Old 08-11-2011, 10:51 PM   #1
ath
Drives: 2007 Toyota Yaris
how do I replace the drivers side rear view mirror
I just got broke my mirror off and got the replacement part, but I have no idea how to install it. Do I have to take the door panel off? Help!
ath is offline   Reply With Quote
Old 08-12-2011, 06:22 AM   #2
The door panel has to come off to get at the nuts that hold it to the door.
Old 08-12-2011, 10:04 AM   #3
Revsson
http://www.etimago.com/yaris/repairmanual/Mirror.pdf
Old 04-19-2012, 09:05 PM   #4
zydeco
Drives: 2007 toyota yaris
ok guys, where's the great advice? I also need to replace my 07 Yaris drivers side mirror... let's have some realistic how to!
zydeco is offline   Reply With Quote
Old 04-19-2012, 11:33 PM   #5
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
I saw some on ebay...........not OEM but will help your cause.
Killchain is offline   Reply With Quote
Old 04-19-2012, 11:47 PM   #6
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
There are screws in the door panel. Likely one where the door handle is, and potentially one more at least in where you "pull" the door from. After you're 100% sure the screws are all you, start pulling at and edge to pop the clips out. When you've got it mostly loose, you may have the unhook the rod that connects the door handle to the door lock. In fact, do this before doing the clips. My bad.
After that, just keep popping clips out and lift the door panel upwards and away from the door. Voila.
Loud vibration/rattling on driver's side? Ashley87 General Yaris / Vitz Discussion 3 05-30-2010 02:24 AM
Side mirror compatibility question kw531 DIY / Maintenance / Service 3 12-11-2009 10:09 AM
Replacing driver side mirror? supernes550 Cosmetic Modifications (Exterior/Interior) 4 01-26-2009 11:11 AM
