Old 04-17-2011, 10:03 PM   #397
Hopefully this will help prevent the manafold from cracking again.
Did you put on the replacement manifold I sent you?
Old 04-18-2011, 10:57 AM   #398
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
My previous set up used a 1.5mm restrictor that came with my oil line. I thought it was needed to maintain proper oil pressure in the engine. My turbo was trashed after 4 months. More recently I did a lot of reading on Garretts web sight and they say no restrictor is needed unless you have so much oil pressure its leaking through the seals into the intake or exhaust. I looked inside my turbo and it looks to have its own restrictor built in. Its bigger then 1.5mm, mabe 3mm. So far everything going well. And yes I am still using a extra spring to pull my wastegate open at a lower pressure. i still need to buy some lager injectors soon. Mabe then run at 8-9 psi
pimp my yaris is offline   Reply With Quote
Old 04-18-2011, 10:58 AM   #399
pimp my yaris
C'est la vie
Yes
Old 04-18-2011, 03:41 PM   #400
Focus_Sh1ft
Focus_Sh1ft's Avatar
Awww yeah
Old 04-20-2011, 06:16 PM   #401
pimp my yaris
C'est la vie
Ordered some used 2azfe injectors today. Looking forward to doing some more tuning and mabe a dyno run while its still cold outside. I saw no noticable difference in afr using 1zz injectors from a 99 corolla.
Old 04-22-2011, 04:05 AM   #402
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I am running 1mm restrictor in my GT2560R turbo as recommended by Garrett.
Looking from the oil feed you can see a 3mm restrictor but that is not the proper restrictor to use.
Parmas is offline   Reply With Quote
Old 04-22-2011, 09:58 AM   #403
pimp my yaris
C'est la vie
I believe the 2560r is a ball bearing turbo, but for a journal bearing turbo like mine, Garrett recomends no restrictor.
Old 04-22-2011, 05:56 PM   #404
Parmas
Parmas's Avatar
I didn't knew yours was not ball bearing. If so then you should not restrict the oil feed line.
Do you know what oil pressure you have at the turbo feed line?
Old 04-23-2011, 09:55 AM   #405
pimp my yaris
C'est la vie
No, but its a 4an line so there should be plenty of oil flow.
Old 04-23-2011, 11:08 AM   #406
pimp my yaris
C'est la vie
Yesterday I installed 2azfe injectors from a 08 scion TC. Then spent about an hour driving around and retuning with the AEM FIC. Got it running great and may only need some slight tweeking in the future. I first tryed using my previous map and changed the injector size in the FIC software. That did not work so well, so I had to start from scratch making a new map. The stock injectors could not keep up at high rpm. Now I need a dyno run soon.
Old 04-23-2011, 10:07 PM   #407
Focus_Sh1ft
^ Just be ready for super rich AFRs next winter. The ECU will be increasing the duty cycle for cold weather compensation and it's going to be expecting 200ish cc injectors and tCs are what, 360?
Old 04-23-2011, 11:20 PM   #408
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
yes, dyno run soon please
Old 04-24-2011, 10:11 AM   #409
pimp my yaris
C'est la vie
Oh ya. On my first start up the car would barely run. My wide band was pegged at 10:1. Most of my new fuel map is pulling duty cycle back with negative percentages. I am running positive percentages in high boost. The FIC actually zeros out (no intervention) at about 2 psi of boost. At idle its negative 27%
Old 04-24-2011, 08:01 PM   #410
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
how is your timing? i can send you the tune i got if ya want
Old 04-24-2011, 08:48 PM   #411
cdydjded
Drives: Yaris LB Turbo
Months ago I said exactly what you are going through with the TC injectors. They are too big for the factory ECU to handle. I said you would have to pull fuel. I hope the person who thought I didnt know what I was talking about reads your post and admits they were completely wrong.
Old 04-24-2011, 10:14 PM   #412
Focus_Sh1ft
^ Who was that? It's not exactly a hard concept to grasp...
Anyways, I could have sworn the FIC causes hesitation at 0 and below in its maps. So pulling fuel actually works? That means I can stop skewing the MAF!
Old 04-25-2011, 04:23 AM   #413
Parmas
Parmas's Avatar
I think you must precise more this post when saying " I am running positive percentages in high boost". How much positive and how much boost?
Running low AFRs are not very good to the engine. Excess fuel tend to mix with engine oil and you can see it dirty after 2 runs already. Running dirty oil mixed with fuel tend to make flash marks on the cylinder bores due too low lubrication to the piston rings. Also turbo bearings tend to fail earlier because of this. I am mentioning this from experience so prevent running the engine like this.
Do you have an upgraded fuel pressure regulator? With the regulator you can reduce fuel pressure and equalizing fuel ratios (although I don't know how the stock ecu reacts having it installed)
Old 04-25-2011, 07:01 PM   #414
pimp my yaris
C'est la vie
After tuning I am idling at 13.5 to 14:1 afr with the engine warm. When under full throttle my map maintains about 11.5:1 afr. So far its running great and the engine runs very smooth. And Focus, about that hesitation under acceleration I am almost sure its caused by the ignition system and not the FIC. I replaced my spark plugs with a colder heat range and closed the gap very small. This made a huge difference as the spark needs less voltage to jump the smaller gap. I still sometimes have a hesitation but much less often. I think the only way to correct this completely would be better ignition coils. I have heard of boost actually blowing out the spark when more air rushes into the combustion chamber. Have you corrected your hesitation?
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 03:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 03:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 02:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 03:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 03:10 PM
