if there will be a prob using the 3dr springs on my sedan if itll be more of a drop or less of a drop... Did you have to remove you're wipers when you were doing your spring install? Thanks again!
Old 04-20-2011, 01:04 PM   #5
The box says "3-door only". lol. There's no difference. Also, trust me, the sedan drops like the 5-door, not sure why since the sedan is lighter. I wasn't that knowledgeable when my suspension was installed, but I believe the cowl was removed. Since then, I've became more knowledgeable. lol. I'm installing suspension parts on Si's now. hahahaha
Old 04-20-2011, 01:06 PM   #6
This was done back in the beginning of 07, so that's why my memory is a little fuzzy. hahaha.
Old 04-20-2011, 07:23 PM   #7
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
^ hey how does it ride?
i've been looking at them...you still on stock dampers??
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 04-20-2011, 09:37 PM   #8
It rides okay. I have the TRD Sportivo shocks. My family and friends (who are not into cars) hate the ride tho. They find it too "bouncy" while I say it could be a little stiffer/firmer. hahahaha
Need your help installing Tein Basic coilovers for rear canot get spring seated DeathBeard Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-01-2010 11:46 AM
Question about cutting the rear spring perches YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 07-20-2010 10:22 PM
For the TEIN S tech users any sagging issues? marcus Performance Modifications 7 01-28-2010 04:06 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
