Old 05-22-2011, 12:15 AM   #1
JTDBT903
JTDBT903's Avatar
Drives: '08 SEDAN 5 SPD.
Front end alignment specs for lowered car
I just dropped my car and want to do an alignment on it and I can't find any good posts on alignment specs. Anybody that is dropped have any good suggestions? What do you think for a DD thats been dropped about 1.5''-2''.
-1 camber [or should I go -1.5]
0 toe?
Should I do the rear washer trick to add some negative camber before I take it in?
JTDBT903 is offline   Reply With Quote
Old 05-22-2011, 01:24 PM   #2
Viperoni
Drives: 2005 Toyota Echo
On my echo I'm running -1.5 degrees and 0 toe all around, turns in good and sticks good too. I could use more camber for the track, but on the street it's good.
Don't worry about washers, the alignment tech will/should have round shims that will do the job properly.
2006 Saturn Ion Redline
Old 05-22-2011, 03:54 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Do you track it? And do you mean the rear suspension thing moving the bolt up by rear washer trick? If you do, I'd say absolutely.
If you don't track the car then I would say no negative camber, if you do then, go for as much as you can stand.
Colin Chapman disciple
Old 05-24-2011, 12:44 PM   #4
JTDBT903
JTDBT903's Avatar
Does anybody have the factory sloppy specs for the alignment?
No I don't track the car [maybe one day] I just want the most out of handling on a daily driver.
I just put the stainless washers behind the lower two bolts on the rear hub for some negative camber. I thought it would give me close to -1 but sheesh it looks like alot more than that! I have an appointment for the alignment tomorrow and would like to be able to tell the guy how I want it but right now I'm still not sure what would be best for a DD.
Nobody have any problems/tire wear with this on all four:
-1 camber
0 Toe
Old 05-24-2011, 08:40 PM   #5
why?
why?'s Avatar
Drives: Yaris LB
-1 camber
0 Toe
I wouldn't go a full -1 camber on the fronts. It isn't necessary and just hurts traction on an already traction hurting thin tire.
I wonder what Jason@SportsCar runs?
Oh, and any alignment shop will be able to pull up the factory specs for you.
Old 05-24-2011, 10:59 PM   #6
Viperoni
I would definitely run -1 camber and 0 toe on the front, -1 camber and a bit of toe in (say 1/4 degree total) on the rear for extra stability and less wandering.
I've been running the specs in my first post in this thread for close to 1000 miles, but I drive my car a lot harder than the average driver so I'm not a good basis for comparison. I can tell you that I am getting more outside tire wear than inside, even on the rears; I have brand new Hankook RS3's, and they have a flame molded into the 2nd and 4th thread grooves, the flame on the outside of either tire is noticably more worn than the inside flame.
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 11:43 PM
Custom front end spdas Cosmetic Modifications (Exterior/Interior) 18 03-09-2011 07:56 PM
understeer DOMAV General Yaris / Vitz Discussion 31 09-30-2009 08:01 AM
enobmort42 - Photo-Scavenger Hunt! enobmort42 Photo-Video-Media Gallery 9 03-05-2009 11:52 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 11:58 PM
