Old 05-22-2011, 02:49 PM   #19
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Thumbs up SUCCESS! DRL Works
Originally Posted by toy_toronto View Post
Thanks for the idea zuberio -- nice work!
I recently installed an HID kit but now missing the DRLs since I had to disconnect the relay underneath the dash. I'd like to get the DRLs back therefore I plan to do this relay DIY to my hatchback, but the difference is I just want to use the existing parking lights inside the headlights as the DRL lights (see pic below).
I'm going to be replacing the bulbs with the brightest/white 194's LED that I can find to make them more visible in daytime.
I've searched the forums but had difficulties finding the info... Do you have a link where I can find the hatchback headlights wiring diagram so I can splice the hi/lo signal source to the relay?
thanks!
-toy
Success
I didn't know that the sedan and hatch shared almost the same wiring. I went and checked the same fusebox and managed to splice the same wires to make the bulbs I wanted to use as DRLs work (i.e. parking/city lights inside headlights).
There's a slight difference though compared to which BAT wire zuberio used. I ended up tapping the brown wire (85) since it's the only one that switched LO (86) to 12V to energize the relay coil whenever I switched the headlights on.
Now I have my DRLs back! Now I just need to find the brightest LEDs to swap the bulbs with.
-toy
Old 05-27-2011, 02:18 PM   #20
toy_toronto
always toyin'
Drives: 2010 5-Dr
Well, the LED swap didn't make the lighting any brighter so I added a pair of dedicated DRLs and mounted them between the lower grill.
This pretty much concludes my quest for DRL (for now, haha).
-toy
Old 07-07-2011, 08:02 PM   #21
ladyKay
Drives: 2008 yaris sedan
That just looks awesome, a job well done! I need to do that for mine too, only I have no idea. Probably really pricey to have someone else to do it for me...
ladyKay is offline   Reply With Quote
drl, headlights, led, relays, wiring
our DRL is running in pulse............. marcus Cosmetic Modifications (Exterior/Interior) 14 06-21-2010 09:49 AM
Daytime Running Lights Module amtoro Willing to Buy by private party 1 11-13-2009 10:32 AM
DayTime Running Lights ISSUE!!!??!?!?!?!2009 5-door-hatch powermicro In Car Entertainment + Electronics (audio / video / alarm) 1 05-14-2009 12:12 AM
Need Help Wiring Fog Lights MadMax Cosmetic Modifications (Exterior/Interior) 29 11-29-2008 06:31 PM
Daytime Lights NimbleYarisOwner General Yaris / Vitz Discussion 17 08-24-2007 09:07 AM
