Old 07-28-2011, 11:18 PM   #19
Right. How hot will a 400 watt element located in the cylinder head (where it cant heat the coolant or the oil which could thus spread heat to all parts of the engine) make the engine?
Ideally you would like the engine to be at operating temperature just before starting it.
Is there a way of doing that?
park in a heated garage.
block heaters are for REALLY cold days. i remember when i had my matrix xrs, i was up north (iroquois falls, ontario) and the morning we were going to leave it was -35C. the car wouldnt even turn over the oil was so thick....it took several tries and then about 20min of idling just to warm the car up.
i had more than a few days like that when i lived in new brunswick, but this time i had a block heater. car started right away, but it still took a while to get the engine warm....
Old 07-29-2011, 10:31 PM   #20
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Bronsin,
I had a block heater (OEM) for my Yaris and definitely gained 2-3 mpg in the winter. I even had a best ever tank of 48 mpg in the fall. The engine warms up much more quickly which makes a difference with the auto. Its nice getting warm air sooner also.
The bad news-I got a year and a half out of it before it quit working. It was fun while it lasted and I have no regrets but I won't get another.
They are designed for the coldest of days, not steady use. They are a great design as such, and easily replaced/reasonably priced. My Yaris cranks right over at -20 though so no worries.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 07-30-2011, 12:09 AM   #21
auxmike
auxmike's Avatar
Weight reduction — for example the hatch and hood are made of aluminium instead of steel.
Wow, that's something. I remember the big fuss over the Acura NSX havng aluminum panels...
Old 07-30-2011, 09:16 AM   #22
bronsin
bronsin's Avatar
Originally Posted by R2D2 View Post
Bronsin,
R2
If the one I bought goes bad I'll go back to my hot plate.
