Old 08-21-2011, 05:24 PM   #1
08blackyari
slowpoke
Drives: 08 blk LB manu. pwr opt & cld
Bent Rim!! with pic
So, last night I was at a friends place and we were checking out his girl's new Fiat 500...so we took it for a spirited sprint around their apartment complex. Next thing you know we get into my 08 hatch and are speeding around. One turn led to another and I slid into a curb, smashing the hell out of my rim. The bumper and all seemed fine but the rim is so bent that I get a wheel shake when I drive it.
Does anyone know id any 15 4-100 steelie will support our hub caps? Because I found one that may be the right size, the guy is unsure if it is 15 x 5.5 but is sure its a 15. Any help would be awesome.
-Sam
08blackyari is offline   Reply With Quote
Old 08-21-2011, 08:31 PM   #2
YAR1S
YAR1S's Avatar
LMAO.
-Jen <3
Old 08-21-2011, 09:29 PM   #3
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Holy bent lip batman that suck
Originally Posted by sw07gt
Old 08-21-2011, 10:18 PM   #4
YarisSedan
Drives: 08 Yaris Sedan
Wow thats amazing it still holds air. Dismounting that tire could be a issue to swap to the new rim. May slightly damage the bead. Also definitely have your alignment checked once its all finished its garenteed to be out.
Old 08-21-2011, 10:36 PM   #5
yaris2010RS
yaris2010RS's Avatar
lmfao, wow
u hit that curb hard lol
+1 check ur alignment
Old 08-21-2011, 11:52 PM   #6
08blackyari
slowpoke
Thank you, all. Thank you. It was tough smashing into a curb but, as always, I found a way to succeed.
I drove about 20 miles on the freeway after that, at about 65 mph, and the steering wheel was shaking a bit (which isn't normal for my car).
I haven't driven it since and have already ordered a new rim and a set of new tires (I was due since they were balding with 52k miles on them). The car drifted a bit to the right but nothing crazy. I'll see whats up with the alignment after the new tires are installed.
Anyone have an idea of what an alignment job should cost?
Old 08-22-2011, 05:12 AM   #7
bronsin
bronsin's Avatar
It was not possible to align my 1980 Subaru Hatchabck. You just put it together and thats what you got. Except for the tie rods of course (toe in) We have an alignment specialist in Camden Schemps. That guy was an expert. He always told the truth.
I suspect all modern cars arethat way now. Although I dont know it for sure. I DO know my buddy years ago had "problems" with his alignment so he took it to be aligned. After words he said "Wow they fixed it THE CAR DRIVES LIKE NEW!"
Then I pointed out none of the well rusted fasteners that had to be loosened to adjust the steering were touched at all.
So much for alignments.
I suspect alignments are like synthetic oil.
A GREAT BIG LIE!
Old 08-22-2011, 12:30 PM   #8
TOLMACH
Drives: soarer
A GREAT BIG LIE!
I guess you just need to find the proper mechanics shop to do the alignment.
Old 08-22-2011, 02:31 PM   #9
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Hate to say it, but that's what you get when you speed around an apartment complex.
Black_griffin6 is offline   Reply With Quote
Old 08-22-2011, 02:33 PM   #10
^ I don't think you hated to say that.
Old 08-22-2011, 02:50 PM   #11
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
as slow as it is i didn't even read that......
Old 08-22-2011, 08:37 PM   #12
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Alignment most times if nothing is broken is about $100,you should get a printout of what the alignment was when it started and what it was when it was done.......
If you bent a control arm or tie rod the cost goes up for parts and labor.....
Got lucky with a bent rim and trashed tire.....slow down and stay around a while the planet has a lot of neat things to do and see.....lol
Old 08-22-2011, 09:07 PM   #13
YarisSedan
A lot of times something could be slightly damaged or out of wack but still can be corrected with alignment. I am a alignment tech at a bodyshop and see cars daily that are in colission that you have a range of specification and a new car would be somewhere in the middle giving you either way movement slight adjustment. The cars after colission will take all the way max range one way or the other to correct and its barely within limit. So obviously something is slightly bent that may not be visually apparent. However according to insurance its within range so we have to let it go.
A GREAT BIG LIE!
I work on mostly european cars at my shop and all of them have adjustment for camber and toe. I just did a 87 porsche the other day that had adjustment for camber toe and even caster.
The yaris i know has no adjustment in the rear unless you use shims. The front is only toe. Camber is only adjustable by means of a camber bolt or grinding the stock bolt to make it a little smaller to allow strut movement.
Old 08-22-2011, 11:32 PM   #14
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
I have 47,000 miles and replaced 4 rims and I think I need another
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 08-23-2011, 12:06 AM   #15
08blackyari
slowpoke
Thanks, Dad. I only wish you were there before hand to lecture me
Old 08-23-2011, 10:45 AM   #16
Zaphod
Drives: Big Yellow
No, really ... you shouldn't need anyone to tell you that.
Zaphod is offline   Reply With Quote
Old 08-23-2011, 05:46 PM   #17
Black_griffin6
Old 08-23-2011, 07:09 PM   #18
"Son... you never listen...."
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Bent rim repair costs!!!!! yarisnewbie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-26-2010 07:36 PM
I NEED A 15" STEEL RIM AND OEM TIRE robkay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 12-18-2009 10:57 AM
Help me pic my best pic... Sabretooth Photo-Video-Media Gallery 17 06-14-2009 07:52 PM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 03:25 PM
