Old 05-04-2011, 01:01 PM   #775
Jason@SportsCar
Originally Posted by soloecho2 View Post
It was ment as a joke about the camera image. Thanks for the info on the other cars. Keep up the good work.
OK. Someone else made a similar comment, so I thought I was missing something in the video.
Old 05-04-2011, 06:51 PM   #776
Jason@SportsCar
Here is a PDF version of the second installment of the Yaris feature: http://pdfcast.org/pdf/sportscar-yaris-part-2
Old 05-05-2011, 08:04 PM   #777
Jason@SportsCar
New part to test fit this weekend:
Old 05-05-2011, 08:06 PM   #778
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Which mount are these on a Yaris? Echo's don't have anything like that.
rob323 is offline   Reply With Quote
Old 05-05-2011, 08:11 PM   #779
Jason@SportsCar
From the cross member to the bottom of the trans.
If it works good, and if the math $$$$ works out, Energy Suspension might put these into production.
Old 05-05-2011, 08:16 PM   #780
rob323
Hmm, I wonder if this is an upgrade I can make on my echo cause that rear roll stopper cops an absolute hiding.
Old 05-05-2011, 09:18 PM   #781
Energy Suspension will have to compete with TRD on that one. I would stock theirs if the price is right -- and they call.
Old 05-07-2011, 11:03 AM   #782
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Originally Posted by Jason@SportsCar View Post
This should buff right out... Or maybe its time to order a new one.
i love that image. Safe Racer with the nice dent in it.
So a question, how much of your success is the Yaris, and how much is your experience? Is the Yaris really as good as you make it seem, or are you manhandling the crap out of it to make it perform?
Colin Chapman disciple
Old 05-13-2011, 03:24 PM   #783
Jason@SportsCar
Early on it was all about manhandling the crap out of the car... Now that the cars is getting faster I have to do less work.
Old 05-13-2011, 03:26 PM   #784
Jason@SportsCar
Another item to put on the to do list. Going to try the 170 degree thermostat from the MR-2 Spyder. Dimensionally is measures the same as the Yaris part - and the Yaris uses the same standard part as the Spyder - so hopefully it works.
$10 VS $75+ for the TRD Japan part.
I probably wont install it until we put the new motor in.
Old 05-13-2011, 03:45 PM   #785
good info
Old 05-13-2011, 03:47 PM   #786
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
my catalog says yaris and mr2 spyder thermostats are NOT the same!
the yaris shares same part # as all the 1nz motors and supra and 2.7 liter tacomas.
the mr2 spyder shares part #'s with camry, matrix,highlander,etc....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 05-13-2011, 03:58 PM   #787
Jason@SportsCar
Since I have the spare motor sitting in the garage I may try and test fit it this weekend, I just wont have a chance to track test it.
btw... It is a Stant 14077 if anyone else wants to try it. Obviously you are at the mercy of the electric fans in a street car, so you will see little if any change except at freeway speed.
I looked into it because of the higher temps we are seeing now. With the 15" wheel/tire combo the car did not rev as quickly, and the temps stayed right around 200. Now with the 13"s the cars revs quicker, and maintains a higher average RPM, this has driven the temps up around 210. Hopefully this does the trick.
Old 05-13-2011, 04:01 PM   #788
Jason@SportsCar
Stant lists the 48308 (OE style 180 degree) as fitting the Yaris and 05' Spyder, along with a dozen or so other cars.
This is why we test stuff. Fingers crossed.
http://stant.com/common/part_locator...m.cfm?id=48308
Old 05-13-2011, 04:40 PM   #789
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
HOPEFULLY it works!!!
Old 05-14-2011, 12:29 AM   #790
Jason@SportsCar
Well it fits in the hole... wont know if it works for a few weeks.
Old 05-14-2011, 11:06 AM   #791
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
very interesting.. i love this thread..
Old 05-17-2011, 12:05 AM   #792
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
What pads do use for the track? I run into brake fade issues after just a few laps on Hawk hp+. What our your current spring rates? I bumped up my front rates after removing sway and fight instability during high speed braking , but it rotates fine eveywhere else now.
Ptuning.com
Blown_xa is offline   Reply With Quote
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 08:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 11:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 06:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 01:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 11:51 AM
