Old 04-25-2011, 09:01 PM   #415
cdydjded
Drives: Yaris LB Turbo
Originally Posted by Parmas View Post
I think you must precise more this post when saying " I am running positive percentages in high boost". How much positive and how much boost?
Do you have an upgraded fuel pressure regulator? With the regulator you can reduce fuel pressure and equalizing fuel ratios (although I don't know how the stock ecu reacts having it installed)
Our cars use a return-less fuel system, it does not have an accessible FPR. The FPR is inside the fuel tank.
Old 04-25-2011, 09:03 PM   #416
cdydjded
Originally Posted by Focus_Sh1ft View Post
^ Who was that? It's not exactly a hard concept to grasp...
Anyways, I could have sworn the FIC causes hesitation at 0 and below in its maps. So pulling fuel actually works? That means I can stop skewing the MAF!
It was the resident jackass, Ill give you one guess. And yes the FIC does not like 0's in a cell inside the fuel map.
Old 04-25-2011, 10:14 PM   #417
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Yup that caused my bogging and hesitation.
Old 04-25-2011, 10:18 PM   #418
cdydjded
How many of the maps are you using? I just use the fuel map using the built in map sensor & timing map by TPS position......
Old 04-26-2011, 12:07 AM   #419
Yoda
Yoda's Avatar
3 maps. fuel maf and ignition. tho i could hook up the o2 map but ehhh too lazy.
Old 04-26-2011, 12:12 PM   #420
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Those are the same maps I use. I pull 2 degrees of timing at high rpm for safety sake. And I think I have the maf clamped at 3.1v. I dont actually have any zeros in my fuel map. Around 2 psi the numbers switch from negative to positive percentages.
pimp my yaris is offline   Reply With Quote
Old 04-26-2011, 12:28 PM   #421
Yoda
Yoda's Avatar
You might have a little knock when it gets hot. My timing is pulled by like 6 I think. My maf is clamped around the same
Old 06-09-2011, 07:32 PM   #422
pimp my yaris
C'est la vie
Turned up the hairdryer a little! A couple of days ago I went from 7psi to 8.5! Its a nice kick in the pants. I can really her that thing screaming now.
Old 06-09-2011, 10:42 PM   #423
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Nice. I've been running mine at 8.5-9lbs. Love it. Hope it don't blow soon. ;)
Old 06-10-2011, 09:22 PM   #424
pimp my yaris
C'est la vie
Me too
Old 06-10-2011, 09:30 PM   #425
pimp my yaris
C'est la vie
I leaned out from about 11.5 to 12.5:1 afr after raising the boost. Looks like some fuel system upgrades are needed. Going to work on the pump again this weekend.
Old 06-17-2011, 08:45 AM   #426
pimp my yaris
C'est la vie
Well over the weekend I managed to get my 255lph pump installed into the stock fuel filter and regulator inside the tank. I tryed to do this once before with no success. I found previously the pump was loud and overheated in about five minutes of driving and the car would dye out. This time I found the pump was restricted because the outlet tube on the pump is longer then the stock pump. So the tube would bottom out in the filter and restrict flow. So this time I shaved on a angle a little over half the outlet tube on the new pump. This mabe a little hard to picture but it allows the fuel to enter the filter without restriction. I also had to use a larger O-ring to seal the pump tube inside the factory filter that sourounds the pump. Now it is only slightly louder then the factory pump and has been working great from sat. Also my afr has returned to 11.5:1.
Old 06-26-2011, 08:33 PM   #427
reflux1
Balls deep...
reflux1's Avatar
Drives: 2007 yaris liftback
pimp's car is definitely fun to ride in...
reflux1 is offline   Reply With Quote
Old 06-27-2011, 09:35 PM   #428
pimp my yaris
C'est la vie
Last weekend I installed a new 3 1/4 inch autometer phantom tach and new JVC 7" touch screen head unit. Also recently installed new Federal 215/40/17 tires. They just barely fit and they rub very slightly on the tie rod when turned to the stop. But look great. Also rerouted my intake tubing and moved the air filter to clean up the engine compartment a little. I am having a spoiler for the rear hatch painted this week. I am loving this little pocket rocket now.
Old 07-06-2011, 04:22 PM   #429
aruester
Drives: 2009 Yaris 3D
Great job pimp! It took a couple days but I read the whole thread lol. I will be starting my Turbo project one day soon and it will be my first so this was VERY enlightening!
Does ur glove box still open? That is a very clean install from the looks!! I like!
aruester is offline   Reply With Quote
Old 07-07-2011, 09:01 AM   #430
pimp my yaris
C'est la vie
Yes the Glove box still opens, but there is a hole cut in the pocket behind both of the guages for clearance and wiring. I dont use it anymore.
Old 07-07-2011, 09:12 AM   #431
pimp my yaris
C'est la vie
I installed a new spoiler that I ordered on E-bay from China. It was actual plastic [not fiberglass] and its working well. Not to big and not to small, I think. Also towed some friends to a track day with there bikes. With so much weight on the back of the weeee Yaris it sounds like a diesel truck with the turbo. Still had plenty of pull though. One tough car!
Old 09-18-2011, 10:02 AM   #432
pimp my yaris
C'est la vie
Going on a ride today with some friends from Supra forums. Going to some twisty roads to a state park for a little picnic and bullshiting. My friends Supra is pushing 932 ponies to the rear wheels. His turbo is the size of a large dinner plate. His girl friends supra is pushing 420 to the rear wheels with a single turbo conversion. Must be nice to have money. Im sure I will be the only turbo Yaris there, but Im gonna represent!
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 03:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 03:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 02:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 03:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 03:10 PM
