![]() ![]() ![]() Drives: 09 Yaris 3dr HB, BRZ Join Date: Mar 2011
Tein Springs - Cut Bumpstop? 3dr
With my echo I never bothered, didn't know whether we needed to either.
Anyways, I received a set of Tokico blues and Tein Springs (thanks Garm) today, and will be putting them on myself (Brother did the echo, i held the beer..) So, is cutting the bumpstop neccessary for this application? Thanks |
#2 | |
Shut your fricken suck!!!
Thanks,
Can't find anythign on the website or in the box they came in so was at a bit of a loss. |
![]() ![]() ![]() Drives: 2007 black yaris hb Join Date: Feb 2011
im running tein stechs and tokico blues been for several months now...i cut the bumpstops just below the plastic bushing ring thing...you will see what im talked about wen you get ur bumpstop out. u do need to cut them because the tein springs are soft so u will compress and hit ut bumpstops if you dont. i havent had any problems with bottoming out yet so thers my 2 cents
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
Frankly, I'd rather protect the strut from bottoming than have a slightly more comfortable ride.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
#6 | |
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
The issue IME is when your traveling fast with a heavy load, you hit a large dip and break your back(not literally) when the car comes to a sudden stop halfway through it. Other than that it's probably not going to be a problem leaving them longer. I did cut mine when I installed my DF's on factory shocks because I was worried they would be super bouncy and keep slamming me around.
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
When I did TRD springs and struts, I did not cut them. If you have the accompanying shocks with the springs, it's not necessary to cut the stops. If you're doing just springs, then you might want to cut the stops. That's what I've heard. There are so many different opinions on this matter though.
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. |
In the end I didn't cut them I am going to see how it goes. The car has a 2nd person in it maybe 2x a year, and the only time it has a load in it is when I take the winter wheels to the stealership to have them mounted (no charge of course!)
you should have cut them...but with that kind of drop, your wheels will likely rub before you hit the bump stop
Let us know in a couple of weeks how things are going.
I had Teins on my echo hb and didn't cut bumpstops, I can recall hitting the bumpstop maybe once in the 5 years I had it. It would rub at the front on rare occasions (195/50/15's on ET38 rims at least i think that was the offset) but it would have to be extreme for it to happen. The echo actually sat lower than the Yaris is so far.
Not been using the car much since I did it, on vacation and have the place to myself so being a bum for a week! Can't wait for the wheels to arrive... then to see if 17 " ET42 will work with/without 10mm spacers in the rear.. |
| Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed | RedVitz | Photo-Video-Media Gallery | 18 | 10-09-2010 03:36 PM |
| Tein S-tech Springs with Stock shocks combination. | daddz07 | California | 11 | 08-21-2010 01:49 PM |
| Tein S-tech Springs with Stock shocks combination. | daddz07 | Performance Modifications | 1 | 08-09-2010 03:45 PM |
| Tein Basic Damper Coliey's Vs. Tein S. Tech Springs | ToTo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 35 | 05-07-2007 05:08 PM |
| TEIN S-Tech Springs *NOW AVAILABLE* | EnduroMTS | Sponsors Classifieds Area | 1 | 10-12-2006 02:08 PM |
