Old 11-16-2010, 03:29 PM   #1
revolution
Drives: 2009 JDM Toyota Vitz
Steering Wheel Audio Controls...?
Hi,
So I found all the part numbers for the Steering Wheel Audio Controls that will allow me to add it to my Vitz RS, but I'm stuck on a little issue...
I can order the Silver Trim pieces, Buttons and Spiral, thats easy. And i can get the smaller Steering Wheel Airbag cover as well. But my only concern is what to do about the Airbag? Will i move the Airbag over from the old steering wheel cover? If so, how do i do that? I don't want it going Poof! on me whilst im installing...
Any help very much appreciated!!!!
2011 JDM Toyota Vitz RS
NCP91-AHMVK
Keyless-Go,8 Airbags, Pioneer AVH-P4150DVD, Reverse Camera, Nokia Bluetooth Kit, Pioneer 6.5" 230W Split System in Front, 6000K HIDs in Headlamps, 6000K HIDs in Foglamps, Afe Intake, 17" Advanti Toro Rosso Alloys with 205/45/17 Yokohama R1 Tyres, 40mm Modellista Lowering Springs...
revolution is offline   Reply With Quote
Old 11-16-2010, 03:48 PM   #2
Originally Posted by revolution View Post
Hi,
The airbag assembly is riveted to the cover with some very heavy duty rivets. You would need to drill those out to change covers.
Old 11-16-2010, 04:38 PM   #3
To answer your PM questions in a bit more detail, here are some pictures of how the airbag assembly and cover are constructed:
The airbag assembly removed from the steering wheel (note that the popped squib has been removed in this picture):
A replacement cover:
The rivets that need to be removed to separate the airbag frame from the cover:
The back side of the removed airbag frame:
The front side of the removed airbag frame:
The back side of the removed airbag frame with the popped squib:
The front side of the removed airbag frame with the popped squib:
The back of the popped squib:
The front of the popped squib:
Hopefully those give you a better idea of what you are dealing with. I drilled the rivets on this popped one, but would be hesitant to do so on a live one. The rivets are large, hard, and generate a lot of heat while being drilled. If I were going to swap the cover on a live one, I think I would:
1. Cut the plastic cover around the four rivets.
2. Pry the frame out of the cover (it has a lip that fits into a channel in the plastic, so you have to pry it loose once the rivets are free).
3. Unbolt the squib from the frame (there are four nuts that hold the squib assembly to the airbag frame).
4. With the airbag squib removed, drill the rivets out of the frame.
5. Bolt the airbag squib back to the frame.
6. insert the airbag assembly into the new cover.
7. Rivet or bolt the airbag assembly to the new cover.
Old 05-10-2011, 03:40 PM   #4
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
cool tips
ricepower is offline   Reply With Quote
!!Toyota Belta(Yaris Sedan) Steering Wheel Controls!! Murtaza_murti In Car Entertainment + Electronics (audio / video / alarm) 39 01-07-2015 03:33 PM
Steering wheel audio contorols - Yaris 2003 levvy In Car Entertainment + Electronics (audio / video / alarm) 14 08-31-2013 09:54 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 11:16 AM
Steering wheel audio controls? vodkalush In Car Entertainment + Electronics (audio / video / alarm) 14 09-14-2006 12:17 AM
