Old 12-11-2011, 09:14 AM   #1
menz
Drives: yairs blue 2007 automatic 1.3
car is unstable and vibrates like a washing machine
For few months now, I have been noticing that my car has turned unstable and vibrates a lot. I had a lot of dents on the wheels, so I fixed them and did the alignment and balance and the weights. So it became better at lower speeds but on high speeds around 80 mph i notice that it starts to shake really bad at 100 mph its awful, I can hear the coins rattles in my glove compartment and everything. I can feel the irregularity coming from underneath me like something in the suspension on the driver's side. One of my friends told me it could be the ball joint or bushings. Planning on taking it to the shop next weekend but thought I would get advice from here first. Thanks I am trying to explain this I hope the info helps make you understand.
BTW I used to drive the car on unpaved roads a lot that's why I had dented wheels. I also hear some kind of squeak when braking at low speeds and the car vibrates more when I brake at high speeds. I checked the brake pads and they were fine.
menz is offline   Reply With Quote
Old 12-11-2011, 12:06 PM   #2
A-Dingo-Ate-My-Baby
Drives: yaris
you need new wheels at this point. yours are beyond being able to balance them
also need stock size wheels with stock profile tires to be able
to eat the bumps and not dent the wheels
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 12-11-2011, 05:56 PM   #3
menz
I have changed the tires 15 thousand kilometers ago and the denting happened in the long life of the car and they are stock
Old 12-12-2011, 01:24 PM   #4
petyanca
Drives: 09 LB, 3 door, auto
Do you drive 100 mph on unpaved roads ?
petyanca is offline   Reply With Quote
Tags
ball joint, brakes, bushings, suspension, vibrations
