Old 01-18-2011, 01:36 PM   #19
marschall
Drives: vitz 06
The only problem is that it is not illuminating i just mailed pivot lets see i will keep you posted if you dont mind sir
marschall is offline   Reply With Quote
Old 01-19-2011, 12:07 PM   #20
tforkner
Drives: 08 liftback 5 speed
Cars have been started with keys since just after WWII (OK, not sure about that) for a reason. The only cars I ever had with start buttons had them because I bypassed bad wiring or key switches. I really don't get why start buttons are all the rage right now- they seem pre-tailfin to me.
tforkner is offline   Reply With Quote
Old 02-02-2011, 12:25 AM   #21
1.5ty
Rollerskate
1.5ty's Avatar
Drives: 09 hb
hey scott is there a way to start the car with the push start and not have to have the key at all like a switch you can hide and flip when you wanna hit the pts butten
Its a roller-skate get it right
add me on facebook if your from nc
my email for facebook is drifter704@yahoo.com
1.5ty is offline   Reply With Quote
Old 02-02-2011, 07:08 AM   #22
You would have to remove the lock cylinder to get rid of the steering column lock. That eliminates a level of security for theft of your car, but if your 09 has the engine immobilizer, you would still need to wave the key by the receiver (the black rings around the key switch) to allow the car to start.
Old 02-02-2011, 08:56 AM   #23
1.5ty
Rollerskate
1.5ty's Avatar
Drives: 09 hb
i dont have a chip its just a key and hey if you could or if you ever get a chance could you show me what wires i need to hook the new button that way when you have it off you cant do noting and with it on you can sttart the car listen to the radio every thing like a key but without the key
Old 02-02-2011, 10:11 AM   #24
Actually, thinking about it a bit more, with a basic momentary switch, all you can do it crank the starter. You still need something else (the key, another switch, etc.) to turn the engine on/off and to have things like ACC mode. The OEM PTS and some of the aftermarket ones have logic behind the switch that allows for the different modes (push once for ACC, again for ON, a third time to start, then hold for 3 seconds to kill).
Old 02-02-2011, 11:15 AM   #25
hachi-roku_fan
Drives: 1986 Toyota Corolla
CTScott, do you think it would be possible to use the PTS system from a Lexus, that uses no keys at all, just sensors? Or is that a function that is limited by the ECU?
hachi-roku_fan is offline   Reply With Quote
Old 02-02-2011, 01:14 PM   #26
The OEM PTS system uses a different ECM, so even using an OEM Yaris/Vitz one from an area where that feature is available is impractical.
There is a complete aftermarket system that has been discussed on MI:
http://www.microimageonline.com/foru...-Entry-for-279
Old 02-02-2011, 08:30 PM   #27
1.5ty
Rollerskate
1.5ty's Avatar
Drives: 09 hb
hey scott I see that you said you made a pts setup how does your work I don't have a chip in the key and don't have power but I really don't wanna use the key other then to unlock the doors I wanna have mine set like a rally car flip a switch and then hit the button to start the car no keys
Old 02-02-2011, 09:45 PM   #28
My module lets you use an OEM PTS switch and allows you to start and kill the engine.
For what you are looking to do, you would basically be replacing the keyswitch with your flip switch and then could use my module, or just a simple momentary switch for cranking the starter. The one downside to what you are thinking of doing is that without the key/steering column lock or the engine immobilizer it would be very easy for someone to steal your car.
Old 02-03-2011, 12:26 AM   #29
1.5ty
Rollerskate
1.5ty's Avatar
Drives: 09 hb
hell if someone wants my car ill give them a hr head start then call and say someone stole it i like my car and hate it at the same time
Old 07-24-2011, 09:35 PM   #30
isra
isra's Avatar
Drives: 2007 Yaris hb
if i install your pts module and i dont have the factory immobilizer do i still need to put the key in the ignition switch??
iSRA
isra is offline   Reply With Quote
Old 07-24-2011, 09:39 PM   #31
Yes. To unlock the steering column.
Old 07-24-2011, 09:44 PM   #32
isra
isra's Avatar
is there a way to do it so that i dont need the key
iSRA
Old 07-24-2011, 09:51 PM   #33
At this point not really. If I get around to adding the RFID interface to it, then that will completely take the place of the key.
Old 02-12-2021, 02:59 PM   #34
Mrdea321
Drives: Vitz 2006
Hey scoty i converted my yaris to totally push start with keyles entry.i change things
changed the complete dash board wiring of push start yaris
Smart card ecu
Smart door receiver control
Push start button
And given attached 3 antenas.
And door handles and its wiring.but im facing my door sensor wlare nit working i think due to wiring.they dont detect my key remote when i near i had to unlock manually by remote with unlock button.can anyone help regarding door wiring?
Mrdea321 is offline   Reply With Quote
GB- Push to Start , With SMART ENTRY 1NZYaris1 Items for Sale by private party 32 12-07-2011 02:10 AM
FS: Push to Start Trim Piece CTScott Items for Sale by private party 36 05-28-2010 01:42 PM
Push Button Start Stoln Europe (continental) 20 05-24-2010 08:56 AM
push start vs electric start? yaris2010RS General Yaris / Vitz Discussion 18 04-07-2010 03:20 PM
push to start engine button DIY (done) yarismo DIY / Maintenance / Service 6 03-31-2010 05:21 PM
