Old 07-05-2011, 04:37 AM   #1
eric_edge
Drives: '11 3dr white
Question wheels and mpg
pardon the newbish nature of the question.
how will tire and wheel size affect mpg? i.e. larger rims v. smaller rims, fat tires v. low-profile tires
and how drastically will lowering a car affect mpg?
im looking to pick up a yaris soon (my '94 camry finally died ) and would like to strike some balance between the car's natural fuel efficiency and absolute rolling teardrop sexiness when it's on a nice set of wheels.
eric_edge is offline   Reply With Quote
Old 07-05-2011, 01:24 PM   #2
AppleJacks716
Drives: 2010 5 Door
When i change wheels, which is a 5lb difference per wheel, my gas milage changes 3 to 4 mpg.
AppleJacks716 is offline   Reply With Quote
Old 07-05-2011, 01:27 PM   #3
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Larger, wider= less MPG.
Larger, lighter (more expensive) = maybe neutral change. ....emphasize maybe.
Basically use the stock wheels for a gauge. If you put anything grippier or wider, or heavier the difference will eat up the mpg.
Lowering actually helps out with the mileage as more air is forced over the car.
Drive the new car for a month to see your mpg before the change.
Old 07-05-2011, 01:44 PM   #4
wildmongoose26
wildmongoose26's Avatar
Drives: 09 5dr Yaris
More narrow tires will increase MPG since there is less contact patch.
Wider wheels will decrease MPG.
Heaver wheels will decrease MPG.
Lighter wheels will increase MPG.
Note that if you change the rolling diameter of the wheel the speedo will be slightly off and skew the MPG a little since your speedo will read off as well.
Angela
Chevy Cruze ECO earns an astounding 42 MPG EPA Highway rating! Kal-El Off-topic / Other Cars / Everything else Discussions 26 02-05-2011 10:29 AM
17" VS 16" Weight and MPG longlivekel Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-25-2010 08:59 AM
FE Turnaround: Disappointment to Satisfaction, 2010 Yaris. Almost +50 MPH. Thank You! STC Fuel Economy Forum 12 04-16-2010 11:21 PM
Help me see 55 mpg! Loren Fuel Economy Forum 76 04-02-2009 04:23 PM
Wheels & Tires For MPG S1L3N7 D3A7H Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 01-30-2009 10:45 AM
