Old 08-24-2011, 01:22 AM   #1
RogueYaris
Drives: 2015 Abs Red
Simota SRI rubs driver side headlight
My Simota SRI is such a tight fit that the cone is packed against the driver's side headlight.
I'm wondering if anyone else had this issue and what they did to alleviate it.
Yes, I tried the search function but I couldn't find anything relevant.
RogueYaris is offline   Reply With Quote
Old 08-25-2011, 06:21 PM   #2
RogueYaris
bump, nothing?
Old 08-25-2011, 06:30 PM   #3
Pictures would probably help a lot.
Old 08-26-2011, 09:19 PM   #4
RogueYaris
The cone is touching the driver's side headlight.
It's not a full connection of the whole cone, just part of it closest to the front of the car.
Old 08-27-2011, 12:28 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
you're sure everything is pushed together tightly?
Old 08-27-2011, 02:44 PM   #6
RogueYaris
Ok, here's a question:
Is it supposed to be a metal to metal contact between the intake and the engine?
Old 08-27-2011, 06:25 PM   #7
how about a picture of the other end?
I think you might be able to jam that filter on a little bit more?
It may just be a tight fit on the sedan; I know these work fine with the liftback.
It also doesn't look like there's a problem in terms of function.
Old 08-27-2011, 11:51 PM   #8
RogueYaris
It's on a liftback :p and functions great.
I'm just worried about scuffing up the driver's side headlight.
I know, shouldn't be a big deal in terms of resale value, but you never know.
Next time I'm tooling around in my engine, I'll try to snug things up even more but I thought everything was tight when I put it in.
Old 08-28-2011, 10:31 AM   #9
Lil Abner
Drives: 2009 3dr LB Manual
No, I don't think you want the intake pipe to be touching the aluminum throttle body. So you could try to pull that one out a bit. But then loosen up the other connection points and try to push those sections closer together.
Old 09-01-2011, 04:16 AM   #10
RogueYaris
It's not touching as it is.
Been a lazy bastard since I got back and haven't done anything with it yet.
Then again the game I'm playing right now is down for maintenance.
Great time to look like a crackhead and tinker with my car.
Old 09-01-2011, 02:40 PM   #11
^ LOL
Old 09-01-2011, 04:51 PM   #12
RogueYaris
I just went out and tried shoring things up but I don't really have any space left.
Is there any sort of lubricant that I can put on there that would make it slide easier and not mess up the engine or rubber?
Old 09-01-2011, 05:45 PM   #13
Bluevitz-rs
^ silicone spray is fine to use on rubber parts.
Old 09-02-2011, 12:12 AM   #14
Lil Abner
Yeah, unless you put too much on and it gets into the engine and MAFS.
You could try a little bit of water and some good elbow grease.
Old 09-02-2011, 05:58 AM   #15
you'd have to spray A LOT of lube on there to have it soak thru the filter and mess up the MAF sensor...lol
itll be fine rubbing the headlight...
Side of headlight reflectors regal Cosmetic Modifications (Exterior/Interior) 7 04-13-2009 04:26 PM
WTB: Drivers Side Headlight LiftBack Saggio Willing to Buy by private party 7 03-10-2009 03:21 PM
Driver side foglight trim gwasabi Willing to Buy by private party 3 03-03-2009 04:11 AM
Replacing driver side mirror? supernes550 Cosmetic Modifications (Exterior/Interior) 4 01-26-2009 12:11 PM
The Driver Side River Nutzoids General Yaris / Vitz Discussion 7 12-14-2006 02:11 AM
