![]() ![]() Drives: 07 yaris hatch Join Date: Jul 2009
07 wont start, no dash lights, battery good
07 LB wont start, does not turn over even, no noise. All other features, radio, overhead light, headlights still work fine. Yet only headlight indicator is only dash light that will come on (when i turn on lights), otherwise no dash lights, carwont turn over. It will push start
Got boost? |
Battery and alt are new, been in for about 1 month
Got boost? |
![]() ![]() Drives: 07 yaris two door liftback Join Date: Jul 2011
starter bad? or wire to the starter?
thats what i hope, but why no dash lights?
Got boost? |
Have you checked all the fuses? in the car and under the hood.
AM2 fuse in the under hood fuse panel.
And the winner is.... CTScott. AM2 Fuseblown. swapped and I'm ok now. Thanks soooooooo much guys. Its so painful to be told by the dealer that they wont even look at my car with the s/c on it.
Got boost? |
CTScott, how did you find it? Do you have a service manual or alldata?
Got boost? |
Why did it pop in the first place I wonder....
Got boost? |
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
There is a sticky thread at the top of this section.
It has links to the 2007 service manuals in it. |
AM2 is the main fuse for the ignition circuit. Anything using ignition switched power could pop it if shorted, or if you have too much hung on that circuit for the fuse, that could also cause it.
#12 | |
Drives: Yaris Hatchback 2007-Automatic Join Date: Jan 2016
Spent almost all day to figure-out...changed relay and all (stupidity checked AM2 in rush too)...You are genius...StayBlessed I have a question, what is the reason for that... I hope coz of remote starter installed in car..?? |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 02:15 AM |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 03:02 AM |
| Good place to find constant & switched 12V behind dash? | atebit | In Car Entertainment + Electronics (audio / video / alarm) | 16 | 03-03-2009 11:40 AM |
| Brighter Dash lights, there is a switch??? | mgthompson | General Yaris / Vitz Discussion | 14 | 04-04-2007 09:51 AM |
| CLUSTER LIGHTS WENT OUT | Go4th | DIY / Maintenance / Service | 23 | 01-25-2007 12:37 PM |
