#19 |
I normally got around 451KM per tank while living in Italy, in the mountains. This is mainly on average with highway and city driving combine. Here in the UK for some odd reason i manage a little less, around 415KM per tank. But I also believe is the petrol, in italy I used Shell V-power all the time, but here i use everything else.
#20 |
UK Yaris Newbie
Drives: Yaris 1.8 SR Join Date: Jan 2011
If I drive very carefully I can get upto 47MPG on the motorway, usually 37 around town in my 1.8
Having fun is more like 32 mpg ;D |
#21 |
![]() ![]() Drives: Yaris SR 1.8 Join Date: Sep 2010
I rev mine up to around 6000rpm and drive it quite hard and the computer is reading 38mpg, if I drive normally I get 40mpg.
#22 |
UK Yaris Newbie
#23 |
might use 4.5L = gallon in the UK
(its 3.8L for a US gallon) might actually be closer to 32mpg using 3.8L/gallon
#24 |
Next time I fill up I'll work it out properly, I did set up a fuelly account but I keep forgetting to put the details in.
#25 |
![]() ![]() Drives: Yaris TS 1,8L Join Date: Oct 2008
All I can say is that after installing aFe intake my fuel consumption fell from 10,5 to 9 litres per 100km
#26 |
![]() Drives: Toyota Cars Join Date: Mar 2011
Toyota Yaris TS is a hatchback body style automobile that has 5 seats and 5 doors. It is manufactured for the first time in 2007. The measurements of the vehicle are as follows: height - 1530.00 mm, width - 1695.00 mm, length - 3800.00 mm. Furthermore, the front and rear track are 1460.00 mm and 1450.00 mm respectively and the wheelbase is 2460.00 mm. 1120 kg is the curb weight. The Toyota Yaris TS engine is naturally-aspirated and has 4 cylinders with 4 valves per cylinder, double overhead camshaft (DOHC) and engine displacement of 1798 cubic centimeters. It is positioned in the front of the vehicle and its alignment is transverse. The cylinders are inline-arranged. The cylinder diameter is 80.50 mm and the piston stroke length is 88.30 mm. The compression ratio is 10.00:1. The maximum torque delivered by the engine is 173 Nm at 6000 revolutions per minute and its maximum torque is 97 kW / 133 ps at 6000 revolutions per minute. The model's fuel system is electronic fuel injection (EFI). From 0 to 100 km/h the vehicle accelerates for 9.30 s. For 16.80 s the automobile can make a quarter mile. The Toyota Yaris TS has a 5-speed manual transmission. The top gear ratio is 0.82:1. 4.31:1 is its final drive ratio. This automobile has an urban fuel consumption of 7.2 l/100 km, combined of 9.2 l/100 km and extra urban fuel consumption of 6.0 l/100 km. 42 liters is the capacity of the fuel tank. The rating of CO2 emissions is 170 g/km. The vehicle has a power assisted rack and pinion steering box. The type/size of tyres in the front is 204/45 R 17. The type/size of tyres in the rear is 205/45 R 17. The front brakes are set up with ventilated disks. The rear brake system includes disks, servo assistance, anti-lock braking system (ABS). The diameter of the front brakes is 275.00 mm and the one of the rear brakes is 259.00 mm.
Toyota Dealers Los Angeles Last edited by royb20644; 04-12-2011 at 05:44 AM. |
#27 |
does yours TS feel the diference between high octane fuel or not?i use 95 octane (manual says that), i filled last year 98 octane fuel, but i did't feel difference at performance, only at consumption:a liitle more compare to 95, so i decided to fill only 95.maybe i used a bad 98 octane fuel?or our car doesn't "like" high octane fuel?
#28 | |
#29 | |
#30 |
The newest batch of Toyota Yaris, which has been produced for the model year 2006 to 2007.The Toyota Yaris offers up to 29 miles to the gallon in the city and 35 miles per gallon on the highway. And also very ok for riding from town to town.Simply stated, there is really just one reason to make it perfect to ride in orange county toyota.
#31 | |
#32 |
![]() Drives: Toyota Yaris 1.8TS Join Date: Oct 2012
Hey Guys!
iv just recently installed a Custom cold air induction and we had a problem with the 02 sensor where the engine light came on and the car refused to start. we had to settle for keeping the OEM o2 sensor housing which sorted the problem but then the engine light stayed on. having said that prior to the CAI, i was getting a maximum of 400km off a full tank, generally throwing 38-40L per tank. we disconnected the battery to reset the ecu and engine light and since then ive seen that my kms have shot up to 450 - 480 km off a tank! im a happy chappy! i dont know if the CAI affects the petrol consumption but i would recommend disconnectin the battery for abt 15min then reconnect and see what happens...
Current: 2009 Yaris 1.8TS Ex : 2010 VW Polo 1.4 Comfortline |
#33 |
flat foot and economic driving i am averaging not more than 9.7L /100km
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 04:34 AM |
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 04:54 PM |
| Another S/C'd member worried about his AFR | LtNoogie | Forced Induction Forum | 181 | 04-18-2009 01:19 AM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 11:53 AM |
