Old 10-20-2011, 01:31 AM   #1
Dylanwhat
Drives: Yaris Liftback
Exclamation 2008 Yaris Buzzing
Hey guys!
I have very limited car knowledge and I need some help.
My 2008 Yaris Hatchback has been making a buzzing sound for a while now. It almost sounds like there is an RC car in the engine. I feel like the sound is coming from the alternator. Spraying belt dressing on the belt made the sound quieter but it's still quite loud. I wanted to see if you guys have any experience with this because I sure don't.
Also, would this effect my performance? I feel like accelerating is much slower than normal and when I let off the gas on the freeway it slows down drastically.
Here's a video
http://vimeo.com/30833879
Dylanwhat is offline   Reply With Quote
Old 10-20-2011, 01:38 AM   #2
Astroman
Modded Moderator
Astroman's Avatar
Wow that does sound bad. The video helped. Try this: get a 1x2 wooden stick long enough to put against various parts of the engine components and put your ear up against the other end. This kind of works like a stethoscope and will help pinpoint what part might be the problem. It could be the alternator or water pump. Figure out what part it is and take it to a place like autozone (or pepboys?) and tell them what part it is and show them the noise it makes.
Hope this helps, and get that fixed asap.
Old 10-20-2011, 05:26 AM   #3
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
The fact that the smoke is gone, when the added gas?
I like very much travel
MickZEL is offline   Reply With Quote
Old 10-20-2011, 11:52 AM   #4
Dylanwhat
I used some long hosing to isolate the sound. It seems to be coming from the alternator. I feel confident that I can replace the alternator myself.
Would this explain my performance issues?
Should I buy a remanufactured alternator or a low milage alternator. Also should I get it online or locally?
Thanks so much guys!
Old 10-20-2011, 12:06 PM   #5
That definitely sounds like the alternator has a bearing that is on its way out. Either low mileage or reman should be fine. You can check locally at junk yards using www.car-parts.com which is an online database for junkyard parts. Try to get a 2009 or newer if possible, as the 2007 and early 2008 ones are prone to an issue with part of the voltage regulator corroding.
If the bearing is bad enough to add rotational resistance, then it could definitely be your performance issue.
Old 10-20-2011, 10:15 PM   #6
Astroman
Modded Moderator
Astroman's Avatar
+1
Old 10-20-2011, 11:09 PM   #7
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Lots of money made by the "rebuilders" by taking a perfectly good alternator and replacing the bearings. It is the method they use to replace the bearings that assures a return customer!
I replace alternator bearings by pulling the old ones, then burnish the shaft so that the new ones slide on, not press on. Takes a bit of time, but the bearings will last far longer, and take less power to turn.
Tags
buzzing, repair, sound, yaris
2008 PeterPoop's Turbo Yaris 5 speed Base model. PETERPOOP Cars for Sale by private party 32 07-18-2011 04:34 AM
A few OEM 2008 Toyota Yaris parts white_rice Canada 0 03-20-2010 06:23 PM
2008 yaris update Runner59 General Yaris / Vitz Discussion 1 08-14-2007 10:44 AM
