View Poll Results: Best 10mm Rear Spacer (and why)
Ichiba Wheel Spacer 10 mm 1 9.09%
H&R Trak+ Wheel Spacer 10 mm 2 18.18%
Penguin Garage Hub Spacer 10mm 8 72.73%
Voters: 11. You may not vote on this poll
Old 08-17-2011, 01:02 AM   #1
SeriousBlack
SeriousBlack's Avatar
Drives: 2007 Yaris RS HB
Best Rear Spacer
My current suspension and wheel/tire fitment:
H&R Sport Springs with Tokico HP Blues
Rota RB Rims (16X7 ET 40)
Falken Ziex 195/50/16
I want to space my rears out - ideally 10mm. I have a set of Ichiba 10 mm spacers with the extended lugs. I'm having second thoughts about them because I don't like the extended lugs they come with and am not sure of their quality vs H&R Trak spacers. I am also intrigued by the Penguin hub spacers because I like the idea of having the spacer behind the brake assembly, out of the way. I'm just concerned about corrosion etc. So, for everyone that's tried these three, please chime in and vote with comments.
The 10mm spacer to go with is:
1) Ichiba Wheel Spacer
2) H&R Trak+ Wheel Spacer
3) Penguin Hub Spacer
SeriousBlack is offline   Reply With Quote
Old 08-17-2011, 01:28 AM   #2
PG is great if you're not going to change the spacer again soon. It allows you to use your stock lug nuts, so it's also cost effective.
Of the others, H&R is a superior product, but again, if you're not going to take the wheels off on a regular basis, the Ichiba might work fine for you.
All three are available in our online store, and we are happy to ship to Canada.
Old 08-17-2011, 02:32 AM   #3
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
+ 1 for PG. No fuss, no muss, gets the job done.
Old 08-17-2011, 03:20 AM   #4
Another for the PG hub spacers. I like mine a lot.
Old 08-17-2011, 09:04 AM   #5
You've already got Ichiba so might as well use them. I've had no issues with mine other than yeah, you have to replace the lugs. Ichiba lugs are sub-par and way too long.
Go to NAPA for some new lugs. Part# is 641-2196
Old 08-17-2011, 12:10 PM   #6
^ or buy just the lugs from H&R.
Old 08-20-2011, 01:47 PM   #7
SeriousBlack
Is there a reason the 10mm PG spacers do not come with washers?
I'm assuming it's advisable to use them.
Old 08-20-2011, 02:32 PM   #8
The 10mm spacers come with washers so the bolts clear. Otherwise, no it's not necessary.
Old 08-20-2011, 05:36 PM   #9
SeriousBlack
Perhaps I'm mistaken but the MicroImage Online site advertises the PG hubspacers as follows:
These rear hub spacers come complete with everything needed for correct installation including:
*2 6061-T6 aircraft grade aluminum hub spacers (10mm or 13mm width)
*8 Class 12.9 socket head capscrews
*8 Hardened washers (13mm only)
That suggests the 10mm hub spacers do NOT come with washers. I'm going to order the 10mm ones but would like to know if I should be using washers with them.
Thanks.
Old 08-20-2011, 05:58 PM   #10
I don't know why there would be 8 of them, but I had always thought the washers were included to add some negative camber. Rubbing became more of an issue with 13mm over 10mm, especially on the passenger side tire.
Old 08-20-2011, 07:36 PM   #11
SeriousBlack
Garm?
Old 08-21-2011, 11:27 AM   #12
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Because you need 4 for each side
Old 08-21-2011, 12:48 PM   #13
Altitude
Altitude's Avatar
I have the PG 10mm spacers. When I got them they came with washers, but I didn't use them or need them. I think WeeYari has it correct.
Old 08-22-2011, 03:44 AM   #14
SeriousBlack
What size fitment/drop do you have?
Rear Hub Spacer camber? SweetRS Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 08-26-2009 05:10 PM
Penguin Garage Rear Hub Spacer Raffle!! Penguin Garage General Yaris / Vitz Discussion 27 06-30-2009 02:05 AM
Ideal Spacer Width For the Rear? tk-421 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-27-2009 06:59 PM
