Old 06-13-2011, 03:36 PM   #811
Jason@SportsCar
Made a trip up to AAA Speedway on Sunday to pick up some tires. And there it was in the paddock, the Honda Fit HP racer. They still have a lot of work to do, but it was great seeing the car out there for the SCCA Regional race.
Luckily for them I happened to have a couple of my 13" Jongbloed Racing wheels with me, and they were able to do a test fit. Turns out the wheels we spec'd for the Yaris are a perfect fit over the Honda's brakes.
Hopefully they get the car up to speed and bring it to the Runoffs at Road America.
Old 06-13-2011, 04:57 PM   #812
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Haha, man they have that thing slammed in normal Honda fashion.
Old 06-27-2011, 02:00 PM   #813
Jason@SportsCar
Pulled the old front off this past weekend. The lower core support was bent up pretty good from the last race. Also the bumper was not salvageable, it was bent to the point of being cracked, and most of the mounts/supports were missing or damaged.
Turns out the #20 Yaris is not going to be used anymore, so we are going to pull all of the support structure and bodywork we need off of it before it goes to the crusher. Best part, since it has the same graphics its just plug and play.
Old 06-28-2011, 12:27 AM   #814
Bluevitz-rs
Wha happen?
Old 06-28-2011, 06:49 PM   #815
Jason@SportsCar
Originally Posted by Bluevitz-rs View Post
Wha happen?
Nothing major, just wear and tear from racing. With the 13" wheels I only have about 3" of ground clearance, dipping a tire off the track means the front bumper/belly pan both hit the ground.
Between getting punted at Willow Springs, and jumping off the track at Buttonwillow, the front end was due to be replaced.
Old 06-28-2011, 06:59 PM   #816
Jason@SportsCar
We got all of the useful bits off of the 20 car, and it will soon meet the crusher. We swapped the damaged bumper from the 99 on to it.
Old 06-28-2011, 07:45 PM   #817
is the cage going to be crushed?
Old 06-28-2011, 07:50 PM   #818
Jason@SportsCar
Yeah, the whole thing. It's a weld in cage anyway, no way you could salvage and reuse it. The amount of hours that would take does not justify the few dollars saved versus getting a new one built.
The 98 car will stick around for a while, just in case they come up with a use for it - the 98 was supposed to go to the U.S. dealer meeting in Vegas this week, but they took something else.
Old 06-28-2011, 09:55 PM   #819
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
can we have a moment of silence for when it goes to the crusher?
Old 07-11-2011, 01:27 PM   #820
Jason@SportsCar
Got the old stuff out this weekend, went much quicker than I thought it would. Unfortunately some parts are on back order so I could not start putting the new motor in yet, hopefully I can knock it out next weekend.
Old 07-18-2011, 01:42 PM   #821
Jason@SportsCar
Shiny new motor in place - you could eat off this thing. Should have it back on the ground next weekend, then off to the dyno, and finally a test day at the track.
Old 07-18-2011, 03:21 PM   #822
ilikerice
ilikerice's Avatar
amazing.. looks so fresh
Old 07-18-2011, 05:29 PM   #823
Jason@SportsCar
So I had some time to play with this some more while I had two engines sitting on the garage floor. I put both thermostats in a pan on the stove and heated them up to get open and closed lengths.
The Stant MR2 unit will fit. The only issue is the bypass will always be closed - with the stock thermostat the bypass is only closed when the thermostat is open.
So does anyone know what function the bypass has?
Originally Posted by Jason@SportsCar View Post
Another item to put on the to do list. Going to try the 170 degree thermostat from the MR-2 Spyder. Dimensionally is measures the same as the Yaris part - and the Yaris uses the same standard part as the Spyder - so hopefully it works.
$10 VS $75+ for the TRD Japan part.
I probably wont install it until we put the new motor in.
Old 07-18-2011, 05:45 PM   #824
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
"bypass valve regulates hot coolant into the heater core when you're using the heater or AC."-found USING GOOGLE....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 07-18-2011, 06:01 PM   #825
Jason@SportsCar
Thanks. Since I don't have either of those it should not be a problem.
Old 07-18-2011, 06:26 PM   #826
Astroman
Modded Moderator
Astroman's Avatar
Sad! Wish I could swap out the drivers side mirror with mine. Mine was broken at the swivel point and is gorilla glued, and when the glue did set it sagged a quarter inch. Toyota won't sell me the broken part, I need to buy the whole damn mirror.
Old 07-19-2011, 01:27 PM   #827
Bluevitz-rs
They bypass also help let through any trapped air bubbles.
Old 07-26-2011, 01:43 PM   #828
Jason@SportsCar
New front end is in place. I decided to put the brake ducts behind the grill this time, looks better, hopefully they still get good airflow. I also moved the tow hook, one less thing sticking out of the bumper.
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 08:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 11:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 06:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 01:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 11:51 AM
