Old 03-13-2007, 01:25 AM   #1
Black Yaris
der Zeck
Black Yaris's Avatar
VVTi Managment Greddy
http://cgi.ebay.com/ebaymotors/GREDD...98233123QQrdZ1
Have not seen one of these b4, just wanted ya'll to check it out
Old 03-13-2007, 01:30 AM   #2
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Interesting
Old 03-13-2007, 01:39 AM   #3
ChinoCharles
Drives: LB
http://www.perfectpowerusa.citymax.c...ge/2003728.htm
Old 03-13-2007, 08:33 AM   #4
punch
punch's Avatar
we have used this with the turbo pt cruisers in the past, nice product.
punch is offline   Reply With Quote
Old 03-13-2007, 10:25 AM   #5
Dragonacc
Drives: 07 Yaris LB, 70 Mach 1, 84 5.0
Adding extra injectors is a bandaid, real control lets you flash the stock ecu any way you want it while maintaining OBD functionality (Something standalones can't do).
Dragonacc is offline   Reply With Quote
Old 03-13-2007, 12:01 PM   #6
ChinoCharles
Drives: LB
Adding extra injectors is a bandaid... unless one of those injectors happens to be hooked to a tank of nitrous. Then its more like a full body cast.
Old 03-13-2007, 12:06 PM   #7
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
The E-manage should come with any TURBO kit you buy for your car... If you drop around $3,000 and don't get one... you’re getting ripped off...
You don't need it without Forced Induction... If you want something for Naturally Aspirated Yarii... look at the:
http://www.jscspeed.com/index.html?/.../pe_camcon.htm
Nutzoids is offline   Reply With Quote
Old 03-13-2007, 12:38 PM   #8
Dragonacc
Well there is that.
Old 03-13-2007, 06:12 PM   #9
cdydjded
Drives: Yaris LB Turbo
Nut: find me a kit for under 3K with a emanage & intercooler & I will buy it for you. You aperantly have no experiance with turbo kits. I am not trying to insult you, you just need to be more realistic with your posts. Turbo kits cost money period.
Old 03-13-2007, 06:33 PM   #10
Nutzoids
Nutzoids's Avatar
Thanks man... i'll take this one if your buying!
http://www.epsturbos.com/SCION-STAND...BO-TS25B1.view
It's for a Scion Xb... but I'll convert it...
When I get home to my Home PC... I can get maybe 5 or 6 other sites that show eManage for under 3 grand... but this is the best I can do from work...from memory...
Since ZPI and Why are the only 2 that I have found that make Turbos for the Yaris... and they are still in production... I have to go with Scion as a Determaning factor...
ZPI:
http://www.zeropointindustries.net/s...roducts_id=211
WHY:
http://www.whyindustries.com/store/p...products_id=51
ok...ok your right... These last 2 are a bit more then $3,000
I have been mistaken before... But anything is Possible... if you just look around!
But I guess your right... I aperantly have no experiance with turbo kits. Not yet... give me a couple more months! and I will be able to say that I have baught one...Installed one... and drive a car with one!
Old 03-14-2007, 06:35 PM   #11
cdydjded
Good try Nut but that first turbo does not have a emanage:
What the TSI Extreme Kit comes with:
1 Garrett Turbo w/internal wastegate @ 6psi
1 High Nickel Composite Cast Exhaust Manifold
1 Downpipe
1 Fuel Pressure Regulator
1 MAP Unit
1 Oil Return Line and Fitting
1 Air Filter w/piping
1 Injection Control Unit w/Turbo Timer
1 Injector Interface Block w/Injectors
1 Blow Off Valve
1 High flow intercooler w/mounting hardware, pressure tubes, rubber hose connections and clamps
Comes with everything necessary to install! Kit is a complete bolt-on!
Good luck converting it, nothing from the xb will work.
Old 03-14-2007, 06:37 PM   #12
cdydjded
And the WHY industries also has no emanage.
Old 03-14-2007, 06:46 PM   #13
Nutzoids
Nutzoids's Avatar
ZPI still has one...for a little over $3,000... So I was $500 off... But in my defense it was on sale last month for 3Grand! That just shows how much ZPI rocks...
Alright so I'll make you a deal... I won't make you buy one for me... If take back your statement about me not knowing what I'm talking about!
I have done my research on Turbos, but I am no Expert... But you have to admit I was close!
Old 03-14-2007, 08:00 PM   #14
Dragonacc
Did your research huh? How does the hot side of a turbocharger actually spin then?
(Just giving you a hard time.)
Old 03-14-2007, 08:50 PM   #15
H2XcapePod
Drives: 07 Yaris LB
congratulations on wetting each others whistles gentlemen!
I believe the real concern is how much performance you can squeeze out of that Cam Controller from JSCSpeed. Anyone have any experience with them?
H2XcapePod is offline   Reply With Quote
Old 03-14-2007, 08:58 PM   #16
acrbill
Drives: Polar White Hatch
Didn't you guys read that huge post on the Scion forums where the guy tried several mods and dynoed the results? He tried the camcom thing and could not make any power. IIRC the stock ecu kept fighting it. Perhaps the Greddy unit works better?
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline   Reply With Quote
Old 03-14-2007, 08:58 PM   #17
Dragonacc
Maybe none, changing the VVT setting "might" gain some power, but you'd have to play around with them on a dyno to know for sure.
I know on newer Miata's changing the VVT setting did almost nothing on engines that were only mildly modified.
My gut tells me it'll be the same here.
If you want to gain some power leave the VVT alone and lean out the A/F mixture, and tune the ignition setting for 91-93 octane fuel.
Old 03-14-2007, 09:39 PM   #18
H2XcapePod
Drives: 07 Yaris LB
I hadn't seen the one over on the Scion forums...however I stumbled upon a Celica forum and they were buying them up like hotcakes. I don't recall if it was consumers or the company, but someone had posted some dynos gaining about 10-15 horses. upon further inspection...I'm pretty sure the company posted them...and we all know how that can go!
GReddy prototype = Free Exhaust! Chris_Lum California 30 02-27-2007 11:13 PM
Greddy xB Supercharger Papamoon Performance Modifications 2 02-09-2007 04:08 PM
Opion Wanted on Greddy Infometer.... kdctuning General Yaris / Vitz Discussion 5 01-28-2007 06:49 PM
Will the XA Greddy cat-back fit? Black Yaris Performance Modifications 8 12-23-2006 11:43 PM
Greddy Intellegent Informer the_saint In Car Entertainment + Electronics (audio / video / alarm) 0 11-12-2006 05:26 PM
