#73 | |
Below my observation: My wiring harness is not the same. The canadian cluster has the illumination control and GCC/EU model don't have. To fix this, You have to swap/jumper or rig the illumination pinout of the new cluster. I put it back my original cluster as I am annoyed without the illumination/backlight. Everything works fine. From here, I noticed also that they have different programming cluster daughter board. Tried to swap their daughter boards also but the results is more bad(none of the pointers is working). |
#74 |
So, I've been searching all these Tach Cluster threads and still have not been able to verify if I can put a tach cluster in my '08 3dr HB MT US base model. If it is possible does anyone have an idea of which clusters will work without issue?
I was thinking of trying a cluster from an '08 US HB auto trans model. We need to make a chart showing what will work with what.
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed. |
#75 | |
#76 |
Right on Scott, that narrows the search a bit.
Love your snowplow BTW
#77 |
2ZR swap. DO IT! Ask how!
Thread revival time!
I've been plowing though as many threads as I can, but I still can't find the part number for a USDM cluster w/tach and ABS. I've found some part numbers on villagetoyotaparts.com and toyoDIY, but the descriptions are either absent, or not helpful. Here's what I've found so far at villagetoyotaparts.com for a 2010 USDM 3DR MT: 83800-52L30 - speedo only (2010 hatch, ebay listing) 83800-52L40 - ??? 83800-52N61 - speedo only (2009 hatch, ebay listing) 83800-52N71 - w/tach and ABS 83800-52P01 - ??? 83800-52X00 - ??? Could someone with a USDM hatch with tach pull their cluster and verify the part number? *edit* Ok, after more poking around at toyotapartszone.com, I found about a dozen part numbers for the 09 North American hatch. Sadly, they either say "Mexico spec" or "not available". The descriptions seem to be a bit better, but having a description for a part that doesn't exist anymore is pretty useless. =/ Last edited by CrankyOldMan; 07-19-2011 at 08:45 AM. Reason: clarified by CTScott |
#78 | |
For an 09+ with ABS and the Tach: 83800-52N71
#79 |
147K-Blue / 24K-Yellow
Drives: 2010 Ylw 3dr. AT(Blue-Wife's) Join Date: Mar 2011
I know this Thread is almost 4yrs old... Don't Shoot Me!
On the 09+ LB w/abs WITH TACH, does it matter?, or which Part # is correct for 5-Speed and which for AT?
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires. Repair List: 1 new blower motor, making funny noise. @ 91K (Water pump @ 120K) Mod List: 1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott) |
#80 |
![]() ![]() ![]() Drives: Yaris Hatchieback Join Date: Jun 2010
tach cluster
I got 07 hatch none tach and I found one for $150 09 hatch with tach. Can anyone provide me some information here please. Can i just swap it over and plug and play or I need to change wht hardness. Thx!!!
#81 |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
09 S Cluster needs to be matched with car with abs or the mph needle wont move.
S cluster doesnt matter Auto or Manual. Harness is the same, its simple plug and play.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
#82 |
Thanks for reply. So all 09 cluster comes with abs. Can i get one with out abs and then both will be working fine. thx!
#83 |
With US ones ALL come WITH ABS. The speedometer issue is only when using a JDM cluster on a non ABS US car. If you use a U.S. ABS one on a non ABS car the ABS and brake lights will always be on. You can disable those lights to make it usable.
#84 |
Thank you very much! CTScott
#85 |
![]() ![]() Drives: 2008 Yaris 3 Door Manual Join Date: Mar 2015
I read this whole thread, is there an end all answer for this?
I'm reading "discon the battery first and it'll work" then "that doesn't work" then "the dealer can do it" then "the dealer can't do it" What's the actual answer here?? I'd sure love to have a tach, on the cluster on my 08 manual... |
#86 | |
#87 | |
#88 |
![]() ![]() Drives: 2008 Yaris Join Date: Sep 2014
CT, I'm thinking about doing the swap to the type S to get the tach. If I did this what would flashing the mileage include? I.e. do I need to send it to you with my old cluster or something and how much would you want?
#89 |
You would just have to send me the new one (and shoot me a pic of your current one with its current mileage). I charge $40 + return shipping to reprogram them.
#90 |
Good to know CT, I'm in the middle of moving so it may take a month or two but i'll definitely be PMing you in the future, thanks!
| Installing Speedhut tach, need help! | RedRide | DIY / Maintenance / Service | 2 | 07-05-2009 04:02 PM |
| Canada tach in a US Yaris LB | tiksman | DIY / Maintenance / Service | 49 | 02-27-2007 02:40 AM |
