#307 |
Drives: yaris sedan 2008 Join Date: Aug 2011
i did an abs at dixie toyota for 1000 cad right in the thick of a january snow - they changed wire and the calipers or so i think - sometimes when it rains i also have an engine check - surely toyota canada does not not give a damn of canadian weather for our 20000plus money - toyota was the best, now falling way behind ford, hyundai et al.
They need take responsibilities of their mess over n over, Toyota Engineering My Ft! |
#308 |
TOYOTA please take notice!
This is why my lights (ABS + BREAK) turn on! (I'm guessing) I did solder them directly and cover with a Sealant. We'll see how much they hold on! ![]() ![]() D.
. CLA 250, 4MATIC |
#309 | |
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
Just another nail in the coffin proving my theory that the Yaris is the furthest thing ever from the reliable Echo... derickveliz2: I was under the impression the hub had to be removed to access these wires. Yay or nay? |
#310 | |
You need a small screwdriver or something to help get the clip off if I'm not mistaken. It was a while ago now. |
#311 | ||
Yes and No... It helps to fix them if you remove the hub, but 1 side had 2 wires broken all ready like you see in the pictures above, the other side only one wire was broken. I did remove them both. no access to the wires from the inside of the hubs, it's where the wires go into the hub. I hope I didn't confuse you? Quote:
"NO MORE LIGHTS FOR ME!!! and I spend nothing but my time. Lets see when they will turn on again! D.
. CLA 250, 4MATIC |
#312 |
![]() ![]() Drives: 2007 Yaris Sedan Join Date: Oct 2008
Just a friendly reminder to check on your sensors if you're changing over to your winter tires in the next three weeks or so. I know I'll be giving them their annual cleaning and application of dielectric grease.
It's a lot easier to clean them now, before the temperature gets into the negative double-digits! |
#313 |
Quebec greekster
Drives: Yaris Hatchback Join Date: Aug 2011
I just want to say, that whichever the problematics with sensors, specially ones around wheels, underbody, try lubing them with dielectric grease, or grease, whatever. Cause no matter how many times you change em, water, ice, salt snow.. aint helping.. and seems Toyota made a big bobo with Yarises or othr model sensorabilia.... up to date, i have changed, ABS sensors, Alternator Sensor, The radio ( a lil transistor thing burnt inside it) , and now im on my Camshaft sensor... Yeeee i wonder wich sensor will go next!? good thing i get parts cheap or free, and make em myself.. when its sunny... and aint raining or snowing.....
Note, before changing your ABS sensor, clean the connectors,and add dielectric greasse they should work just fine. IF pin isnt brocken from rust. |
#314 |
![]() ![]() ![]() Drives: 2007 Yaris Hatch Join Date: Feb 2007
My brain is hurting after trying to read your post ^^^^^.
#315 |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2006
Yeah I had this problem last winter, the lights would come on and then go off a few days later, after winter it had not come back on, we still are waiting for our first snow here in Kentucky, and I feel it will start coming back on... I have 198,000 miles on my vehicle now, should be at 200,000 by end of January.
#316 |
![]() Drives: 2008 yaris Join Date: Feb 2011
I am back after almost a year and with good news. Since following the instructions here about opening the connection and cleaning the leads and then plugging it up with dielectric grease I have not had the light come on, and I have not lost my ABS brakes.
Big thanks to those of you who posted pic's and explained this easy fix. Sad to see Toyota not putting a recall on this since it is a very dangerous situation. A couple times I would have ABS and then poof lost it when the lights came on, pretty scary stuff when you are skidding along a highway with cars on front and behind you. So if you have not tried this fix, TRY IT!!!! My independent garage did it for free when I had them switching my winter tires to my summer tires. Even if you DO NOT have this situation, I would do it as a preventative measure. |
#317 |
Uhm your an idiot. When the light comes on you lose abs, but you do not lose any braking power.
#318 |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
So I FINALLY had a yaris come in with an ABS light on, ended up being corrosion at the LR connector. If anyone is wondering it's only $45cdn for a whole new harness per side to fix, that is IF the bearings terminals aren't damaged. Fairly easy to change out as well. I'm a little confused at some of the posts saying thousands of dollars being spent to fix these problems
Even both bearings and both harnesses replaced including labour wouldn't be $1000 using toyota parts, through my shop anyways...?
05' Echo Hatch - Greddy Supercharger - rear disc |
#319 |
What if the corrosion is on the terminals hub side? Then what are you going to replace??????????????????????
#320 | |
If the terminal in the hub/bearing unit is damaged you'll have to replace it, but it still isn't terribly expensive. I would definitely agree with what several people have suggested and recommmend taking the connectors off and packing them full of grease to keep them from corroding. The best part is, I suggested to do this on the other sides connector (RR) of the customer's yaris I was working on, and they wouldn't approve me to do it.
#321 |
Exactly, replacing a hub and paying toyotas inflated part pricing is terribly expensive to yaris owners. Especially since it's a design flaw.
#322 | |
The pricing on these parts specifically isn't too bad, I was amazed that the harness was only $45...but that is probably because it is a common issue (they had 9 in stock).
#323 |
Drives: 2006 Yaris Join Date: Jan 2012
I don't understand how people can drive for years with their ABS light on...I was told the car wouldn't pass inspection with it on. I'm going through the same thing now as we speak..car's in at the dealer and I'm waiting to hear the verdict.
#324 |
#yyc
Drives: BSP '07 RS 5dr LB Join Date: Aug 2011
Had the lights come on last week when it was -40, but they went away as soon as it warmed up. Knock on wood that they stay off, will be inspecting the problem area closer in the springtime.
