Old 11-21-2011, 08:10 PM   #1
Connoisseur_of_fine_cars
Oh what a feeling
Connoisseur_of_fine_cars's Avatar
Drives: Yaris
Another Pet peeve
I thought the instrument panel was really cool. But there is a safety problem. At dusk, not dark enough to see your own headlight light but dark enough that others can't see you w/o your headlight lit, there's no indication that you don't have your headlight lit. Because Yarii instrument panel is always lit. With old school technology, you 'll notice easily that you can't see the instrument panel because its dark, and that's your cue to turn on the headlight. Yarii has no such cue. Almost got into a bad wreck today because of this. I now think Yarii instrucment panel is not very cool. Technology. One step foreward, two steps back.
Connoisseur_of_fine_cars is offline   Reply With Quote
Old 11-21-2011, 08:19 PM   #2
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Huh?
Next to the CEL... looks like a light bulb with light coming from it.
If it's illuminated... your lights are on. If it isn't... your lights are off.
Old 11-21-2011, 08:37 PM   #3
A-Dingo-Ate-My-Baby
Drives: yaris
this ^
also you can dim the dashboard lights
yours is probably cranked up to the notch, making it full bright
roll it back halfway, then turn the headlights on ...instrument panel will dim
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 11-21-2011, 10:26 PM   #4
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
I can see mine just fine and it's set below 1/2 brightness. Turn it up so you can see your indicator lights. Sounds to me that the only safety issue in your car is the loose nut behind the wheel.
Stove is offline   Reply With Quote
Old 11-21-2011, 11:22 PM   #5
Oh what a feeling
Drives: Yaris
My grammer must be really bad because yall guys all missed my point.
Let me try it again with an example. I get into car when the sky is bright sun light. I drive and drive. Of course, my headlight is off because the sky is bright. The instrument panel is fully lit; this cannot be dimmed when headlight is off. After driving for many hours, the sky is loosing day light. Other people are starting to turn on their headlights. I'm driving and look down at the instrument and can see everything clearly. There's nothing to indicate my headlight needs to be turned on because everything looks good and bright, whereas in an old school instrument panel, everything would be dark and unseeable. I drive along, and a guy in other car only looks for bright headlight in this low light condition and drives in front of me. Ka-pang!
You get it now? Yarii need some kind of light sensor. When the outside gets dark, a bright red light will blink until headlight is turned on. I'm serious; I've almost gotten into a wreck twice because of this.
Old 11-21-2011, 11:27 PM   #6
Hershey
" Sounds to me that the only safety issue in your car is the loose nut behind the wheel."
And members wonder why there's no activity .
Old 11-21-2011, 11:32 PM   #7
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
Solution: turn the little knob at the end of the turn signal stalk all the way to the on setting before dusk. (haha, sorry)
My instrument cluster isn't always lit. Maybe they changed it in a later year than yours.
NZ-FE Vios is offline   Reply With Quote
Old 11-21-2011, 11:55 PM   #8
A-Dingo-Ate-My-Baby
Drives: yaris
the light sensor is called a 'driver'
how hard is it to turn the lights on ?
you want automatic lights, buy a controller and install one, or get a camry
How can this be a peeve or safety problem with the Yaris ?
fewer cars have automatic lights than those that don't
Old 11-22-2011, 12:05 AM   #9
Stove
Stove's Avatar
Humor... deal with it.
I would still argue that it isn't a safety problem with the car (or any car that is set up similarly) but I understand that it is difficult to tell if the lights are on at times. During those times look for the headlight indicator in jpmck03's picture or just reach down and check the knob to see if your lights are on if you can't remember if you turned them on or not. I don't see how a warning light to remind the driver to turn their lights on is at all necessary.
Old 11-22-2011, 12:06 AM   #10
The Limo
On my 07 sedan my headlight "light" on the dash is where the "cool" light on the dash is in the second post. Don't know if that is because it is a sedan or maybe a Canadian thing. I always check at dusk to make sure that light is on.
Roy
The Limo is offline   Reply With Quote
Old 11-22-2011, 12:09 AM   #11
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
...After driving for many hours, the sky is losing day light. Other people are starting to turn on their headlights. ... There's nothing to indicate my headlight needs to be turned on...
Isn't the fact that it's getting dark out a pretty good indicator to turn your lights on?
Or maybe the fact that other drivers have their headlights on?
... there is a safety problem ... with Yarii instrument panel ...
I don't think that this is a flaw with the vehicle or a safety issue for Toyota to worry about...
So, they need a light to remind you to turn your lights on when it's dark out?
What next, a light to remind you to turn your wipers on when it's raining?
Or a sensor that tells you that your back window is frosted over, so you should turn your defroster on so you can see?
Old 11-22-2011, 12:20 AM   #12
A-Dingo-Ate-My-Baby
Drives: yaris
^ some cars have all that stuff, they cost a biiiiiiit more than a Yaris...>$100,000
Old 11-22-2011, 01:42 AM   #13
Oh what a feeling
Drives: Yaris
Arghh!!! I'm talking about at dusk.
Old 11-22-2011, 01:45 AM   #14
Oh what a feeling
Drives: Yaris
Mine is 2011. Mine is always lit. Looks like the Sedan yaris has the tradition instrument cluster, like a Camry. The LB Yaris has the fancy new always-lit instrument.
Camry
Sedan Yaris
LB Yaris
Old 11-22-2011, 01:58 AM   #15
I look at my climate control knobs as a reminder that my lights are on or off...
Old 11-22-2011, 04:17 AM   #16
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I think there's an app for that...
Old 11-22-2011, 07:02 AM   #17
w7ist
Drives: 08 yaris lb
You could disable your DRL so that you can't see as it's getting dark. That is halfway there to being more 'old school'.
w7ist is offline   Reply With Quote
Old 11-22-2011, 08:52 AM   #18
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've had way too many people pull out in front of me during the daytime, so I always keep my lights on. To compensate for the dimmed panel lights, I turn the brightness knob all the way up. Going past the bump at the top end puts the dash lights on full-bright, so they can be more easily seen.
I've made turning on the lights part of my pre-driving sequence, so I don't even think about it when I crank the car up. I.e. foot on break, clutch in, gears in neutral, key in, crank, clutch out, lights on, music on, check mirrors, adjust climate control, etc. etc.
new pet pic thread puetato89 Off-topic / Other Cars / Everything else Discussions 186 04-16-2013 03:23 AM
MI pet rat cali yaris Off-topic / Other Cars / Everything else Discussions 11 11-12-2011 08:52 PM
