Old 01-08-2012, 10:28 PM   #1
nemobile
Drives: Yaris 09 Sedan
Loose Change holder(?) and cup holder
Happy new year, everyone!
I have this problem since I bought my 09 yaris sedan as used 1 and a half years ago.
I am not sure what this part is called, but I saw someone called it a change holder that is located by your left leg and cover the fuse box.
This part was always loose, and it kept dropping on my left knee and stayed open all the time I drove, so I took it out temporarily.
I am not sure if the part is broken or something inside is broken so it doesn't hold the change holder(?) well.
Also the passenger side cup holder doesn't stay closed, so I don't let whoever sits there use the cup holder. Is this because something is broken inside?
does anyone have the same experience? I am trying to figure these out by myself and fix them because I don't want to bring this car to a mechanic and pay $$$ for something that doesn't bother the car's performance.
>> Nemobile, my favorite toy! <<
nemobile is offline   Reply With Quote
Old 01-09-2012, 02:06 PM   #2
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
if its still under 36k miles it will be covered under warranty
by the way did you buy from private owner or used car lot?
OTA'sTOY is offline   Reply With Quote
Old 01-09-2012, 02:16 PM   #3
I don't understand. It would be open for them to use it.
Old 01-09-2012, 02:19 PM   #4
Pics would be nice to get an idea of what you are talking about, I'm confused a little.
Old 01-09-2012, 02:43 PM   #5
There is a little metal clip that attached to the top part of the opening for the driver's side change cup and it is probably missing on yours. Unfortunately, I don't see it listed in the EPC, so it is probably only available by purchasing the entire assembly (which is called the "box, instrument panel").
For the passenger cup holder, the spring assembly that keeps it closed may be missing or broken. It is a less than a dollar part (55623-52050).
Old 01-11-2012, 11:53 PM   #6
Revsson
Check out page 42 and 56 of the Instrument Panel service manual on the below link:
http://www.etimago.com/yaris/repairm...nt%20Panel.pdf
It shows how the spring clips should be that hold it in for the sedan.
Other parts of the service manual are here:
http://www.etimago.com/yaris/repairmanual/
Welcome to YarisWorld!
Old 02-20-2012, 11:30 PM   #7
nemobile
It currently has 51k. I bought it from a used car lot. :-/
I regret I didn't check all the details before I bought it. (always learning hard way.)
Old 02-20-2012, 11:32 PM   #8
nemobile
haha I am sorry if I confused you.
The thing is when it's not in use I'd like to close it. but it always stays open.
Old 02-20-2012, 11:34 PM   #9
nemobile
Sorry for the confusion, KCALB SIRAY. I should get used to posting pics. :)
Old 02-20-2012, 11:37 PM   #10
nemobile
Thank you, CTScott! Now I should look for where I can find/order the parts. :P
Old 02-20-2012, 11:44 PM   #11
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
At one point I had thought that I had lost the metal clip...I was so pissed...then I found it sitting under my pull lever for the trunk...ppphhheeewwww! Be careful once you do replace it cause they can come unhinged easily. As for the cupholder that seems to be a theme. I was looking at getting a sedan for my daughter last summer and the summer before that. Found what I felt was a lot of them that had damaged cupholders. Removing them is dicey too because it is easy to lose the metal wires into the dash fast quick and in a hurry so be careful with that as well.
Old 02-20-2012, 11:45 PM   #12
nemobile
Thank you, Revsson.
Unfortunately, the links do not work anymore. Do you know any other place I can find that service manual?
Old 02-20-2012, 11:48 PM   #13
nemobile
Thank you for your story, fnkngrv.
I may end up just leaving them as-is, but I will see what I can do. :)
Old 02-21-2012, 10:52 PM   #14
Revsson
Originally Posted by nemobile View Post
Thank you, Revsson.
Dang...no, I don't know. Perhaps CTScott has an answer.
I think someone had downloaded it to another site like torrent or
something, but I just always went to that link.
Anyone else have an answer for the service manual link?
Old 02-21-2012, 10:56 PM   #15
Garm has a mirror of them on the Micro Image forum:
http://www.microimageonline.com/foru...32-YARIS-FILES
CUP HOLDER REMOVAL? SweetRS Cosmetic Modifications (Exterior/Interior) 13 09-19-2016 09:43 AM
Cup holder busted ras3448 General Yaris / Vitz Discussion 5 09-21-2011 08:01 AM
Dash Cup Holder dzcab Cosmetic Modifications (Exterior/Interior) 5 08-17-2011 11:24 PM
cup holder removal DOMAV General Yaris / Vitz Discussion 9 08-27-2009 12:32 PM
A eye for a eye but a Ipod for a cup holder? yrsdrgn DIY / Maintenance / Service 30 05-08-2007 03:51 AM
