#253 |
That explains the boost creep. You can pretty much nix that (and make more power sooner) with a controller.
#254 |
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
Naw it was the open down pipe. It created a situation where it was easier for the exhaust gases to pass by the wastegate. And also not enough exhaust was flowing tru the dang thing to begin with. The hole was very small. I will upload the pics later today when I get off work.
#255 |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
I'm with Garm on this one. Boost creep or no boost creep - get a controller. If you set it up correctly it greatly aids in spooling. You do seem to be obsessed with getting as much power as possible
![]() Speaking of - are you still pushing 10 psi? If so how many miles has it been? |
#256 | |
Here are some pics of the porting job. Not bad for my first time. O sorry for the big pics
#257 |
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
porting the waste gate is probably the best way to reduce boost creep. the other setup is to get a low psi spring and use a boost controller, but you can still get creep with that setup if you cant get the air out of your wastegate. i bet that porting helped!
#258 |
Looks pretty thin on the one edge. Did you leave enough material there for the door to make a seat?
#259 |
Awesome!
#260 |
Yup it's just enough material left. It spools about 300 rpm faster than before. And sounds like a jet lol. The turbo is almost as loud as my exhaust... I need to get a vid up one of these days.
#261 |
Awesome :)
#262 |
2ZR swap. DO IT! Ask how!
I think you may need to swap the final drive to get more torques on your wheels, eh Garm?
#263 |
yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes yes
#264 |
Need help to pick a new engine management. Scince I am trying to get the most out of this engine stock I need to upgrade form the Aem fic. Throw some names at me
#265 |
AEM EMS?
GReddy Ultimate? |
#266 |
Also what ignition upgrades should I be considering? Just coils? I already have one step colder plugs.
Hmm not sure about the ultimate with the cost of all the things you need to get it running the way you want it. You might be up there in cost with the standalone. |
#267 |
http://shop.microimageonline.com/All...-1NZX1-100.htm
If I was building my Yaris, this is the management I would choose - without a doubt. IT UTILIZES ALL OF THE STOCK WIRING/SENSORS. Just having a harness made for standalone management is probably over 1K in labor alone. |
#268 |
that might be nice but who am i gonna get to tune that beast?
#269 |
I would imagine anyone that knows a decent amount about engine tuning should be able to pick up on using the software pretty quickly. Realize that most engine managements do the same thing - manage the engine lol. The biggest difference is always going to be how it's implemented.
Don't quote me on that though. |
#270 |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Don't worry about ignition, the factory packs are good past 30psi of boost. I use Haltec Sprint 500, factory wiring harness. Just made a patch (plug and play) harness.
Ptuning.com |
| Turbo Project Yaris TS 1.8L | CASTREX | Yaris TS Talk | 40 | 08-21-2009 11:24 AM |
| HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 12:59 PM |
| Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 01:30 PM |
| delayed turbo project... | joey1320 | Forced Induction Forum | 8 | 09-27-2007 12:18 AM |
| Vitz Rs turbo vs U.S. Yaris add turbo? | weaponrcamry | Performance Modifications | 18 | 08-09-2006 09:45 PM |
