#37 |
That part with the stuck bolt is called the "block, fusible link" (82620-52050). It's only $12 from the dealer (the clamp is a separate part, and that is about $20). With the corrosion the bolt and nut may be fused to where they can't be removed without snapping the bolt.
| Tags |
| battery, battery terminal, corrosion, duralast, fail |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 02:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 03:40 PM |
| Charging voltage for stock battery | Vinceb | DIY / Maintenance / Service | 3 | 02-12-2011 01:10 AM |
| Fog lamps as back up low beams. | ellenbetty | General Yaris / Vitz Discussion | 114 | 10-22-2009 04:40 PM |
| Installation of a Battery Isolator | frostbitten | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 10-07-2009 01:11 PM |
