![]() ![]() ![]() Drives: 3-door liftback blazing blue Join Date: Oct 2006
Manual transmission problem
Sometimes when stopped with the clutch pushed in if you go thu the gears the trans feels like it gets tight won't go into 1st gear until you let the clutch out and push it back in then a little bit later it feels fine.This morning I drove to work 35miles away was going thu the parking lot in second gear stopped and tried to put in in first gear wouldn't go in until i let the clutch out and pushed back in worked fine on the way home have 100,003 mile on car trans oil changed at 75,000miles
07 yaris LB 5-speed blazing Blue 07 yaris LB Auto Bayou Blue rostra cruise control oem style foglights 96tacoma 4x4 xcab I4auto Weathertech vent visors Scan GaugeII |
That is completely normal for most every manual trans.
You have to momentarily let the clutch out (like you described) to get the shafts spinning to enable the syncros to slip on to and engauge on the proper shaft. In other words shafts usually have to be spinnning for syncros to function properely. If gear teeth are not lined up via syncros, etc. you can't shift into that gear. Somtimes when stopped, you can go through the gears without using the clutch and other times, you cant. Like I said, it's normal. Last edited by RedRide; 06-30-2011 at 11:45 PM. |
^+1^
Also notice if you ever have trouble getting it in reverse, put it in 4th and then try reverse again. will go in nice and smooth.. |
Thanks guys i was worried want to drive my yaris to at least 200,000 miles
![]() ![]() ![]() Drives: Yaris Sedan Supercharged Join Date: Sep 2010
Take care of tranny man..... I already been through one......if you drive lot or you drive hard your car you might want to change your gear oil every 6 mos.... extend the life of it as much as possible ......... but if your problem worsens it might be a syncros wearing out or damaged ... I had that prob on my old tranny.......when it grinds to shift into gear worry.... lol
#6 | |
#7 | |
![]() ![]() ![]() Drives: US 2007 Yaris Liftback 5MT Join Date: Aug 2006
Just wanna confirm that this is normal, I had totally forgotten about it though because when I war learning how to drive a manual I was told to get into the habit of only putting it in 1st gear at a dead stop or going veeeeeery slow.
- Jason
2007 Toyota Yaris Liftback Base 5 Speed. Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust. |
Yea that good... that's what I do... or neutral ....
![]() ![]() ![]() Drives: '08 LB, '07 WRX Join Date: Jan 2009
try driving a wrx! first is dead stop only unless you double clutch it. ahhhh...the idiosyncrasies of subaru 5 speeds!
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
To get slightly smoother gear handling try just oiling and lubing the gear linkage on top of the gear box... WD-40 and some lube.
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
What kind of driving requires a gear oil change every six months? It seems like overkill.
![]() ![]() Drives: 2008 toyota yaris Join Date: Mar 2011
one that doesn't use a clutch to shift
08 toyota yaris with some big tires lol 02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
Not if u want your tranny to last u a long time.... if u drive a lot or drive it hard or both its good to change it.... I drive a lot & I take it to the track occasionally .... I'm going to start doing it...its good to have fresh oil in there......
Okay, I can understand a track car and hard shifting but not the "drive a lot". There's a reason why they make it a semi-pain to change the gear oil.
shouldnt the manual transmission fluid be changed every 40000miles?
#17 | |
Never try to force it into any gear. |
| Toyota C160 Reverse Gear Problem | Parmas | DIY / Maintenance / Service | 2 | 12-01-2010 01:30 AM |
| Transmission designed for 10-15 min cold start delay | Ironwill5 | DIY / Maintenance / Service | 29 | 12-03-2009 08:08 PM |
| manual transmission squeaky | Rich k | DIY / Maintenance / Service | 2 | 07-13-2009 11:34 PM |
| Is this normal in Manual transmission? | Syroyizhka | DIY / Maintenance / Service | 16 | 04-02-2009 01:19 PM |
| Detailed dealer pricing on the new, 2007 Toyota Yaris. | tomjasz | New YARIS Purchase Forum | 3 | 08-11-2006 10:46 PM |
