Not quite a noob
Drives: e46 325 Join Date: Jul 2009
My new Leather Scion tC steering wheel!
Bought it off eBay. This is the link I bought it from:
http://cgi.ebay.com/ebaymotors/ws/eB...T#ht_500wt_956 only issue is that the wheel will sit crooked. The sl9otsin the locking ring don't line up properly with the Scion wheel I got. The stock yaris wheel has a ridge in the metal part that sits on top of two ridges in the locking right, whereas the Scion wheel does not have these ridges, and therefore mus sit crooked in the other slots in the locking ring. A bit irksome.. but it's leather! |
I have a TC one on Crashy. To make it not sit crooked, you rotate the clockspring by the width of that tab.
Not quite a noob
doesn't that make your signal on one side shorter than the other?
The signal cancel difference is really not even noticeable with how little you have to shift it.
Not quite a noob
Awesome
Ill give it a shot in a bit when I have time! |
Not quite a noob
Hey CT, I shifted the locking ring to the left and now my wheel is straight BUT! for some reason it clicks excessively when I turn?
Very strange. No clicking with mine.
Not quite a noob
It sounds very.. patterned. They're not random. I hear two clicks when I reach a certain point, and then two clicks again when I pass back around the other way. The signals and everything work fine, but this annoying me. As far as I know I haven't rotated the clock spring a full cycle around accidentally so it's not like it could be off.. Maybe I'm crazy but, does your normal yaris click when you turn? More than just the once when the signal passes the point of return?
#9 | |
Not quite a noob
Everything is on tight and proper
I just pulled mine back off to take another look. If you look at the round part that inserts into the center of the clockspring, the continual diameter of the TC one is equal to the widest width of the Yaris one. I wonder if the extra material is sitting wrong on yours to where it is pushing against some of the fins on the inner surface of the clockspring and hence deforming the clockspring case enough to cause the clicking?
Not quite a noob
It may be that you're right and it's not seated right. When I get back to my car in a bit I'm going to go e it another reseat. Which way did you orient your clocksprong? More clockwise or counter?
The Clockspring connector is to the right of center.
#14 |
Not quite a noob
^ Which incidentally fixed my problem. I set it clockwise form center. Magically fixed itself.
#15 | |
1.5 or 2.5 both=0-60 in 8
Man what an idiot, I wish I knew about this, just wasted the money on a after market leather steering cover!
#16 |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
final pics?
#17 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
does it fit with the silver parts that have the volume control ?
http://www.ebay.com/itm/Scion-TC-Ste...#ht_889wt_1344
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#18 | |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 02:41 PM |
| Scion XB/XD Silver/Dark Grey Leather Steering wheel | DED1982 | Items for Sale by private party | 15 | 07-30-2010 09:51 AM |
| Leather Steering Wheel | MGargano | Cosmetic Modifications (Exterior/Interior) | 29 | 05-08-2009 05:53 PM |
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 01:05 AM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 07:30 PM |
