Old 03-29-2009, 02:09 PM   #73
LOF, I posted a second excel file just before your post with more spirited acceleration, Open Loop seems to kick in at 75% throttle and above, though this should require some more testing
I'm not sure you can get injector info off the OBD bus?
But what do you think of that URF AF sensor device I posted earlier? By tweaking the response from the sensor it would have the ability to affect the short term fuel trim and thus richen it up a little as needed. I'm just not sure how the rear O2 sensor will react to that and cause trouble...
Old 03-29-2009, 02:23 PM   #74
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I saw that log, he is going too slow. We need long WOT pulls in a single gear, like you would do on a dyno.
Injector info is there on the OBD, the software just needs to be able to read it.
The problem with adjusting the fuel trim is that the car will readjust it back. The car can adjust fuel trims around +/- 25% before a CEL is thrown. Like I said, I have never really seen one that truly works. The car is constantly learing around your changes.
The rear 02 does nothing in relation to fueling. It is only there to insure the pre cats are functioning.
Old 03-29-2009, 03:04 PM   #75
hmmm i believe those are stored values when you have a CEL, not the dynamic values like you've logged so far...
Old 03-29-2009, 03:14 PM   #76
right right gotcha... well this is way over my head, and I need to get to bed, so I won't be much help
Old 03-29-2009, 10:42 PM   #77
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
some links i found but im in the process of reading them
http://www.autospeed.com/cms/A_2388/article.html
http://autospeed.com/cms/A_2695/article.html
Old 03-29-2009, 10:54 PM   #78
largeorangefont
Break'em off some.
LOF i got no engine mods so far and i need a longer straight with no one in front of me to do it safely and properly. ill try and do a run like you said from 2000k and up in each gear.
That would be great. Even seeing what a stock car does will be very helpful. Is there anything on the PID list relating to the fuel injectors?
Your list for that other pull had all the stuff we need, except for injector duty cycle or pulse width.
Old 03-30-2009, 02:57 AM   #79
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
hey Guys
FYI , i chatted to a few guys with the SMT6 chip here in RSA, and they werent all that happy with the chip and have since changed to UNICHIP , im not sure if this is isolated senario's but just thought i'd give you guys the heads up.Problems reported are fueling and idiling , but like i said , could just be the cars that were tuned , i will keep an eye out for more info.
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 03-30-2009, 03:40 AM   #80
thanks for the heads up, aucorium...
Today I tested something... As you might know I have a basic AF gauge hooked in to the factory sensor, it's not all that useful, but can show me when the car goes to open loop (in closed loop the AF ratio keeps oscillation rich-lean-rich-lean, as this is the most efficient way for the catalyser to work, wile in open loop the needle stays still). So, leaving the house, I shifted up to third at a rather low speed and put the throttle down. The engine was too low in RPMs to gain any sensible speed, but sure enough, AF needle pegged itself at 14:1 after a second, and stayed there until I let my foot off the gas.
I should have a chance to get on the highway late tonight and repeat the experiment in other gears/conditions, but this is quite promising!
Old 03-30-2009, 05:25 AM   #81
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
mmm , that seems to show some promise , nice one!! let us know how the test goes.
JDMtuner
www.jdmtuner.co.za
Old 03-30-2009, 05:53 AM   #82
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
FYI
i am busy researching us a Dastek Uni - Q chip , apparently this works on the yaris , it worked on my buddies honda fit 1.5 , so im gonna see if i can get a plug and play setup , as the guys here claim to have one for the yaris , i will keep you posted.
here is the chip:
http://www.dastek.co.uk/features_unichip.htm
it can control VVT aswell !
JDMtuner
www.jdmtuner.co.za
Old 03-31-2009, 02:35 PM   #83
here it is in excel format with in-cell bar graphs to show the relations a bit better
http://dl.getdropbox.com/u/691356/FastRun.xls
Old 08-17-2011, 04:54 PM   #84
lammy29
Drives: Yaris
any updates after all these years?
lammy29 is offline   Reply With Quote
