Old 07-15-2011, 05:04 PM   #1
Mister Z
Drives: 08 Yaris HB
question
Does anyone kno if the oem header gasket fit the megan racing header? Also if u do run he oem gasket will it be a loss of power since the gasket diameter holes are smaller than actermarket?
Mister Z is offline   Reply With Quote
Old 07-15-2011, 05:32 PM   #2
Since the exit ports in the head don't change in size, it shouldn't matter. I've seen lots of people reuse that gasket, I usually just pick up a new one, they are very cheap.
Old 07-15-2011, 05:35 PM   #3
Mister Z
Drives: 08 Yaris HB
Thanks garm. If that's the case then what makes the headers better than stock if the exit ports are the same size?
Old 07-15-2011, 07:08 PM   #4
You can bolt on a larger, open flow axle back way at the back and extract a couple of horsepower.
In the same way, opening up the exhaust and collecting with a freer flowing header will generate more power. On the intake side, the intake does the same thing. All of the bolt-ons add a small amount of power, and none require head work.
(Although a port and polish on your head would generate some that's for sure!)
Summary: You are more powerful when you're not constipated.
Old 07-15-2011, 08:10 PM   #5
Mister Z
Drives: 08 Yaris HB
cool thanks garm!!!
Question about bi amping front components. YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 6 08-28-2010 01:04 PM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 01:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 04:57 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 06:44 PM
