#109 |
![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2011
2007 LB AT, 59,750 miles, have replaced wipers and tires. 0 problems.
#110 |
![]() ![]() Drives: '08 HB Join Date: Nov 2008
2008
LB Black 91193 Pass Front brake caliper replaced under warranty Front Bumper(hit something on highway)/Tires/Oil/Plugs/Wipers/Serp Belt/Added HD Radio/Took Out Back Seat |
#111 |
![]() Drives: Anything but Toyota Join Date: Sep 2011
2010
5 dr Diesel hatchback Venetian silver <7000 miles All warranty. Multimode Transmission clutch reset (twice), air conditioning gas leak repaired, coolant loss investigated - nothing found, corroding alloy wheel replaced, corroding alloy wheel nuts replaced, squeaky driver's floor silenced with all new under carpet components, front wheel geometry reset due to uneven tyre wear. |
#112 |
![]() ![]() ![]() Drives: 2010 Carmine Red hatchback Join Date: Mar 2009
Hmmm.....I forgot about this thread. I posted a few years ago about my '09 hatchback, but I rolled it in Oct. '09. Here's my new Yaris' info:
2010 3-door hatch Carmine red 45K miles averaging 40MPG I have had absolutely no mechanical issues with this car! The paint, on the other hand, not so good. Winter driving has taken its toll on the front end....it looks like it's been sandblasted. Oh well. The only parts I've replaced have been the wiper blades and I replace them once a year on all my cars, just as a precaution. I love my Yaris! |
#113 |
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
2009
3-dr Hatchback, Manual Absolutely Red 65,000 miles 45mpg on daily 1.25 hour commute (each way) Maintenance: Wipers, Synthetic Oil and Filter, Air Filter, Cabin Filter, Synthetic Gear Oil, Tires, and Lucas Fuel Treatment Mods (that might change things): DF210 springs, rear MI anti-swaybar, K&N drop-in air filter, under-hood alternator wire upgrade, and other irrelevant toys. Problems: Lots of stone chips on bumper, a few on the hood, scratched rear bumper, dent in drivers front quarter panel, and replaced front windshield (small chip cracked the glass in half within 3 hours). Who's fault? Bad Michigan Roads, and Worse Road Crews! I inspect the car every oil change (7,500 miles) while it's on my lift, and I don't see any issues starting. |
#114 |
![]() Drives: 2008 Toyota Yaris Sedan Join Date: Feb 2012
I signed up today to see if anyone heard of the same problem my wife and I are having.
Year: 2008 Mileage: 74,xxx Model: 4dr Sedan Color: Flint Mica At 62k miles, our transmission went out and was replaced (by dealer due to our warranty) At approx 70k miles, a bearing in our AC motor went bad, and they replaced that as well. We are nearing the end of our warranty (80k miles) and i'm praying that if anything crazy pops up in terms of major mechanical problems, it does so before our warranty ends. Any advice out there? |
#115 |
![]() Drives: '07 Yaris Hatchback Join Date: Feb 2012
Year: 2007
Mileage: about 65k Model: 2 DR hatchback Color: Bayou Blue Been averaging only 27- 29 mpg. I do mostly around town driving, not much highway driving. This is disappointing. In the first year of owning the car I had to have the passenger seat replaced because it wasn't locking. I also had the turn signal- light mechanism replaced because whenever I turned on my signal my high beams would come on. It's been great otherwise. Maintenance: Oil and filter changes, wiper blades, air filter & in-cabin air filter, tires, and a belt replaced. I've had the car 5 1/2 years now and still haven't had to replace break pads. I have some scratches, a lot from rocks and pebbles on the road, but last summer my friend backed into it, in his own driveway, he buffed out the paint scuff but there's still fairly deep scratches there. No modifications, though I want to get the windows tinted and this evening I'm going out to buy some wheel covers and spray paint and have myself some colored wheels. That should be fun. Also I'm new here, so hi everyone! |
#116 |
Toyota
Drives: '11 5dr/5spd yaris Join Date: Nov 2009
Whoops. Forgot to check in for February.
Purchased 5/29/11: 16 miles 2/1/12: 3,611 miles Average: 103 miles/wk (35 weeks) |
#117 |
![]() ![]() ![]() Drives: BSP Yaris LB 2007 Join Date: Apr 2007
Fixed the title to include other info.
Let's include: 2007 3 dr Black 32000 battery died, 2 flat tires (so far) 2 yrs ago the cheapo stock battery kept dying and later found a dead cell, luckly it was replaced under warranty. Toyota like everyone else put the cheapest battery they can find. Recently my tires started going flat one after another while the car was parked. Apparently in 2007 there was a batch of bad valve stems that cracked at the base due to bad formula mixture. If you bot your car around 07 from the midwest check your valve stems! |
#118 |
![]() ![]() ![]() Drives: Black '09 2dr HB Join Date: Feb 2009
2009
Black 3 dr Bought March 2009 30,270 miles I think I've had atleast 2 flat tires, only replaced one though. No major issues. Been getting regular oil changes & filter changes. At 30,000 maintenace I was told I needed to 'Clean & Adjust rear brake shoes'. This was done. I was also told I need to do a brake fluid flush & Fuel injection & throttle body cleaning. Have not done these, and havent decided if I need to. Some people say to do it, some don't.. |
#119 |
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
not the owner, but was just looking through fuelly and i saw this owner with over 203,000 miles on the ODO
http://www.fuelly.com/driver/n9qgs/yaris |
#120 |
![]() ![]() Drives: 07 BB yaris / 06 Mustang Gt Join Date: Apr 2007
2007 blue yaris hatchback
automatic 83k miles on it... 40k miles tires replaced, 59k miles water pump and serptine belt replaced by warranty. wipers replaced at ?? k miles. average 31-32mpg full tank. |
#121 |
that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
Just hit 95k yesturday
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
#122 |
2010 5dr
39k mi tires replaced twice due to nails on road replaced control arm bolt from TSB Dead battery replaced with junkyard yaris battery (FREEBIE!) Front caliper leaked fluid a bit, my fault for not tightening during bleed after putting in OEM BBK avg 29-33 mpg |
#123 |
2008 yaris
Blazing blue 60,000 Running good, still getting around 35 mpg. Problems: None other then a hood rattle that no one seems to be able to fix tried about ten places. I've just learned to live with it. Done all required services, been pleased with car so far!
http://www.midatlanticnostalgiaconvention.com |
#124 |
![]() Drives: Yaris 2007 Join Date: Jan 2009
2007
Hatchback Grey 78000 No problem so far, only routine maintenance (oil, transmission fluid and coolant change). Not even brake pads or tires. Once battery died about three years ago due to my fault but steel functions like new) |
#125 |
![]() Drives: 07 Yaris 3dr, 09 Yaris 4dr Join Date: Sep 2011
2007 Hatchback
81k No problems so far 2009 Sedan 37k No problems so far |
#126 |
2007 Yaris TS
89000 KM One Problem with ABS Sensor, not terrible! :-P:-P:-P
| excessive sulfur odor on 2007 model year Yaris | tomjasz | General Yaris / Vitz Discussion | 121 | 03-13-2010 06:49 PM |
| TSB's | WD-40 | General Yaris / Vitz Discussion | 27 | 06-06-2007 01:11 AM |
